| Hudson support [message #1477906] |
Tue, 18 November 2014 02:58  |
I heard a rumour that Hudson support is gonna stop in another one year.
Is that a true statement?
Please let me know if any update on this statement .. We are using Hudson in our project.
[Updated on: Tue, 18 November 2014 02:59] by Moderator
| Re: Hudson support [message #1647353 is a reply to message #1548400] |
Tue, 03 March 2015 06:34  |
Hi Prakash,
currently i am using Hudson 3.2.1 can you please tell me minimum versions of jdk,ant,maven and apache-tomcat ?
coming to my problem am using Active Directory plugin 1.31-h3 matrix based Authentication, when i am trying to add user to matrx based authentication it is showing error.
FYI
Mar 03, 2015 2:56:47 AM hudson.plugins.active_directory.ActiveDirectoryUnixAuthenticationProvider retrieveUser
WARNING: Failed to retrieve user information for admin
javax.naming.NamingException: [LDAP: error code 1 - 00000000: LdapErr: DSID-0C090627, comment: In order to perform this operation a successful bind must be completed on the connection., data 0, vece ]; remaining name 'DC=global,DC=,DC=com'
at com.sun.jndi.ldap.LdapCtx.mapErrorCode(LdapCtx.java:3127)
at com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:3033)
at com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:2840)
at com.sun.jndi.ldap.LdapCtx.searchAux(LdapCtx.java:1849)
at com.sun.jndi.ldap.LdapCtx.c_search(LdapCtx.java:1772)
at com.sun.jndi.ldap.LdapCtx.c_search(LdapCtx.java:1789)
at com.sun.jndi.toolkit.ctx.ComponentDirContext.p_search(ComponentDirContext.java:412)
at com.sun.jndi.toolkit.ctx.PartialCompositeDirContext.search(PartialCompositeDirContext.java:394)
at com.sun.jndi.toolkit.ctx.PartialCompositeDirContext.search(PartialCompositeDirContext.java:376)
at hudson.plugins.active_directory.LDAPSearchBuilder.search(LDAPSearchBuilder.java:52)
at hudson.plugins.active_directory.LDAPSearchBuilder.searchOne(LDAPSearchBuilder.java:42)
at hudson.plugins.active_directory.ActiveDirectoryUnixAuthenticationProvider.retrieveUser(ActiveDirectoryUnixAuthenticationProvider.java:261)
at hudson.plugins.active_directory.ActiveDirectoryUnixAuthenticationProvider.retrieveUser(ActiveDirectoryUnixAuthenticationProvider.java:191)
at hudson.plugins.active_directory.ActiveDirectoryUnixAuthenticationProvider.retrieveUser(ActiveDirectoryUnixAuthenticationProvider.java:135)
at hudson.plugins.active_directory.AbstractActiveDirectoryAuthenticationProvider.loadUserByUsername(AbstractActiveDirectoryAuthenticationProvider.java:30)
at hudson.plugins.active_directory.ActiveDirectoryMailAddressResolverImpl.findMailAddressFor(ActiveDirectoryMailAddressResolverImpl.java:30)
at hudson.tasks.MailAddressResolver.resolve(MailAddressResolver.java:88)
at hudson.tasks.Mailer$UserProperty.getAddress(Mailer.java:542)
at hudson.plugins.emailext.ExtendedEmailPublisher.createMail(ExtendedEmailPublisher.java:316)
at hudson.plugins.emailext.ExtendedEmailPublisher.sendMail(ExtendedEmailPublisher.java:238)
at hudson.plugins.emailext.ExtendedEmailPublisher._perform(ExtendedEmailPublisher.java:230)
at hudson.plugins.emailext.ExtendedEmailPublisher.perform(ExtendedEmailPublisher.java:190)
at hudson.tasks.BuildStepMonitor$3.perform(BuildStepMonitor.java:51)
at hudson.model.AbstractBuild$AbstractRunner.perform(AbstractBuild.java:736)
at hudson.model.AbstractBuild$AbstractRunner.performAllBuildSteps(AbstractBuild.java:714)
at hudson.model.AbstractBuild$AbstractRunner.performAllBuildSteps(AbstractBuild.java:690)
at hudson.model.Build$RunnerImpl.cleanUp(Build.java:174)
