Home » Archived » IMP » Eclipse 3.3.0 report
Eclipse 3.3.0 report [message #14616] Fri, 26 October 2007 10:50 Go to next message
Hi there,
I am a student very interested in IMP. I working on a small project for
ActionScript 2 and now 3 (ASDT) as a hobby.
"IMP doesn't quite work under Eclipse 3.3 as of yet. We .. encourage
people to pitch in by doing things like testing IMP under 3.3 and
submitting bug reports, if not submitting patches."
I think working in 3.3 saves lots of time because of Mylyn and I also
think its also a great tool too encourage community and participations (I
love the context and focus). So I try to identify some problems an maybe
some solutions.
I run Ubuntu 7.10 with java-6-sun-1.6.0.03 JVM and Eclipse 3.3.0 as a test
Platform with code from today's head rev. I also evaluated IMP with WinXP
on Eclipse 3.2.2. As long as there is no bugzilla component for IMP I just
put it here.
-- missing HTMLTextPresenter
org.eclipse.imp.editor.UniversalEditor uses
org.eclipse.jdt.internal.ui.text.HTMLTextPresenter that moved to
org.eclipse.jface.internal.text.html.HTMLTextPresenter but is not
accessible because of plugin package restrictions (internal..)
In this case one can easily add the HTMLTextPresenter and the four
required Readers to the IMP codebase (same license).
-- invalid thread access on start-up
That is very easy fixed by wrapping the language registration in a
Runnable executed by the default display in
org.eclipse.imp.runtime.RuntimePlugin.earlyStartup().
org.eclipse.swt.SWTException: Invalid thread access
at
org.eclipse.imp.language.LanguageRegistry.registerLanguages( LanguageRegistry.java:208)
at
org.eclipse.imp.runtime.RuntimePlugin.earlyStartup(RuntimePl ugin.java:78)
-- (minor) default key binding conflict with subversive
ALT+CTRL+R is set to org.eclipse.imp.xform.findReplace and
org.polarion.team.svn.ui.command.CompareWithRevisionCommand
-- getAllPlugins()
org.eclipse.pde.internal.core.PluginModelManager.getAllPlugi ns is missing.
however there is a method getAllModels() with the same return type. no
solution because of the next problem.
-- use of internal packages
org.eclipse.imp.metatooling (especially org.eclipse.imp.extensionsmodel)
are using classes in the package org.eclipse.pde.internal.core. The
problem is internal should not be used by others. Since 3.3 Eclipse
started to use OSGi enforced package restriction. That means if not
explicit exported, the package will be inaccessible from other plug-ins.
Maybe this can be resolved by using the corresponding public interfaces
and a custom implementation. But I stop right here for today, I obviously
cant test any of the wizards without the extensionsmodel working.
Best regards
Martin Schnabel
Re: Eclipse 3.3.0 report [message #14649 is a reply to message #14616] Mon, 29 October 2007 08:21 Go to previous messageGo to next message
Hi Martin,
Thanks a lot; this is extremely helpful! With this sort of assistance,
we'll be up on 3.3 in no time! :-)
Martin Schnabel wrote:
> Hi there,
> (I love the context and focus). So I try to identify some problems an
> maybe some solutions.
> test Platform with code from today's head rev. I also evaluated IMP with
> WinXP on Eclipse 3.2.2. As long as there is no bugzilla component for
> IMP I just put it here.
You're right. We'll probably just copy the code over as you suggest.
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
As you say, a trivial fix. Thanks for this one.
Yes, IIRC I put that binding in a long time ago to help while
testing the AST searching (which is still half-baked). We can
certainly remove this.
> -- getAllPlugins()
> missing. however there is a method getAllModels() with the same return
> type. no solution because of the next problem.
> obviously cant test any of the wizards without the extensionsmodel working.
Obviously we're aware of this one. We've been trying to avoid simply
copying the PDE's plugin/extension model code, which provides a higher-
level means of manipulating plugins, but the PDE doesn't provide enough
API yet. We'll see what we can do to remove the internal package
dependencies.
Thanks again!
-- Bob
Robert M. Fuhrer
Research Staff Member
Programming Technologies Dept.
IBM T.J. Watson Research Center
IMP Team Lead (http://eclipse-imp.sourceforge.net)
X10: Productivity for High-Performance Parallel Programming
(http://x10.sf.net)
Re: Eclipse 3.3.0 report [message #14771 is a reply to message #14649] Thu, 01 November 2007 15:59 Go to previous messageGo to next message
You're welcome.
> API yet.
You might need an overview where these internal packages are used and
what for. I looked through the projects and wrote a list.
*org.eclipse.imp.analysis*
org.eclipse.imp.analysis.type.constraints.fastrep.BindingKey uses
org.eclipse.jdt.internal.core.util.KeyKind and
org.eclipse.jdt.internal.core.util.KeyToSignature to parse binding keys.
Since it is basically a light utility parser for binding key signatures
its not hard to implement a new one without dependencies to org.eclipse.jdt.
*org.eclipse.imp.preference*
org.eclipse.imp.preferences.wizards.NewPreferencesDialogWiza rdPage and
org.eclipse.imp.preferences.wizards.NewPreferencesSpecificat ionWizardPage
have a method getSchema(), that returns the restricted type
org.eclipse.pde.internal.core.schema.Schema. However it is only checkt
whether the schema exists so the method could be changed to boolean
hasSchema () { return fSchema != null; }
*org.eclipse.imp.prefspecs*
org.eclipse.imp.prefspecs.compiler.PrefspecsCompiler uses
org.eclipse.pde.internal.core.bundle.WorkspaceBundleModel to parse the
manifest.mf files.
