Home » Eclipse Projects » Remote Application Platform (RAP) » Client Error with 3.0 M3
Client Error with 3.0 M3 [message #1476969] |
Mon, 17 November 2014 09:04  |
since RAP 3.0 M3 (the same application was working fine with M2) sometime the application crash with client error. It does not seems to be related to browser as crash occurs with firefox and chrome.
It seems also to be related to workbench, I have not yet experienced this issue in RWT applications
I am currently investigating this issue to understand what could cause this. In the meantime, the client error stack is :
Error: TypeError: element.appendChild is not a function
Script: {"head":{"requestCounter":1},"operations":[["set","w1",{"exitConfirmation":"Vous êtes sur le point de quitter cette application. Tous les changements non sauvegardés seront perdus."}],["create","w2","rwt.widgets.Shell",{"style":["NO_TRIM"]}],["listen","w2",{"Move":true,"Resize":true,"Activate":true,"Close":true}],["set","w2",{"active":true,"mode":"maximized","minimumSize":[30,0],"activeControl":"w8","bounds":[0,0,1855,985],"children":["w8","w11","w14","w15","w16","w19","w20","w23"],"tabIndex":-1,"visibility":true}],["listen","w2",{"Help":true}],["create","w88","rwt.widgets.Menu",{"parent":"w2","style":["BAR"],"bounds":[0,0,1855,20]}],["create","w89","rwt.widgets.MenuItem",{"parent":"w88","style":["CASCADE"],"index":0,"text":"Fichier","menu":"w90"}],["create","w91","rwt.widgets.MenuItem",{"parent":"w88","style":["CASCADE"],"index":1,"text":"Édition","menu":"w92"}],["create","w93","rwt.widgets.MenuItem",{"parent":"w88","style":["CASCADE"],"index":2,"text":"Gérer","menu":"w94"}],["create","w95","rwt.widgets.MenuItem",{"parent":"w88","style":["CASCADE"],"index":3,"text":"Fenêtre","menu":"w96"}],["create","w97","rwt.widgets.MenuItem",{"parent":"w88","style":["CASCADE"],"index":4,"text":"Aide","menu":"w98"}],["create","w90","rwt.widgets.Menu",{"parent":"w2","style":["DROP_DOWN"]}],["listen","w90",{"Show":true,"Hide":true}],["create","w92","rwt.widgets.Menu",{"parent":"w2","style":["DROP_DOWN"]}],["listen","w92",{"Show":true,"Hide":true}],["create","w94","rwt.widgets.Menu",{"parent":"w2","style":["DROP_DOWN"]}],["listen","w94",{"Show":true,"Hide":true}],["create","w96","rwt.widgets.Menu",{"parent":"w2","style":["DROP_DOWN"]}],["listen","w96",{"Show":true,"Hide":true}],["create","w98","rwt.widgets.Menu",{"parent":"w2","style":["DROP_DOWN"]}],["listen","w98",{"Show":true,"Hide":true}],["create","w8","rwt.widgets.Composite",{"parent":"w2","style":["NONE"],"bounds":[2,22,900,22],"children":["w99","w9"],"tabIndex":1,"clientArea":[0,0,0,0]}],["create","w99","rwt.widgets.Sash",{"parent":"w8","style":["VERTICAL"],"bounds":[0,0,0,0],"tabIndex":-1,"visibility":false}],["listen","w99",{"Selection":true}],["create","w9","rwt.widgets.Composite",{"parent":"w8","style":["NONE"],"bounds":[0,0,900,22],"children":["w7"],"tabIndex":-1,"clientArea":[0,0,900,22]}],["create","w7","rwt.widgets.CoolBar",{"parent":"w9","style":["FLAT","HORIZONTAL"],"bounds":[0,0,900,22],"children":["w3","w6"],"tabIndex":-1}],["create","w100","rwt.widgets.CoolItem",{"parent":"w7","style":["DROP_DOWN"],"bounds":[0,0,900,22],"control":"w3"}],["create","w3","rwt.widgets.ToolBar",{"parent":"w7","style":["FLAT","HORIZONTAL"],"bounds":[10,0,890,22],"children":[],"tabIndex":4}],["listen","w3",{"MenuDetect":true}],["create","w101","rwt.widgets.ToolItem",{"parent":"w3","style":["DROP_DOWN"],"index":0,"bounds":[0,0,40,22],"toolTip":"Nouveau...","image":["rwt-resources/generated/f6b616da.gif",16,16]}],["listen","w101",{"Selection":true}],["create","w102","rwt.widgets.ToolItem",{"parent":"w3","style":["PUSH"],"index":1,"bounds":[40,0,24,22],"enabled":false,"toolTip":"Sauvegarder le contenu en cours (accès direct par Ctrl+S)","image":["rwt-resources/generated/57340c0d.gif",16,16]}],["listen","w102",{"Selection":true}],["create","w103","rwt.widgets.ToolItem",{"parent":"w3","style":["PUSH"],"index":2,"bounds":[64,0,24,22],"enabled":false,"toolTip":"Sauvegarder