Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMFStore] unable to retrieve history
[EMFStore] unable to retrieve history [message #1454068] |
Mon, 27 October 2014 19:10  |
I have a model stored in EMFStore that has gone through 269 revisions
and is about 10MB in size on the server. I'm able to checkout revisions
through the History Browser after a certain version, but attempting to
checkout any revision before that version fails with the following
exception.
Have you seen this kind of problem before. What could cause this and is
that a way I can fix it so that previous versions are accessible?
!ENTRY org.eclipse.emf.emfstore.client 4 4 2014-10-27 18:58:24.579
!MESSAGE
org.eclipse.emf.emfstore.internal.server.exceptions.ConnectionException:
Server could not be reached.
Failed to parse server's response: Couldn't parse EObject: Failed to
retrieve ID for EObject contained in project:
com.humanfactor.rw.model.regatta.impl.ResultsImpl@7d382ac6
(officialFinishTime: null, rawFinishTime: null, officialOrderOfFinish:
0, adjustedOrderOfFinish: 0)
!STACK 0
java.util.concurrent.ExecutionException:
at java.util.concurrent.FutureTask.report(FutureTask.java:122)
at java.util.concurrent.FutureTask.get(FutureTask.java:202)
at
org.eclipse.emf.emfstore.internal.client.common.UnknownEMFStoreWorkloadCommand.execute(UnknownEMFStoreWorkloadCommand.java:83)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$13.call(ESRemoteProjectImpl.java:415)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$13.call(ESRemoteProjectImpl.java:1)
at
org.eclipse.emf.emfstore.client.util.RunESCommand$WithException$1.doRun(RunESCommand.java:61)
at
org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommandWithResult.commandBody(EMFStoreCommandWithResult.java:31)
at
org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.execute(AbstractEMFStoreCommand.java:64)
at
com.humanfactor.emf.edocument.editingdomain.EMFStoreTransactionalCommandStack$1.doExecute(EMFStoreTransactionalCommandStack.java:61)
at
org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
at
org.eclipse.emf.common.command.BasicCommandStack.execute(BasicCommandStack.java:78)
at
org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.basicExecute(AbstractTransactionalCommandStack.java:241)
at
com.humanfactor.emf.edocument.editingdomain.EMFStoreTransactionalCommandStack.basicExecute(EMFStoreTransactionalCommandStack.java:163)
at
org.eclipse.emf.transaction.impl.TransactionalCommandStackImpl.doExecute(TransactionalCommandStackImpl.java:63)
at
org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at
org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at
com.humanfactor.emf.edocument.editingdomain.EMFStoreTransactionalCommandStack.runEMFStoreCommand(EMFStoreTransactionalCommandStack.java:64)
at
com.humanfactor.emf.edocument.editingdomain.EMFStoreTransactionalCommandStack.execute(EMFStoreTransactionalCommandStack.java:49)
at
org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.aRun(AbstractEMFStoreCommand.java:108)
at
org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommandWithResult.run(EMFStoreCommandWithResult.java:59)
at
org.eclipse.emf.emfstore.client.util.RunESCommand$WithException.runWithResult(RunESCommand.java:78)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl.fetch(ESRemoteProjectImpl.java:395)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl.checkout(ESRemoteProjectImpl.java:438)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl.checkout(ESRemoteProjectImpl.java:1)
at
org.eclipse.emf.emfstore.internal.client.ui.controller.UICheckoutController.doRun(UICheckoutController.java:245)
at
org.eclipse.emf.emfstore.internal.client.ui.controller.UICheckoutController.doRun(UICheckoutController.java:1)
at
org.eclipse.emf.emfstore.internal.client.ui.common.MonitoredEMFStoreAction$1.run(MonitoredEMFStoreAction.java:70)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at
org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
at
org.eclipse.ui.internal.progress.ProgressManager.run(ProgressManager.java:1162)
at
org.eclipse.emf.emfstore.internal.client.ui.common.MonitoredEMFStoreAction.execute(MonitoredEMFStoreAction.java:67)
at
org.eclipse.emf.emfstore.internal.client.ui.handlers.CheckoutRevisionHandler.handle(CheckoutRevisionHandler.java:60)
at
org.eclipse.emf.emfstore.internal.client.ui.handlers.AbstractEMFStoreHandler.handleWithResult(AbstractEMFStoreHandler.java:29)
at
org.eclipse.emf.emfstore.internal.client.ui.handlers.AbstractEMFStoreHandlerWithResult$1.doRun(AbstractEMFStoreHandlerWithResult.java:52)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.emf.emfstore.internal.client.ui.handlers.AbstractEMFStoreHandlerWithResult.execute(AbstractEMFStoreHandlerWithResult.java:54)
at
org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
at
org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at
org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at
org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:243)
at
org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:224)
at
org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at
org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:167)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
