Home » Archived » BIRT » Report Engine runtime problem...help
Report Engine runtime problem...help [message #147193] Wed, 22 March 2006 17:18 Go to next message
I downloaded & unzipped birt-runtime-2_0_1.zip, and put all the jars under
the .../Report Engine/ directory into my project, and can compile classes
that use the Engine, but I'm getting the error below when it runs.
(P.S. The err msg indicates that the IRenderReport class is not found, but I
looked in engine.jar and it is there, and in the right dir...I'm chasing my
tail at this point...HELP!)
javax.servlet.ServletException: Servlet execution threw an exception
edu.iu.uis.cas.filter.FilterCAS.doFilter(FilterCAS.java:277)
edu.iu.uis.ie.Utilities.PerRequestLoggerFilter.doFilter(PerR equestLoggerFilter.java:52)
root cause
java.lang.NoClassDefFoundError:
org/eclipse/birt/report/engine/api/IRenderOption
java.lang.Class.getDeclaredConstructors0(Native Method)
java.lang.Class.privateGetDeclaredConstructors(Class.java:23 28)
java.lang.Class.getConstructor0(Class.java:2640)
java.lang.Class.newInstance0(Class.java:321)
java.lang.Class.newInstance(Class.java:303)
org.apache.struts.util.RequestUtils.applicationInstance(Requ estUtils.java:231)
org.apache.struts.action.RequestProcessor.processActionCreat e(RequestProcessor.java:326)
org.apache.struts.action.RequestProcessor.process(RequestPro cessor.java:268)
edu.iu.uis.ie.Utilities.IERequestProcessor.process(IERequest Processor.java:204)
org.apache.struts.action.ActionServlet.process(ActionServlet .java:1482)
org.apache.struts.action.ActionServlet.doPost(ActionServlet. java:525)
edu.iu.uis.ie.Utilities.IEActionServlet.doGet(IEActionServle t.java:39)
javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
Re: Report Engine runtime problem...help [message #147269 is a reply to message #147193] Thu, 23 March 2006 02:27 Go to previous messageGo to next message
Did you add iText.jar and prototype.js?
Scott Rosenbaum
BIRT PMC
> root cause
Re: Report Engine runtime problem...help [message #147646 is a reply to message #147269] Thu, 23 March 2006 17:32 Go to previous messageGo to next message
Yes I had already installed both of these files (as indicated
below)...before getting the error I reported.
itext-1.3.jar -> installed in the following directory:
birt-runtime-2_0_1\Report
Engine\plugins\org.eclipse.birt.report.engine.emitter.pdf\li b
prototype.js -> installed in the following directory:
birt-runtime-2_0_1\Report Engine\ajax\lib
P.S. But I must add the the Run Time Egnine installation instructions don't
indicate that prototype.js is needed for the Run Time engine (API)
installation.
__________________________________________________________
"Scott Rosenbaum" <scottr@innoventsolutions.com> wrote in message
news:dvtili$loi$1@utils.eclipse.org...
> Scott Rosenbaum
> BIRT PMC
>> under the .../Report Engine/ directory into my project, and can compile
>> classes that use the Engine, but I'm getting the error below when it
>> runs.
>> but I looked in engine.jar and it is there, and in the right dir...I'm
>> chasing my tail at this point...HELP!)
>> root cause
Re: Report Engine runtime problem...help [message #148525 is a reply to message #147646] Mon, 27 March 2006 11:14 Go to previous message
I solved this problem (at least temporarily) by copying the libraries on the
classpath to the WEB-INF/lib directory of my applcation....
"BITBURNER" <rileymg@indiana.edu> wrote in message
news:dvv7m4$t2v$1@utils.eclipse.org...
> don't indicate that prototype.js is needed for the Run Time engine (API)
> installation.
>> Scott Rosenbaum
>> BIRT PMC
>>> runs.
>>> root cause
Previous Topic:Birt Chart
Next Topic:Publishing BIRT Template
Current Time: Tue Jul 22 13:10:16 EDT 2025
Powered by FUDForum. Page generated in 0.03741 seconds
