| Control a connection appearance [message #146295] |
Sun, 12 August 2007 12:27  |
Originally posted by: jorge.matos_.-gmail.com
Hello!
I'm doing a graphic plugin with GMF to make a fluxogram that represents a
programming language. One of the possible figures that an user can use is a
representation of a switch statement. And each switch can have multiple
cases.
The problem is that, for example, if a switch has 10 cases because the
connections are a strait line the graphic will look like a tree...
What I wanted to do is to pre-define the connections between the switch and
the various cases statments to have a specific look. Something like this:
This is suposed to be an example of a switch with 4 cases :)
Thanks in advance
| Re: Control a connection appearance [message #147832 is a reply to message #146959] |
Sat, 25 August 2007 10:16  |
Ok, thanks.
But what I want is to control the connections look, and to do that I will
have to work with edit policies, isn't?
----- Original Message -----
Newsgroups: eclipse.modeling.gmf
Sent: Friday, August 17, 2007 11:41 AM
Subject: Re: Control a connection appearance
>I just mean that you could break multisegment connection in a number of
>connections with intermediate node and this could simplify your diagram
>editor.
> Jorge Matos wrote:
>> Thanks for your help, but i'm not understanding your idea... Can you
>> explain it better? If you have any doubt about what I want to do feel
>> free to ask!
>> I think I will have to use edit policies to achieve those connections,
>> right?
>> "Dmitry Stadnik" <5d5@mail.ru> wrote in message
>> news:f9rroq$hv3$1@build.eclipse.org...
>>> It will be easier to represent it like this:
>>> Jorge Matos wrote:
>>>> Hello!
>>>> a programming language. One of the possible figures that an user can
>>>> use is a representation of a switch statement. And each switch can have
>>>> multiple cases.
>>>> and the various cases statments to have a specific look. Something like
>>>> this:
>>>> Thanks in advance
FUDForum. Page generated in 0.09011 seconds
