Home » Eclipse Projects » Remote Application Platform (RAP) » Client error with Browser.execute function
Client error with Browser.execute function [message #1486366] Mon, 24 November 2014 20:52 Go to next message
Hi there,
I got the following error when calling browser.execute("myJavaScriptFunction()");
This only occurs on a deployed version, not in eclipse !
The method is called in
browser.addProgressListener(new ProgressListener() {
public void completed(ProgressEvent event) {
browser.execute("setData("myJavaScriptFunction()");
public void changed(ProgressEvent event) {}
Do you have an idea of the source of the error ??
Emmanuel
Client Error
Details:
Error: Error: Operation "call" on target "w84" of type "rwt.widgets.Browser" failed:
SecurityRestriction:
Browser-Widget can not access "null:-1nullnull" from "XXX.com".
Properties:
script = setData(120,240)
Script: {"head":{"requestCounter":21},"operations":[["set","w10",{"bounds":[0,0,0,0]}],["set","w80",{"bounds":[0,56,1280,445]}],["set","w81",{"bounds":[5,5,1266,431],"clientArea":[0,0,1266,431]}],["set","w82",{"bounds":[0,0,1266,431],"clientArea":[0,0,1266,431]}],["set","w83",{"bounds":[25,25,1216,60]}],["set","w84",{"bounds":[25,90,1216,240]}],["set","w85",{"bounds":[1039,335,202,71]}],["call","w84","evaluate",{"script":"setData(120,240)"}]]}
Stack: Error: Operation "call" on target "w84" of type "rwt.widgets.Browser" failed:
Properties:
at Object.rwt.remote.MessageProcessor._processError (http://XXX.com/rwt-resources/rap-client.js:231:3811)
at Object.rwt.remote.MessageProcessor.processOperationArray (http://XXX.com/rwt-resources/rap-client.js:231:928)
at Object.rwt.remote.MessageProcessor.processMessage (http://XXX.com/rwt-resources/rap-client.js:231:223)
at rwt.qx.Class.define.members._handleSuccess (http://XXX.com/rwt-resources/rap-client.js:235:3630)
at Object._success (http://XXX.com/rwt-resources/rap-client.js:97:1012)
at Object.rwt.remote.Request._onReadyStateChange (http://XXX.com/rwt-resources/rap-client.js:97:1902)
at XMLHttpRequest.d (http://XXX.com/rwt-resources/rap-client.js:15:522)
Debug: off
Request: {"head":{"requestCounter":20},"operations":[["call","rwt.client.TextSizeMeasurement","storeMeasurements",{"results":{"t-1682727348":[292,58]}}],["notify","w84","Progress",{}],["set","w1",{"cursorLocation":[1156,355]}]]}
[Updated on: Mon, 24 November 2014 20:52] by Moderator
Re: Client error with Browser.execute function [message #1486642 is a reply to message #1486366] Tue, 25 November 2014 02:17 Go to previous messageGo to next message
you run into browser security restriction. Obviously, Eclipse internal
(SWT) browser widget does not respect security restrictions like real
browsers. Without the complete picture/snippet (from where you load the
page and what exactly you want to set) I can't help much.
Best,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Client error with Browser.execute function [message #1486671 is a reply to message #1486366] Tue, 25 November 2014 02:46 Go to previous messageGo to next message
.... in any case such security error should not lead to application
crash. Could you please open a bugzilla and attach a snippet to
reproduce the error?
Best,
Ivan
Ivan Furnadjiev
Re: Client error with Browser.execute function [message #1487353 is a reply to message #1486671] Tue, 25 November 2014 14:51 Go to previous messageGo to next message
Hi Ivan,
The problem occurred only when the URL passed to the browser object was
1. is absolute ("http://server:port/page.html")
2. is build using HttpServletRequest methods (getServerName, etc.)
AND
3. when the HttpServletRequest is stored as an object of my Session class (SingletonUtil.getSessionInstance).
In my previous configuration (only 1. and 2.), it was working properly.
Fortunately, passing only "/page.html" as URL (defined as org.eclipse.equinox.http.registry.resources), solved the problem.
For info, the setData method only pass an argument to a javascript method updating InnerHTML of a div.
Hope that helps to identify the bug.
Emmanuel
Re: Client error with Browser.execute function [message #1487355 is a reply to message #1486366] Tue, 25 November 2014 14:54 Go to previous message
No Message Body
Previous Topic:RAP and Cross Site Request Forgery attacks
Next Topic:RAP and org.eclipse.core.runtime.products extension point
Current Time: Sun Jul 27 02:10:52 EDT 2025
Powered by FUDForum. Page generated in 0.04345 seconds