tout le contenu en cours (accès direct par Ctrl+Maj+S)","image":["rwt-resources/generated/f4c69100.gif",16,16]}],["listen","w103",{"Selection":true}],["create","w104","rwt.widgets.ToolItem",{"parent":"w3","style":["DROP_DOWN"],"index":3,"bounds":[88,0,40,22],"toolTip":"Ouvrir...","image":["rwt-resources/generated/d8b8e87b.gif",16,16]}],["listen","w104",{"Selection":true}],["create","w6","rwt.widgets.ToolBar",{"parent":"w7","style":["FLAT","HORIZONTAL"],"bounds":[-17,0,25,22],"children":[],"tabIndex":-1,"visibility":false,"background":[255,255,255,255]}],["create","w105","rwt.widgets.ToolItem",{"parent":"w6","style":["PUSH"],"index":0,"bounds":[0,0,16,22],"image":["rwt-resources/generated/4e7aad48.gif",8,16]}],["listen","w105",{"Selection":true}],["create","w11","rwt.widgets.Composite",{"parent":"w2","style":["NONE"],"bounds":[0,0,0,0],"children":["w12","w10","w84"],"tabIndex":5,"visibility":false,"clientArea":[0,0,0,0]}],["create","w12","rwt.widgets.Label",{"parent":"w11","style":["NONE"],"appearance":"clabel","bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"foreground":[74,74,74,255],"text":""}],["create","w10","rwt.widgets.ToolBar",{"parent":"w11","style":["FLAT","HORIZONTAL"],"bounds":[0,0,0,0],"children":[],"tabIndex":7,"visibility":false}],["create","w106","rwt.widgets.ToolItem",{"parent":"w10","style":["PUSH"],"index":0,"bounds":[0,0,24,22],"toolTip":"Annulation de l'opération en cours","visible":false,"image":["rwt-resources/generated/cb52ad0b.gif",16,16]}],["listen","w106",{"Selection":true}],["create","w84","rwt.widgets.Composite",{"parent":"w11","style":["NONE"],"bounds":[0,0,0,0],"children":["w87"],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w87","rwt.widgets.Composite",{"parent":"w84","style":["NONE"],"bounds":[0,0,0,0],"children":["w85","w86"],"tabIndex":9,"visibility":false,"clientArea":[0,0,0,0]}],["create","w85","rwt.widgets.ProgressBar",{"parent":"w87","style":["HORIZONTAL"],"bounds":[0,0,0,0],"tabIndex":-1,"visibility":false}],["create","w86","rwt.widgets.ProgressBar",{"parent":"w87","style":["HORIZONTAL","INDETERMINATE"],"bounds":[0,0,0,0],"tabIndex":-1,"visibility":false}],["create","w14","rwt.widgets.Composite",{"parent":"w2","style":["NONE"],"bounds":[0,0,32,22],"children":["w13"],"tabIndex":10,"toolTip":"Afficher sous forme de vue rapide","visibility":false}],["listen","w14",{"MenuDetect":true}],["set","w14",{"clientArea":[0,0,32,22]}],["create","w13","rwt.widgets.ToolBar",{"parent":"w14","style":["FLAT","HORIZONTAL"],"bounds":[0,0,32,22],"children":[],"tabIndex":11}],["listen","w13",{"MenuDetect":true}],["create","w15","rwt.widgets.Composite",{"parent":"w2","style":["NONE"],"bounds":[4,46,1847,935],"children":["w83"],"tabIndex":-1,"clientArea":[0,0,1847,935]}],["create","w83","rwt.widgets.Composite",{"parent":"w15","style":["NONE"],"bounds":[0,0,1847,935],"children":["w107","w40","w27","w82"],"tabIndex":-1,"clientArea":[0,0,1847,935]}],["create","w107","rwt.widgets.ToolBar",{"parent":"w83","style":["FLAT","HORIZONTAL"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false}],["listen","w107",{"Activate":true,"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["create","w40","rwt.widgets.Composite",{"parent":"w83","style":["NONE"],"bounds":[3,26,1841,906],"children":["w66"],"tabIndex":-1}],["listen","w40",{"Activate":true}],["set","w40",{"clientArea":[0,0,1841,906]}],["create","w66","rwt.widgets.Composite",{"parent":"w40","style":["NONE"],"bounds":[0,0,1841,906],"children":["w79"],"tabIndex":-1,"clientArea":[0,0,1841,906]}],["create","w79","rwt.widgets.Composite",{"parent":"w66","style":["NONE"],"bounds":[5,5,1831,896],"children":["w54","w61","w62","w78"],"tabIndex":-1,"background":[255,255,255,255]}],["listen","w79",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w79",{"clientArea":[0,0,1831,896]}],["create","w54","rwt.widgets.Canvas",{"parent":"w79","style":["NONE"]}],["create