Home » Eclipse Projects » GEF » Coordinates, zoom and scrollbars
Coordinates, zoom and scrollbars [message #148264] Fri, 20 August 2004 09:39 Go to next message
Hi all,
I need to draw a line as insertion point for the part to be newly created.
The position depends on the cursor location and the underlying parts.
If I do not translate the line points to absolute the line position and
size will be OK if zoom is 100% but shrinked if the zoom differs from 100%.
If I translate the line points to absolute the line will be OK for all zoom
value but will wrong if the editor's scrollbar are not in the top-left
position.
I can't have my line with the right position and size for both zoom
different from 100% AND scrollbars not on top-left position.
To draw the line I first translate the points and the create a Polyline
What am I doing wrong?
I am using Eclipse 3.0 with GEF 3.0 on Win 2000
Thanks in advance for any help
Roberto
Re: Coordinates, zoom and scrollbars [message #148267 is a reply to message #148264] Fri, 20 August 2004 10:19 Go to previous messageGo to next message
The feedback layer is not scaled, but it is translated during scrolling. To
correct for this, once you are in absolute coordinates, you need to call:
myFeedbackLine.translateToRelative(Translatable)
or equivalently:
feedbacklayer.translateToRelative(t)
feedbacklayer.translateFromParent(t)
"Roberto Genini" <roberto.genini@icimsi.ch> wrote in message
news:opsc09j1fk71gv6x@news.eclipse.org...
> Hi all,
100%.
zoom
> position.
> Roberto
Re: Coordinates, zoom and scrollbars [message #148273 is a reply to message #148267] Fri, 20 August 2004 11:23 Go to previous message
Yes!
It works.
Many thanks
Roberto
Previous Topic:Which tool should I use for drawing lines
Next Topic:MultiLineLabel parent Composite from Draw2D Panel?
Current Time: Sun Aug 03 05:27:20 EDT 2025
Powered by FUDForum. Page generated in 0.06211 seconds
