Home » Language IDEs » Java Development Tools (JDT) » Refactoring warning instead of appending this
Refactoring warning instead of appending this [message #147577] Fri, 05 March 2004 22:32 Go to next message
Originally posted by: igor.noemail.com
I had a problem upon refactoring in this code:
class MyClass {
private int i;
MyClass(int j) {
i = j;
Renaming i into j displays a warning instead of creating
class MyClass {
private int j;
MyClass(int j) {
this.j = j;
Why isn't "this.j" automatically created? IMHO this should be done.
Igor
Re: Refactoring warning instead of appending this [message #147585 is a reply to message #147577] Fri, 05 March 2004 23:43 Go to previous messageGo to next message
Igor,
there's *always* going to be cases for which someone will think they're
obvious and missing.
but the developers cannot read people's minds - that's why you should enter
a feature request
(it's JDT UI, btw)
cheers
a.
Re: Refactoring warning instead of appending this [message #147766 is a reply to message #147577] Mon, 08 March 2004 11:15 Go to previous messageGo to next message
Originally posted by: eclipse-user.jibeinc.com
Igor Akkerman wrote:
> class MyClass {
> private int i;
> MyClass(int j) {
> i = j;
> class MyClass {
> private int j;
> MyClass(int j) {
> this.j = j;
I disagree. I think a warning is definitely appropriate. I guess if you
really are sure you want that, then it should go ahead and do it after
warning you, but I always try to avoid code where method arg names match
instance variable names exactly - it just makes it too easy to forget
the "this." somewhere and end up with a confusing bug.
Eric
Eric Rizzo
Software Architect
Jibe, Inc.
http://www.jibeinc.com
Re: Refactoring warning instead of appending this [message #147789 is a reply to message #147766] Mon, 08 March 2004 16:57 Go to previous messageGo to next message
>> Hi,
>> class MyClass {
>> private int i;
>> MyClass(int j) {
>> i = j;
>> class MyClass {
>> private int j;
>> MyClass(int j) {
>> this.j = j;
I agree that a warning is appropriate. But after warning me and after
I have accepted, it should definitely not produce the code it produces
now:
My Class(int j) {
j = j;
because this cannot be anything but an error.
You may call your method arguments differently, I would not like to do
this. By the way, AFAIK, it is a Java convention not to do so.
Igor
Re: Refactoring warning instead of appending this [message #147797 is a reply to message #147789] Mon, 08 March 2004 18:23 Go to previous messageGo to next message
Originally posted by: akiezun.to.reply.remove.whats.unneeded.mit.edu
> My Class(int j) {
> j = j;
and eclipse marks it as one if you set the compiler prefs appropriately!
a.
Re: Refactoring warning instead of appending this [message #147899 is a reply to message #147797] Tue, 09 March 2004 05:51 Go to previous message
Adam Kiezun <akiezun@to.reply.remove.whats.unneeded.mit.edu> wrote:
>> My Class(int j) {
>> j = j;
of course. And that's why the refactoring module should be aware of
not creating such code. Not even after a warning.
Igor
Previous Topic:Where should I look for the behavior you get for for templates
Next Topic:imports not recognized with source subdirectory
Current Time: Fri Jul 18 15:55:32 EDT 2025
Powered by FUDForum. Page generated in 0.09840 seconds
