Home » Archived » BIRT » Chart Data Type
Chart Data Type [message #148553] Mon, 27 March 2006 12:34 Go to next message
Originally posted by: wyzaj.bethelcollege.edu
Sorry if this is outlined somewhere else but i can't seem to figure out why
this won't work.
I am attempting to make a simple pie chart, however, when I drop the data
column for the Category Definition I get the error:
"Unexpected non-numerical data type Accounting found in data
set; cannot convert to numeric value."
I have looked at my data and it is all numberic values that look like 12.0,
10.0, etc. Is there some option or switch I need to flip somewhere?
Thanks in advance,
Jonathon
Re: Chart Data Type [message #148560 is a reply to message #148553] Mon, 27 March 2006 13:07 Go to previous messageGo to next message
The Value Series need to be numeric, maybe it's not a numeric datatype in
the db?
David
"Jonathon Wyza" <wyzaj@bethelcollege.edu> wrote in message
news:e097nb$6kh$1@utils.eclipse.org...
> why this won't work.
> 12.0, 10.0, etc. Is there some option or switch I need to flip somewhere?
> Thanks in advance,
> Jonathon
Re: Chart Data Type [message #148566 is a reply to message #148560] Mon, 27 March 2006 13:13 Go to previous messageGo to next message
I am using the count() function so I am assuming that returns a numeric
datatype. If I go into Edit Data Set and go down to Output Columns it
shows the column as Type - Double.
> the db?
> David
>> Thanks in advance,
>> Jonathon
Re: Chart Data Type [message #148930 is a reply to message #148566] Tue, 28 March 2006 08:35 Go to previous message
Can you post some sample data and what values you input in the select data
tab of the chart builder?
David
news:e09a15$mqi$1@utils.eclipse.org...
>> the db?
>> Thanks,
>> David
>>> data column for the Category Definition I get the error:
>>> data set; cannot convert to numeric value."
>>> somewhere?
>>> Thanks in advance,
>>> Jonathon
Previous Topic:Does BIRT Viewer work with Firefox?
Next Topic:Urgent: Large script files problem
Current Time: Sat Jul 26 09:35:22 EDT 2025
Powered by FUDForum. Page generated in 0.05491 seconds