","w54.gc","rwt.widgets.GC",{"parent":"w54"}],["set","w54",{"bounds":[5,5,908,409],"children":["w67","w68"],"tabIndex":-1,"foreground":[74,74,74,255],"background":[255,255,255,255],"font":[["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,true,false],"backgroundGradient":[[[229,242,248,255],[255,255,255,255],[255,255,255,255]],[0,5,100],true],"roundedBorder":[1,[255,255,255,255],8,8,0,0],"clientArea":[0,0,908,409]}],["create","w67","rwt.widgets.Label",{"parent":"w54","style":["WRAP"],"bounds":[6,3,88,16],"tabIndex":-1,"foreground":[0,88,159,255],"background":[0,0,0,0],"font":[["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,true,false]}],["listen","w67",{"KeyDown":true}],["set","w67",{"text":"Modélisation"}],["create","w68","rwt.widgets.Composite",{"parent":"w54","style":["NONE"],"bounds":[6,25,896,384],"children":["w55","w56","w57","w58","w59","w60"],"tabIndex":-1,"background":[255,255,255,255]}],["listen","w68",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w68",{"clientArea":[0,0,896,384]}],["create","w55","forms.widgets.Hyperlink",{"parent":"w68","style":["NONE"],"bounds":[2,2,254,66],"children":[],"tabIndex":-1,"foreground":[0,0,128,255],"background":[255,255,255,255]}],["listen","w55",{"FocusIn":true,"FocusOut":true,"MouseDown":true,"KeyDown":true}],["set","w55",{"text":"Ouvrir Édition de Modèle...","underlined":true,"underlineMode":3,"activeForeground":[0,0,255,255]}],["listen","w55",{"DefaultSelection":true}],["set","w55",{"image":["rwt-resources/generated/f70ee12e.gif",64,64]}],["create","w56","forms.widgets.Hyperlink",{"parent":"w68","style":["NONE"],"bounds":[2,73,219,18],"children":[],"tabIndex":-1,"foreground":[0,0,128,255],"background":[255,255,255,255]}],["listen","w56",{"FocusIn":true,"FocusOut":true,"MouseDown":true,"KeyDown":true}],["set","w56",{"text":"CustomerAndFinancialMDM [0.1]","underlined":true,"underlineMode":3,"activeForeground":[0,0,255,255]}],["listen","w56",{"DefaultSelection":true}],["set","w56",{"image":["rwt-resources/generated/2a1c7600.png",16,16]}],["create","w57","forms.widgets.Hyperlink",{"parent":"w68","style":["NONE"],"bounds":[2,96,219,18],"children":[],"tabIndex":-1,"foreground":[0,0,128,255],"background":[255,255,255,255]}],["listen","w57",{"FocusIn":true,"FocusOut":true,"MouseDown":true,"KeyDown":true}],["set","w57",{"text":"CustomerAndFinancialMDM [0.0]","underlined":true,"underlineMode":3,"activeForeground":[0,0,255,255]}],["listen","w57",{"DefaultSelection":true}],["set","w57",{"image":["rwt-resources/generated/af53fa9b.png",16,16]}],["create","w58","forms.widgets.Hyperlink",{"parent":"w68","style":["NONE"],"bounds":[2,119,193,18],"children":[],"tabIndex":-1,"foreground":[0,0,128,255],"background":[255,255,255,255]}],["listen","w58",{"FocusIn":true,"FocusOut":true,"MouseDown":true,"KeyDown":true}],["set","w58",{"text":"SellerCatalogModel2 [0.1]","underlined":true,"underlineMode":3,"activeForeground":[0,0,255,255]}],["listen","w58",{"DefaultSelection":true}],["set","w58",{"image":["rwt-resources/generated/2a1c7600.png",16,16]}],["create","w59","forms.widgets.Hyperlink",{"parent":"w68","style":["NONE"],"bounds":[2,142,193,18],"children":[],"tabIndex":-1,"foreground":[0,0,128,255],"background":[255,255,255,255]}],["listen","w59",{"FocusIn":true,"FocusOut":true,"MouseDown":true,"KeyDown":true}],["set","w59",{"text":"SellerCatalogModel2 [0.0]","underlined":true,"underlineMode":3,"activeForeground":[0,0,255,255]}],["listen","w59",{"DefaultSelection":true}],["set","w59",{"image":["rwt-resources/generated/af53fa9b.png",16,16]}],["create","w60","forms.widgets.Hyperlink",{"parent":"w68","style":["NONE"],"bounds":[2,165,186,18],"children":[],"tabIndex":-1,"foreground":[0,0,128,255],"background":[255,255,255,255]}],["listen","w60",{"FocusIn":true,"FocusOut":true,"MouseDown":true,"KeyDown":true}],["set","w60",{"text":"SellerCatalogModel [0.0]","underlined":true,"underlineMode":3,"activeForeground":[0,0,255,255]}],["listen","w60",{"DefaultSelection":true}],["set","w60",{"image":["rwt-resources/generated/af53fa9b.png",16,16]}],["create","w61","rwt.widgets.Canvas",{"parent":"w79","style":["NONE"]}],["create","w61.gc","rwt.widgets.GC",{"parent":"w61"}],["set","w61",{"bounds":[918,5,908,409],"children":["w69","w70"],"tabIndex":-1,"foreground":[74,74,74,255],"background":[255,255,255,255],"font":[["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,true,false],"backgroundGradient":[[[229,242,248,255],[255,255,255,255],[255,255,255,255]],[0,5,100],true],"roundedBorder":[1,[255,255,255,255],8,8,0,0],"clientArea":[0,0,908,409]}],["create","w69","rwt.widgets.Label",{"parent":"w61","style":["WRAP"],"bounds":[6,3,155,16],"tabIndex":-1,"foreground":[0,88,159,255],"background":[0,0,0,0],"font":[["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,true,false]}],["listen","w69",{"KeyDown":true}],["set","w69",{"text":"Intendance de Données"}],["create","w70","rwt.widgets.Composite",{"parent":"w61","style":["NONE"],"bounds":[6,25,896,384],"children":["w71","w72","w73","w74","w75"],"tabIndex":-1,"background":[255,255,255,255]}],["listen","w70",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w70",{"clientArea":[0,0,896,384]}],["create","w71","rwt.widgets.Label",{"parent":"w70","style":["NONE"],"bounds":[2,2,64,64],"tabIndex":-1,"background":[0,0,0,0],"image":["rwt-resources/generated/43765a52.gif",64,64]}],["create","w72","rwt.widgets.Label",{"parent":"w70","style":["NONE"],"markupEnabled":true,"bounds":[71,26,188,16],"tabIndex":-1,"background":[0,0,0,0],"text":"Ouvrir Édition de Données..."}],["create","w73","rwt.widgets.Label",{"parent":"w70","style":["NONE"],"appearance":"clabel","markupEnabled":true,"bounds":[2,71,369,16],"children":[],"tabIndex":-1,"background":[0,0,0,0],"text":"DemoApplication [Courante] (CustomerAndFinancialMDM)","image":["rwt-resources/generated/d7c7b690.png",16,16]}],["create","w74","rwt.widgets.Label",{"parent":"w70","style":["NONE"],"appearance":"clabel","markupEnabled":true,"bounds":[2,92,369,16],"children":[],"tabIndex":-1,"background":[0,0,0,0],"text":"DemoApplication [0.0] (CustomerAndFinancialMDM)","image":["rwt-resources/generated/88ce8a5e.png",16,16]}],["create","w75","rwt.widgets.Label",{"parent":"w70","style":["NONE"],"appearance":"clabel","markupEnabled":true,"bounds":[2,113,369,16],"children":[],"tabIndex":-1,"background":[0,0,0,0],"text":"HR [Courante] (Corporate)","image":["rwt-resources/generated/d7c7b690.png",16,16]}],["create","w62","rwt.widgets.Canvas",{"parent":"w79","style":["NONE"]}],["create","w62.gc","rwt.widgets.GC",{"parent":"w62"}],["set","w62",{"bounds":[5,419,908,437],"children":["w76","w77"],"tabIndex":-1,"foreground":[74,74,74,255],"background":[255,255,255,255],"font":[["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,true,false],"backgroundGradient":[[[229,242,248,255],[255,255,255,255],[255,255,255,255]],[0,5,100],true],"roundedBorder":[1,[255,255,255,255],8,8,0,0],"clientArea":[0,0,908,437]}],["create","w76","rwt.widgets.Label",{"parent":"w62","style":["WRAP"],"bounds":[6,3,103,16],"tabIndex":-1,"foreground":[0,88,159,255],"background":[0,0,0,0],"font":[["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,true,false]}],["listen","w76",{"KeyDown":true}],["set","w76",{"text":"Administration"}],["create","w77","rwt.widgets.Composite",{"parent":"w62","style":["NONE"],"bounds":[6,25,896,412],"children":["w63","w64","w65"],"tabIndex":-1,"background":[255,255,255,255]}],["listen","w77",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w77",{"clientArea":[0,0,896,412]}],["create","w63","forms.widgets.Hyperlink",{"parent":"w77","style":["NONE"],"bounds":[2,2,261,66],"children":[],"tabIndex":-1,"foreground":[0,0,128,255],"background":[255,255,255,255]}],["listen","w63",{"FocusIn":true,"FocusOut":true,"MouseDown":true,"KeyDown":true}],["set","w63",{"text":"Gérer Éditions de