Home » Modeling » EMF » CDO : Reflective or Dynamic feature delegation ?
CDO : Reflective or Dynamic feature delegation ? [message #1473764] Fri, 14 November 2014 17:43 Go to next message
After one day testing my app (multi-models with many eOpposite features) generated as CDO native - dynamic, I have the feeling, the behavior with EMF utility classes is closer to standard EMF generation.
The behaviors of reflective API : eSet, eGet and eIsSet (used in EcoreUtil.equals for instance ) relying on generated getters / setters seems to work better than when generating with featureDelegation set to Reflective.
Does anyone have some feedbacks about both generations Reflective / Dynamic in CDO context ?
Stéphane.
Re: CDO : Reflective or Dynamic feature delegation ? [message #1476666 is a reply to message #1473764] Mon, 17 November 2014 03:44 Go to previous messageGo to next message
> Reflective.
Better? Iirc, it doesn't work at all if you set it to dynamic.
I wanted the 'cdo team' of our product to switch to reflective
generation for a long time now so that I can close several application
bugs.. Anything that uses EMF reflection breaks when you use dynamic
feature delegation... (Unfortunately I'm not aware of the stuff that
might break when you switch to reflective generation, but I'm willing to
find out if I can close all existing bugs related to eGet/eSet/eIsSet
not working correctly in the cdo edition)
Felix
Re: CDO : Reflective or Dynamic feature delegation ? [message #1476676 is a reply to message #1476666] Mon, 17 November 2014 03:54 Go to previous messageGo to next message
On 17/11/2014 09:44, Felix Dorner wrote:
>> Reflective.
Sorry, more precisely, doesn't work at all as in "Your customized code
in getters/setters won't be used", most obviously the case for derived
features.
Re: CDO : Reflective or Dynamic feature delegation ? [message #1476757 is a reply to message #1476676] Mon, 17 November 2014 05:23 Go to previous messageGo to next message
Am 17.11.2014 um 09:54 schrieb Felix Dorner:
>> Hi,
>>> Reflective.
> Sorry, more precisely, doesn't work at all as in "Your customized code in getters/setters won't be used", most
> obviously the case for derived features.
I found a comment by Ed that clarifies this:
Reflective calls the generated accessors which call the dynamic
accessors whereas Dynamic the generated accessors call the reflective
accessors which call the dynamic accessors. The former is flexible if
you override the generated accessors, the latter are more efficient when
the reflective API is invoked directly, as is the case for most of the
framework's use of the instances.
Cheers
/Eike
http://www.esc-net.de
Re: CDO : Reflective or Dynamic feature delegation ? [message #1476937 is a reply to message #1476757] Mon, 17 November 2014 08:33 Go to previous messageGo to next message
If I use dynamic to benefit from more efficient reflective code, is
there a some other way to 'implement' derived features, so that the
result is computed somewhere in the 'dynamic' part?
Felix
>>> Hi,
>>>> Reflective.
>> features.
Re: CDO : Reflective or Dynamic feature delegation ? [message #1477034 is a reply to message #1476937] Mon, 17 November 2014 10:13 Go to previous messageGo to next message
Felix,
No doubt when all the levels of indirection involved in a CDO/Store
implementation, the performance difference is irrelevant. Measure it
before you worry about it.
> Felix
>>>> Hi,
>>>>> setters
>>>>> set to
>>>>> Reflective.
>>> features.
Re: CDO : Reflective or Dynamic feature delegation ? [message #1477082 is a reply to message #1477034] Mon, 17 November 2014 10:58 Go to previous messageGo to next message
Ciao,
On 17/11/2014 16:13, Ed Merks wrote:
> Felix,
Sorry, I asked wrongly. I don't worry nor measure (lucky me!). After
looking at the difference of the two generation patterns I'd be the
first to flip the switch without hesitation. I just wanted to know if
there are alternatives to implement derived features through some other
CDO-specific mechanism.
Felix
Re: CDO : Reflective or Dynamic feature delegation ? [message #1477820 is a reply to message #1477082] Tue, 18 November 2014 01:17 Go to previous message
Felix,
No, I don't believe CDO provides any other way to compute a derived
feature's value.
On 17/11/2014 4:58 PM, Felix Dorner wrote:
> Ciao,
>> Felix,
> other CDO-specific mechanism.
> Felix
Previous Topic:[oomph] adding new setup will not add git repositories to view
Next Topic:Rookie Q: How get StyledCellLabelProvider from EMF.edit
Current Time: Sat Jul 26 11:35:52 EDT 2025
Powered by FUDForum. Page generated in 0.09681 seconds