at hudson.model.Run.run(Run.java:1536)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:44)
at hudson.model.ResourceController.execute(ResourceController.java:82)
at hudson.model.Executor.run(Executor.java:137)
WARNING: Credential exception tying to authenticate against global..com domain
org.springframework.security.authentication.BadCredentialsException: Failed to retrieve user information for admin
at hudson.plugins.active_directory.ActiveDirectoryUnixAuthenticationProvider.retrieveUser(ActiveDirectoryUnixAuthenticationProvider.java:307)
Caused by: javax.naming.NamingException: [LDAP: error code 1 - 00000000: LdapErr: DSID-0C090627, comment: In order to perform this operation a successful bind must be completed on the connection., data 0, vece ]; remaining name 'DC=global,DC=,DC=com'
... 19 more
Mar 03, 2015 2:56:47 AM com.mtvi.plateng.hudson.ldap.LdapMailAddressResolver findMailAddressFor
INFO: Using provided credentials for binding to LDAP server
SEVERE: Unable to run LDAP query
javax.naming.NamingException: Cannot parse url: sample.apac..com [Root exception is java.net.MalformedURLException: Invalid URI: sample.apac..com]
at com.sun.jndi.ldap.LdapURL.<init>(LdapURL.java:95)
at com.sun.jndi.ldap.LdapCtxFactory.getUsingURL(LdapCtxFactory.java:164)
at com.sun.jndi.ldap.LdapCtxFactory.getUsingURLs(LdapCtxFactory.java:211)
at com.sun.jndi.ldap.LdapCtxFactory.getLdapCtxInstance(LdapCtxFactory.java:154)
at com.sun.jndi.ldap.LdapCtxFactory.getInitialContext(LdapCtxFactory.java:84)
at javax.naming.spi.NamingManager.getInitialContext(NamingManager.java:684)
at javax.naming.InitialContext.getDefaultInitCtx(InitialContext.java:307)
at javax.naming.InitialContext.init(InitialContext.java:242)
at javax.naming.InitialContext.<init>(InitialContext.java:216)
at javax.naming.directory.InitialDirContext.<init>(InitialDirContext.java:101)
at com.mtvi.plateng.hudson.ldap.LdapMailAddressResolver.findMailAddressFor(LdapMailAddressResolver.java:85)
at com.mtvi.plateng.hudson.ldap.LdapMailAddressResolver.findMailAddressFor(LdapMailAddressResolver.java:61)
Caused by: java.net.MalformedURLException: Invalid URI: sample.apac..com
at com.sun.jndi.toolkit.url.Uri.parse(Uri.java:199)
at com.sun.jndi.toolkit.url.Uri.init(Uri.java:138)
at com.sun.jndi.ldap.LdapURL.<init>(LdapURL.java:85)
... 26 more
Mar 03, 2015 2:56:47 AM com.mtvi.plateng.hudson.regex.Configuration findMailAddressFor
WARNING: RegExMailAddressResolver configuration for regex null and email pattern null is not valid.
Mar 03, 2015 3:26:34 AM hudson.plugins.active_directory.ActiveDirectoryUnixAuthenticationProvider retrieveUser
WARNING: Failed to retrieve user information for nagrawal
org.springframework.security.authentication.BadCredentialsException: Failed to retrieve user information for nagrawal
... 19 more
Mar 03, 2015 3:26:34 AM com.mtvi.plateng.hudson.ldap.LdapMailAddressResolver findMailAddressFor
... 26 more
Mar 03, 2015 3:26:34 AM com.mtvi.plateng.hudson.regex.Configuration findMailAddressFor
Mar 03, 2015 3:26:35 AM hudson.plugins.active_directory.ActiveDirectoryUnixAuthenticationProvider retrieveUser
WARNING: Failed to retrieve user information for vsagar
org.springframework.security.authentication.BadCredentialsException: Failed to retrieve user information for vsagar
... 19 more
i have edited hudson-security.xml file to add users in backend thats why it shows no of users in attached sreenshot.
Thanks in Advance
Attachment: Hud.JPG
(Size: 111.99KB, Downloaded 732 times)
FUDForum. Page generated in 0.06554 seconds
