Home » Eclipse Projects » Oomph » Setup Mylyn Query connector trac Edgewall(xml-rpc)
Setup Mylyn Query connector trac Edgewall [message #1479241] Wed, 19 November 2014 04:16 Go to next message
Dear all,
I'm trying to setup mylyn queries by using Oomph (which is very nice and a very useful) and I can't set in my *.setup file the access type of the trac connector for my trac repository (see attached picture).
  <setupTask
      xsi:type="mylyn:MylynQueriesTask"
      connectorKind="trac"
      repositoryURL="http://l-svn2/tracsvn/obswGen"
      userID="${spb.user}"
      password="${spb.password}">
    <query summary="Tickets"
        url="http://l-svn2/tracsvn/obswGen/query?format=tab&amp;order=id"/>
    <description>Trac SVN of the project</description>
  </setupTask>
Is there a special annotation to specify the Access Type to XML-RPC ?
Thanks for any help ;
Johan
  • Attachment: trac.jpg
    (Size: 65.37KB, Downloaded 168 times)
[Updated on: Wed, 19 November 2014 04:17] by Moderator
Re: Setup Mylyn Query connector trac Edgewall [message #1479308 is a reply to message #1479241] Wed, 19 November 2014 05:25 Go to previous messageGo to next message
I managed to access Trac through XML-RPC without problems with Oomph, no extra settings required.
Did you add Mylyn Trac feature to your P2 director class?
<setup.p2:P2Task
    xmi:version="2.0"
    xmlns:setup.p2="http://www.eclipse.org/oomph/setup/p2/1.0">>
  <requirement
      name="org.eclipse.mylyn_feature.feature.group"/>
  <requirement
      name="org.eclipse.mylyn.trac_feature.feature.group"/>
  <repository
      url="http://download.eclipse.org/mylyn/releases/latest"/>
</setup.p2:P2Task>
Re: Setup Mylyn Query connector trac Edgewall [message #1488100 is a reply to message #1479308] Wed, 26 November 2014 05:07 Go to previous message
Yes of course, I added mylyn and the trac connector as requirement like you mention.
Actually, everything works perfectly except that the setting XML RPC is not selected (see my picture). Mylyn accesses tickets via the generic web browser of eclipse instead of using the the appropriate view of mylyn tickets.
Probably that the issue is on the repository side i.e. XML-RPC shall be the default protocol.
However, it would be very nice to specify in Oomph which protocol is used !
Johan
Previous Topic:Rename Eclipse executable
Next Topic:NoSuchMethodError: OfflineMode.setEnabled() since update
Current Time: Thu Jul 24 22:03:48 EDT 2025
Powered by FUDForum. Page generated in 0.06050 seconds