Modèles...","underlined":true,"underlineMode":3,"activeForeground":[0,0,255,255]}],["listen","w63",{"DefaultSelection":true}],["set","w63",{"image":["rwt-resources/generated/b67d066c.gif",64,64]}],["create","w64","forms.widgets.Hyperlink",{"parent":"w77","style":["NONE"],"bounds":[2,73,287,66],"children":[],"tabIndex":-1,"foreground":[0,0,128,255],"background":[255,255,255,255]}],["listen","w64",{"FocusIn":true,"FocusOut":true,"MouseDown":true,"KeyDown":true}],["set","w64",{"text":"Gérer Emplacements de Données...","underlined":true,"underlineMode":3,"activeForeground":[0,0,255,255]}],["listen","w64",{"DefaultSelection":true}],["set","w64",{"image":["rwt-resources/generated/31962b3f.gif",64,64]}],["create","w65","forms.widgets.Hyperlink",{"parent":"w77","style":["NONE"],"bounds":[2,144,254,66],"children":[],"tabIndex":-1,"foreground":[0,0,128,255],"background":[255,255,255,255]}],["listen","w65",{"FocusIn":true,"FocusOut":true,"MouseDown":true,"KeyDown":true}],["set","w65",{"text":"Console d'Administration...","underlined":true,"underlineMode":3,"activeForeground":[0,0,255,255]}],["listen","w65",{"DefaultSelection":true}],["set","w65",{"image":["rwt-resources/generated/2f16132.gif",64,64]}],["create","w78","rwt.widgets.Label",{"parent":"w79","style":["NONE"],"bounds":[5,861,1821,30],"tabIndex":-1,"foreground":[74,74,74,255],"background":[255,255,255,255],"image":["rwt-resources/generated/a9138cfe.png",406,30],"alignment":"right"}],["create","w27","rwt.widgets.Composite",{"parent":"w83","style":["NONE"],"bounds":[0,0,0,0],"children":["w26"],"tabIndex":-1,"visibility":false,"enabled":false,"clientArea":[0,0,0,0]}],["create","w108","rwt.widgets.DropTarget",{"control":"w27","style":["DROP_COPY","DROP_LINK"]}],["create","w26","rwt.widgets.CTabFolder",{"parent":"w27","style":["MULTI","BORDER"],"toolTipTexts":["Réduire","Agrandir","Restaurer","Afficher la liste","Fermer"]}],["listen","w26",{"Selection":true,"Folder":true}],["set","w26",{"bounds":[0,0,0,0],"children":["w25","w109","w110","w24"],"tabIndex":-1,"visibility":false,"font":[["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false]}],["listen","w26",{"Activate":true,"MenuDetect":true}],["set","w26",{"tabHeight":22,"minimizeBounds":[-39,2,18,18],"minimizeVisible":true,"maximizeBounds":[-21,2,18,18],"maximizeVisible":true,"selectionBackground":[255,255,255,255],"selectionForeground":[74,74,74,255],"selectionBackgroundGradient":[[[255,255,255,255],[255,255,255,255]],[0,100],true],"borderVisible":true}],["listen","w26",{"DefaultSelection":true}],["create","w25","rwt.widgets.ToolBar",{"parent":"w26","style":["FLAT","HORIZONTAL"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false}],["create","w111","rwt.widgets.ToolItem",{"parent":"w25","style":["PUSH"],"index":0,"bounds":[0,0,19,22],"toolTip":"Menu","visible":false,"image":["rwt-resources/generated/90970f9f.gif",11,16]}],["listen","w111",{"Selection":true}],["create","w109","rwt.widgets.Label",{"parent":"w26","style":["NONE"],"bounds":[0,0,0,0],"tabIndex":-1,"visibility":false}],["listen","w109",{"Activate":true,"MenuDetect":true}],["create","w110","rwt.widgets.Composite",{"parent":"w26","style":["NONE"],"bounds":[4,1,0,22],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,22]}],["create","w24","rwt.widgets.Composite",{"parent":"w26","style":["NONE"],"bounds":[0,0,0,0],"children":["w112","w113","w114","w115","w116"],"tabIndex":-1,"visibility":false}],["listen","w24",{"Activate":true,"MenuDetect":true}],["set","w24",{"clientArea":[0,0,0,0]}],["create","w112","rwt.widgets.Composite",{"parent":"w24","style":["NONE"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w113","rwt.widgets.Composite",{"parent":"w24","style":["NONE"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w114","rwt.widgets.Composite",{"parent":"w24","style":["NONE"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w115","rwt.widgets.Composite",{"parent":"w24","style":["NONE"],"bounds":[-200,-200,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w116","rwt.widgets.Composite",{"parent":"w24","style":["NONE"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w82","rwt.widgets.CTabFolder",{"parent":"w83","style":["MULTI","BORDER"],"toolTipTexts":["Réduire","Agrandir","Restaurer","Afficher