Home » Eclipse Projects » Eclipse 4 » Eclipse Luna Problem with @Inject(Eclipse Luna Problem with @Inject)
Eclipse Luna Problem with @Inject [message #1472084] Thu, 13 November 2014 10:35 Go to next message
Hello
I have created a new Eclipse 4 Application Project in Luna with a SamplePart:
The SamplePart has a samplePartActivated method with annotation Inject
@Inject
private void samplePartActivated(
@UIEventTopic(UIEvents.UILifeCycle.ACTIVATE) MPart activePart) {
if (activePart != null) {
System.out.println("Activation !!!!");
With Luna I have this exception:
org.eclipse.e4.core.di.InjectionException: Unable to process "SamplePart#samplePartActivated()": no actual value was found for the argument "MPart[@org.eclipse.e4.ui.di.UIEventTopic(value=org/eclipse/e4/ui/LifeCycle/activate)]".
The same code was working on juno.
Can anyone please help me?
Re: Eclipse Luna Problem with @Inject [message #1472205 is a reply to message #1472084] Thu, 13 November 2014 12:43 Go to previous messageGo to next message
You need to:
a) use @Optional on the methpd or
b) use @Optional on the parameter
Tom
On 13.11.14 17:03, ludovic drouineau wrote:
> Hello
> SamplePart:
> @Inject
> activePart) {
> argument
Re: Eclipse Luna Problem with @Inject [message #1472944 is a reply to message #1472205] Fri, 14 November 2014 03:00 Go to previous messageGo to next message
I've done this and I don't have the exception but the parameter is always null:
@Inject
@Optional
@UIEventTopic
System.out.println("Activation!");
else System.out.println("activePart is null!");
(In Juno, parameter was not null)
Ludo
Re: Eclipse Luna Problem with @Inject [message #1477971 is a reply to message #1472944] Tue, 18 November 2014 04:07 Go to previous messageGo to next message
Should I avoid using
@UIEventTopic
(UIEvents.UILifeCycle.ACTIVATE) MPart activePart ?
Re: Eclipse Luna Problem with @Inject [message #1478096 is a reply to message #1477971] Tue, 18 November 2014 06:32 Go to previous messageGo to next message
Not 100% sure, but should the parameter type be org.osgi.service.event.Event instead of MPart when listening to the event.
I guess what you want to do is
@Inject
@Optional
public void receiveActivePart(@Named(IServiceConstants.ACTIVE_PART) MPart activePart) {
  System.out.println("Active part changed "
    + activePart.getLabel());
As explained here: http://www.vogella.com/tutorials/EclipseRCP/article.html#dependencyinjection_activeconstants
Re: Eclipse Luna Problem with @Inject [message #1478184 is a reply to message #1478096] Tue, 18 November 2014 08:08 Go to previous message
Perfect! It works.
Previous Topic:EMenuService - get UI representation of menu
Next Topic:Luna 4.4 unable to connect to marketplace behind firewall
Current Time: Sat Jul 19 01:48:07 EDT 2025
Powered by FUDForum. Page generated in 0.03922 seconds