at
org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at
org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at
org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:850)
at
org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:743)
at
org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:727)
at
org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:662)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at
org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
at
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at com.humanfactor.rw.rcp.RWApplication.start(RWApplication.java:136)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by:
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcClientManager.executeCall(XmlRpcClientManager.java:174)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcClientManager.callWithResult(XmlRpcClientManager.java:120)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcConnectionManager.getProject(XmlRpcConnectionManager.java:172)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$13$1$1.run(ESRemoteProjectImpl.java:409)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$13$1$1.run(ESRemoteProjectImpl.java:1)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.ServerCall.run(ServerCall.java:249)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.SessionManager.executeCall(SessionManager.java:126)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.SessionManager.execute(SessionManager.java:65)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.ServerCall.execute(ServerCall.java:269)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$13$1.run(ESRemoteProjectImpl.java:413)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$13$1.run(ESRemoteProjectImpl.java:1)
at
org.eclipse.emf.emfstore.internal.client.common.UnknownEMFStoreWorkloadCommand$1.call(UnknownEMFStoreWorkloadCommand.java:73)
at java.util.concurrent.FutureTask.run(FutureTask.java:262)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:744)
Caused by: org.apache.xmlrpc.client.XmlRpcClientException: Failed to
parse server's response: Couldn't parse EObject: Failed to retrieve ID
at
org.apache.xmlrpc.client.XmlRpcStreamTransport.readResponse(XmlRpcStreamTransport.java:188)
at
org.apache.xmlrpc.client.XmlRpcStreamTransport.sendRequest(XmlRpcStreamTransport.java:156)
at
org.apache.xmlrpc.client.XmlRpcHttpTransport.sendRequest(XmlRpcHttpTransport.java:143)
at
org.apache.xmlrpc.client.XmlRpcSunHttpTransport.sendRequest(XmlRpcSunHttpTransport.java:69)
at
org.apache.xmlrpc.client.XmlRpcClientWorker.execute(XmlRpcClientWorker.java:56)
at org.apache.xmlrpc.client.XmlRpcClient.execute(XmlRpcClient.java:167)
at org.apache.xmlrpc.client.XmlRpcClient.execute(XmlRpcClient.java:137)
at org.apache.xmlrpc.client.XmlRpcClient.execute(XmlRpcClient.java:126)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcClientManager.executeCall(XmlRpcClientManager.java:164)
... 15 more
Caused by: org.xml.sax.SAXException: Couldn't parse EObject: Failed to
org.apache.xmlrpc.XmlRpcException: Couldn't parse EObject: Failed to
at
org.apache.xmlrpc.parser.RecursiveTypeParserImpl.endValueTag(RecursiveTypeParserImpl.java:80)
at
org.apache.xmlrpc.parser.XmlRpcResponseParser.endElement(XmlRpcResponseParser.java:197)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(AbstractSAXParser.java:609)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(XMLDocumentFragmentScannerImpl.java:1789)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2965)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:606)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:117)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:510)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:848)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:777)
at
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
at
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:649)
at
org.apache.xmlrpc.client.XmlRpcStreamTransport.readResponse(XmlRpcStreamTransport.java:186)
... 23 more
Caused by: org.apache.xmlrpc.XmlRpcException: Couldn't parse EObject:
Failed to retrieve ID for EObject contained in project:
at
org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.util.EObjectTypeParser.getResult(EObjectTypeParser.java:80)
at
org.apache.xmlrpc.parser.RecursiveTypeParserImpl.endValueTag(RecursiveTypeParserImpl.java:78)
... 36 more
Caused by:
org.eclipse.emf.emfstore.internal.server.exceptions.SerializationException:
at
org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.util.EObjectTypeParser.getResultfromResource(EObjectTypeParser.java:147)
at
org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.util.EObjectTypeParser.getResult(EObjectTypeParser.java:74)
... 37 more
!ENTRY org.eclipse.emf.emfstore.client 4 4 2014-10-27 18:58:24.591
!MESSAGE Server could not be reached.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 15 more
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 23 more
at
at
... 36 more
Caused by:
at
at
... 37 more
Current Time: Thu Jul 31 17:20:35 EDT 2025
Powered by FUDForum. Page generated in 0.03309 seconds