la liste","Fermer"]}],["listen","w82",{"Selection":true,"Folder":true}],["set","w82",{"bounds":[0,0,1847,935],"children":["w81","w117","w118","w80"],"tabIndex":-1,"font":[["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false]}],["listen","w82",{"Activate":true,"FocusIn":true,"FocusOut":true,"MenuDetect":true}],["set","w82",{"tabHeight":22,"unselectedCloseVisible":false,"selection":"w119","selectionBackground":[76,166,210,255],"selectionForeground":[0,0,0,255],"selectionBackgroundGradient":[[[210,232,243,255],[76,166,210,255]],[0,75],true],"borderVisible":true}],["listen","w82",{"DefaultSelection":true}],["create","w119","rwt.widgets.CTabItem",{"parent":"w82","index":0,"style":["NONE"],"bounds":[0,0,122,23],"text":"Page d'Accueil","image":["rwt-resources/generated/88d6cef4.gif",16,16]}],["create","w81","rwt.widgets.ToolBar",{"parent":"w82","style":["FLAT","HORIZONTAL"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false}],["create","w120","rwt.widgets.ToolItem",{"parent":"w81","style":["PUSH"],"index":0,"bounds":[0,0,19,22],"toolTip":"Menu","visible":false,"image":["rwt-resources/generated/90970f9f.gif",11,16]}],["listen","w120",{"Selection":true}],["create","w117","rwt.widgets.Label",{"parent":"w82","style":["NONE"],"bounds":[0,0,0,0],"tabIndex":-1,"visibility":false}],["listen","w117",{"Activate":true,"MenuDetect":true}],["create","w118","rwt.widgets.Composite",{"parent":"w82","style":["NONE"],"bounds":[122,1,1721,22],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,1721,22]}],["create","w80","rwt.widgets.Composite",{"parent":"w82","style":["NONE"],"bounds":[3,26,1841,906],"children":["w121","w122","w123","w124","w125"],"tabIndex":-1}],["listen","w80",{"Activate":true,"MenuDetect":true}],["set","w80",{"clientArea":[0,0,1841,906]}],["create","w121","rwt.widgets.Composite",{"parent":"w80","style":["NONE"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w122","rwt.widgets.Composite",{"parent":"w80","style":["NONE"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w123","rwt.widgets.Composite",{"parent":"w80","style":["NONE"],"bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w124","rwt.widgets.Composite",{"parent":"w80","style":["NONE"],"bounds":[-200,-200,0,0],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w125","rwt.widgets.Composite",{"parent":"w80","style":["NONE"],"bounds":[0,0,1841,906],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,1841,906]}],["create","w16","rwt.widgets.ToolBar",{"parent":"w2","style":["FLAT","HORIZONTAL"],"bounds":[914,22,851,22],"children":[],"tabIndex":14}],["create","w126","rwt.widgets.ToolItem",{"parent":"w16","style":["RADIO"],"index":0,"bounds":[0,0,122,22],"toolTip":"Page d'Accueil","text":"Page d'Accueil","image":["rwt-resources/generated/88d6cef4.gif",16,16],"selection":true}],["listen","w126",{"Selection":true}],["create","w127","rwt.widgets.ToolItem",{"parent":"w16","style":["RADIO"],"index":1,"bounds":[122,0,162,22],"toolTip":"Modélisation Logique","text":"Modélisation Logique","image":["rwt-resources/generated/a7111c4b.gif",16,16]}],["listen","w127",{"Selection":true}],["create","w128","rwt.widgets.ToolItem",{"parent":"w16","style":["RADIO"],"index":2,"bounds":[284,0,196,22],"toolTip":"Administration de Modèles","text":"Administration de Modèles","image":["rwt-resources/generated/eceda51f.gif",16,16]}],["listen","w128",{"Selection":true}],["create","w129","rwt.widgets.ToolItem",{"parent":"w16","style":["RADIO"],"index":3,"bounds":[480,0,182,22],"toolTip":"Emplacements de Données","text":"Emplacements de Données","image":["rwt-resources/generated/633c3b4f.gif",16,16]}],["listen","w129",{"Selection":true}],["create","w130","rwt.widgets.ToolItem",{"parent":"w16","style":["RADIO"],"index":4,"bounds":[662,0,189,22],"toolTip":"Console