Duplicate generated method from extended ecore model [message #1479767] |
Wed, 19 November 2014 13:14  |
I am creating an ASTM model by extending modisco's OMG GASTM model. I define an extended function definition class from GASTM's FunctionDefinition. When I generate the model code, there are several duplicate methods with different return types as follow:
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public FormalParameterDefinition[] getFormalParameters() {
if (formalParameters == null || formalParameters.isEmpty()) return FORMAL_PARAMETERS_EEMPTY_ARRAY;
BasicEList<FormalParameterDefinition> list = (BasicEList<FormalParameterDefinition>)formalParameters;
list.shrink();
return (FormalParameterDefinition[])list.data();
* @generated
public EList<FormalParameterDefinition> getFormalParameters() {
if (formalParameters == null) {
formalParameters = new EObjectContainmentEList<FormalParameterDefinition>(FormalParameterDefinition.class, this, Rpg4Package.IRPG4_PROCEDURE_STATEMENT__FORMAL_PARAMETERS + EOFFSET_CORRECTION);
return formalParameters;
* @generated
public Statement[] getBody() {
if (body == null || body.isEmpty()) return BODY_EEMPTY_ARRAY;
BasicEList<Statement> list = (BasicEList<Statement>)body;
list.shrink();
return (Statement[])list.data();
* @generated
public EList<Statement> getBody() {
if (body == null) {
body = new EObjectContainmentEList<Statement>(Statement.class, this, Rpg4Package.IRPG4_PROCEDURE_STATEMENT__BODY + EOFFSET_CORRECTION);
return body;
I checked the super declarations in class org.eclipse.modisco.omg.gastm.FunctionDefinition, only the methods return EList<?> are defined.
Why does EMF generate the methods return array? How can I make EMF doesn't generate them?
Re: Duplicate generated method from extended ecore model [message #1480807 is a reply to message #1480398] |
Thu, 20 November 2014 08:55  |
Thanks. It works after I disable the property.
Ed Merks wrote on Thu, 20 November 2014 01:33Jacob,
It sounds like someone has enabled the GenModel's Model -> Array
Accessors property.
> * @generated
> list.shrink();
> * @generated
> * @generated
> list.shrink();
> * @generated
> if (body == null) {
> body = new
> return body;
FUDForum. Page generated in 0.24808 seconds