*org.eclipse.imp.runtime*
org.eclipse.imp.language.LanguageRegistry uses
org.eclipse.ui.internal.registry.EditorRegistry, the IEditorRegistry
does not let you change or save the mappings. related:
org.eclipse.ui.internal.registry.EditorDescriptor,
org.eclipse.ui.internal.registry.FileEditorMapping
org.eclipse.imp.editor.ProblemsLabelDecorator uses
org.eclipse.jdt.internal.ui.viewsupport.ImageDescriptorRegis try and
org.eclipse.jdt.internal.ui.JavaPluginImages. related:
org.eclipse.jdt.internal.ui.JavaPlugin and
org.eclipse.jdt.internal.ui.viewsupport.ImageImageDescriptor
org.eclipse.imp.preferences.ProjectPreferencesTab uses
org.eclipse.jdt.internal.ui.preferences.ProjectSelectionDial og and all
detail dialogs in org.eclipse.imp.preferences.fields.details extend
org.eclipse.ui.internal.dialogs.ProductInfoDialog.
org.eclipse.imp.preferences.AdaptedProjectSelectionDialog accesses
org.eclipse.jdt.internal.ui.JavaPlugin getDialogSettings().
org.eclipse.imp.wizards.NewProjectWizardFirstPage uses
org.eclipse.jdt.internal.ui.wizards.NewWizardMessages for text messages
and org.eclipse.jdt.internal.ui.preferences.NewJavaProjectPrefer encePage.
org.eclipse.imp.wizards.NewProjectWizardSecondPage uses
NewWizardMessages as well and
org.eclipse.jdt.internal.corext.util.JavaModelUtil,
org.eclipse.jdt.internal.ui.util.CoreUtility,
org.eclipse.jdt.internal.ui.wizards.ClassPathDetector for java project
configuration.
*minor*
org.eclipse.imp.java.outliner.JavaOutliner uses
org.eclipse.jdt.internal.ui.JavaPluginImages for jdt images.
org.eclipse.imp.lpg.wizards.NewLanguageSupportWizardPage has an used
import to a pdt internal package.
I hope it will help a bit. I think many of these dependencies can be
implemented very easy. The only thing that seems to be a problem is the
EditorRegistry.
Best regards
Martin Schnabel
Re: Eclipse 3.3.0 report [message #16703 is a reply to message #14771] Fri, 22 February 2008 22:22 Go to previous messageGo to next message
Originally posted by: psanampu.cisco.com
hi,
did anybody resolved these issues ? Does anybody have imp working with
eclipse 3.3 yet ?
thanks
Prasad
"Martin Schnabel" <mb0@mb0.org> wrote in message
news:fgdb6g$te4$1@build.eclipse.org...
> You're welcome.
>> API yet.
> You might need an overview where these internal packages are used and what
> org.eclipse.jdt.
> manifest.mf files.
> org.eclipse.ui.internal.registry.EditorRegistry, the IEditorRegistry does
> org.eclipse.imp.wizards.NewProjectWizardSecondPage uses NewWizardMessages
> as well and org.eclipse.jdt.internal.corext.util.JavaModelUtil,
> configuration.
> *minor*
> EditorRegistry.
> Best regards
> Martin Schnabel
Re: Eclipse 3.3.0 report [message #20056 is a reply to message #16703] Fri, 30 May 2008 17:14 Go to previous message
Yes, IMP is working with Eclipse 3.3 and also (we believe) with 3.4 M5.
If you have not yet, please see the post of 28 May. This includes the
latest "trunk" code in the IMP SVN repository on Eclipse.org--and the
latest release through the IMP update site on Eclipse.org.
Stan Sutton
prasad wrote:
> hi,
> eclipse 3.3 yet ?
> thanks
> Prasad
>> You're welcome.
>>> API yet.
>> org.eclipse.jdt.
>> manifest.mf files.
>> configuration.
>> *minor*
>> EditorRegistry.
>> Best regards
>> Martin Schnabel
Re: Eclipse 3.3.0 report [message #568663 is a reply to message #14616] Mon, 29 October 2007 08:21 Go to previous message
Hi Martin,
> Hi there,
> at
> at
> -- getAllPlugins()
dependencies.
Thanks again!
-- Bob
Robert M. Fuhrer
(http://x10.sf.net)
Re: Eclipse 3.3.0 report [message #568783 is a reply to message #14649] Thu, 01 November 2007 15:59 Go to previous message
You're welcome.
> API yet.
manifest.mf files.
configuration.
*minor*
EditorRegistry.
Best regards
Martin Schnabel
Re: Eclipse 3.3.0 report [message #569669 is a reply to message #14771] Fri, 22 February 2008 22:22 Go to previous message
hi,
eclipse 3.3 yet ?
thanks
Prasad
> You're welcome.
>> API yet.
> org.eclipse.jdt.
> manifest.mf files.
> configuration.
> *minor*
> EditorRegistry.
> Best regards
> Martin Schnabel
Re: Eclipse 3.3.0 report [message #570795 is a reply to message #16703] Fri, 30 May 2008 17:14 Go to previous message
Stan Sutton
prasad wrote:
> hi,
> eclipse 3.3 yet ?
> thanks
> Prasad
>> You're welcome.
>>> API yet.
>> org.eclipse.jdt.
>> manifest.mf files.
>> configuration.
>> *minor*
>> EditorRegistry.
>> Best regards
>> Martin Schnabel
Previous Topic:BNF input
Next Topic:Update site - not updated?
Current Time: Wed Nov 05 19:04:50 EST 2025
Powered by FUDForum. Page generated in 0.04709 seconds