d'Administration","text":"Console d'Administration","image":["rwt-resources/generated/7cfdb2e7.gif",16,16]}],["listen","w130",{"Selection":true}],["create","w19","rwt.widgets.Composite",{"parent":"w2","style":["NONE"],"bounds":[904,22,10,22],"children":["w131"],"tabIndex":15,"cursor":"move","clientArea":[0,0,10,22]}],["create","w131","rwt.widgets.CoolBar",{"parent":"w19","style":["FLAT","HORIZONTAL"],"bounds":[0,0,10,22],"children":["w132"],"tabIndex":-1}],["create","w133","rwt.widgets.CoolItem",{"parent":"w131","style":["NONE"],"bounds":[0,0,10,22],"control":"w132"}],["create","w132","rwt.widgets.Composite",{"parent":"w131","style":["NONE"],"bounds":[10,0,0,22],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,22]}],["create","w20","rwt.widgets.ToolBar",{"parent":"w2","style":["FLAT","HORIZONTAL"],"bounds":[1777,22,78,22],"children":[],"tabIndex":18}],["create","w134","rwt.widgets.ToolItem",{"parent":"w20","style":["DROP_DOWN"],"index":0,"bounds":[0,0,78,22],"toolTip":"semadmin","text":"semadmin"}],["listen","w134",{"Selection":true}],["create","w23","rwt.widgets.Composite",{"parent":"w2","style":["NONE"],"bounds":[1767,22,10,22],"children":["w135"],"tabIndex":19,"cursor":"move","clientArea":[0,0,10,22]}],["create","w135","rwt.widgets.CoolBar",{"parent":"w23","style":["FLAT","HORIZONTAL"],"bounds":[0,0,10,22],"children":["w136"],"tabIndex":-1}],["create","w137","rwt.widgets.CoolItem",{"parent":"w135","style":["NONE"],"bounds":[0,0,10,22],"control":"w136"}],["create","w136","rwt.widgets.Composite",{"parent":"w135","style":["NONE"],"bounds":[10,0,0,22],"children":[],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,22]}],["set","w1",{"focusControl":"w8","activeKeys":["ALT+#39","ALT+SHIFT+#112","ALT+SHIFT+#113","CTRL+#45","CTRL+SHIFT+#106","ALT+#34","SHIFT+#45","CTRL+#69","CTRL+#32","ALT+#37","CTRL+,","CTRL+.","CTRL+#89","CTRL+#90","ALT+#13","CTRL+#80","#113","CTRL+SHIFT+#83","CTRL+-","CTRL+#78","CTRL+#87","CTRL+#115","CTRL+SHIFT+#87","CTRL+SHIFT+#115","ALT+#118","ALT+SHIFT+#118","CTRL+SHIFT+#111","CTRL+SHIFT+#119","CTRL+#119","CTRL+SHIFT+#118","CTRL+#118","CTRL+SHIFT+#117","CTRL+#117","CTRL+#77","#123","CTRL+#121","ALT+-","CTRL+#83","CTRL+=","CTRL+SHIFT+#70","ALT+SHIFT+#81","SHIFT+#46","CTRL+#70","CTRL+SHIFT+#69","CTRL+SHIFT+#32","ALT+#33"],"cancelKeys":["ALT+#39","ALT+SHIFT+#112","ALT+SHIFT+#113","CTRL+#45","CTRL+SHIFT+#106","ALT+#34","SHIFT+#45","CTRL+#69","CTRL+#32","ALT+#37","CTRL+,","CTRL+.","CTRL+#89","CTRL+#90","ALT+#13","CTRL+#80","#113","CTRL+SHIFT+#83","CTRL+-","CTRL+#78","CTRL+#87","CTRL+#115","CTRL+SHIFT+#87","CTRL+SHIFT+#115","ALT+#118","ALT+SHIFT+#118","CTRL+SHIFT+#111","CTRL+SHIFT+#119","CTRL+#119","CTRL+SHIFT+#118","CTRL+#118","CTRL+SHIFT+#117","CTRL+#117","CTRL+#77","#123","CTRL+#121","ALT+-","CTRL+#83","CTRL+=","CTRL+SHIFT+#70","ALT+SHIFT+#81","SHIFT+#46","CTRL+#70","CTRL+SHIFT+#69","CTRL+SHIFT+#32","ALT+#33"]}],["call","rwt.client.TextSizeMeasurement","measureItems",{"items":[["t-1526665780","CustomerAndFinancialMDM [0.0]",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,false],["t1445257855","Administration",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,true,false,-1,false],["t1440610937","DemoApplication [0.0] (CustomerAndFinancialMDM)",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,true],["t2146254751","Page d'Accueil",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,false],["t450753384","SellerCatalogModel2 [0.1]",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,false],["t715484205","Intendance de Données",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,true,false,5,false],["t-2047647027","Gérer Éditions de Modèles...",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,false],["t-1307826326","HR [Courante] (Corporate)",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,true],["t-1526635989","CustomerAndFinancialMDM [0.1]",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,false],["t1445258041","Administration",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,true,false,5,false],["t-770295449","Modélisation",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,true,false,-1,false],["t-591952714","Emplacements de Données",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,false],["t450723593","SellerCatalogModel2 [0.0]",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,false],["t-1371857926","Gérer Emplacements de Données...",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,false],["t-770295263","Modélisation",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,true,false,5,false],["t-1888409943","Console d'Administration",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,false],["t386764949","SellerCatalogModel [0.0]",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,false],["t1212647030","Administration de Modèles",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,false],["t-1851236817","P",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,false],["t715484019","Intendance de Données",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,true,false,-1,false],["t-2141837573","Ouvrir Édition de Données...",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,true],["t-996715341","semadmin",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,false],["t-1538871423","Modélisation Logique",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,false],["t-66182922","DemoApplication [Courante] (CustomerAndFinancialMDM)",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,true],["t1159880644","Console d'Administration...",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,false],["t-492073629","Ouvrir Édition de Modèle...",["Tahoma","Segoe UI","Calibri","Lucida Sans Unicode","sans-serif","Corbel"],11,false,false,-1,false]]}]]}
Stack: append_element@http://localhost:10080/semarchy/rwt-resources/rap-client.js:8265:1
$.prototype.init/this.__access@http://localhost:10080/semarchy/rwt-resources/rap-client.js:7924:14
$.prototype.append@http://localhost:10080/semarchy/rwt-resources/rap-client.js:7954:12
.members.__setCellNode@http://localhost:10080/semarchy/rwt-resources/rap-client.js:42274:9
.members._createSubElements@http://localhost:10080/semarchy/rwt-resources/rap-client.js:42135:1
.members._applyElement@http://localhost:10080/semarchy/rwt-resources/rap-client.js:42117:9
anonymous@http://localhost:10080/semarchy/rwt-resources/rap-client.js line 2499 > Function:1:590
.members._createElementImpl@http://localhost:10080/semarchy/rwt-resources/rap-client.js:10255:7
.statics.flushGlobalElementQueue@http://localhost:10080/semarchy/rwt-resources/rap-client.js:8592:11
.statics.flushGlobalQueues@http://localhost:10080/semarchy/rwt-resources/rap-client.js:8529:7
.members._handleSuccess/<@http://localhost:10080/semarchy/rwt-resources/rap-client.js:62176:11
rwt.remote.MessageProcessor.processMessage@http://localhost:10080/semarchy/rwt-resources/rap-client.js:61491:7
.members._handleSuccess@http://localhost:10080/semarchy/rwt-resources/rap-client.js:62174:9
rwt.remote.Request.prototype.setSuccessHandler/this._success@http://localhost:10080/semarchy/rwt-resources/rap-client.js:31439:35
rwt.remote.Request.prototype._onReadyStateChange@http://localhost:10080/semarchy/rwt-resources/rap-client.js:31490:13
.bind/<@http://localhost:10080/semarchy/rwt-resources/rap-client.js:624:14
Debug: on
Request: {"head":{"rwt_initialize":true},"operations":[["set","w1",{"bounds":[0,0,1855,985],"dpi":[96,96],"colorDepth":32}],["set","rwt.client.ClientInfo",{"timezoneOffset":-60}],["call","rwt.client.TextSizeMeasurement","storeMeasurements",{"results":{"p-1629471069":[590,14],"p-1629471070":[648,14],"p538441445":[672,16],"p538440932":[599,14],"p538438885":[952,24],"p538440933":[578,14]}}],["set","w1",{"cursorLocation":[156,288]}]]}
Phase: 3
Current Time: Mon Jul 21 08:20:46 EDT 2025
Powered by FUDForum. Page generated in 0.06040 seconds
