Home » Modeling » EMF » (Re)using model elements in other models
(Re)using model elements in other models [message #1479703] Wed, 19 November 2014 12:07 Go to next message
i'm thinking about reusing parts of my model in other models.
Let's say I have a class "Entity" where I implemented some basic rules. Now I want to create another new model with a class where I use class "Entity" class as supertype.
When I add entity-ecore to the new ecore by "load resource..." I can archive something like this, but the entity-model-code is generated new in the new project. No custom code is available with this approach - at least not in my usage.
Is there a way use the "Entity" model project (where custom code is included) instead of creating it new?
I appreciate any help.
Philippe
Re: (Re)using model elements in other models [message #1479719 is a reply to message #1479703] Wed, 19 November 2014 12:23 Go to previous messageGo to next message
On 19/11/2014 18:07, Phil Wim wrote:
When you create the genmodel for your extension .ecore, you can select
the entity model in the lower table denoted "Referenced Generator
Models", like I did quickly here to illustrate:
http://imgur.com/Eg9yWgz
Re: (Re)using model elements in other models [message #1480685 is a reply to message #1479719] Thu, 20 November 2014 06:38 Go to previous message
Felix,
thanks for the quick answer. Exactly what i was looking for.
Philippe
Previous Topic:XSD to dynamic meta model?
Next Topic:Duplicate generated method from extended ecore model
Current Time: Sun Aug 31 00:30:27 EDT 2025
Powered by FUDForum. Page generated in 0.03990 seconds
