Home » Modeling » Compare » Eclipse editor with my designer(Eclipse plugin editor that will open with my own designer)
Eclipse editor with my designer [message #1474099] Sat, 15 November 2014 00:34 Go to next message
Hi , i need an editor like the XML editor that have source/view option.
The source will be the same the view will implement my own designer.
Tried to take the example of the new plugin editor , but how to continue from there ?.
Re: Eclipse editor with my designer [message #1476762 is a reply to message #1474099] Mon, 17 November 2014 05:26 Go to previous message
Please post your question on the Newcomers sub-forum. This is the EMF Compare section, which deals with comparing EMF models. You might also want to lookup tutorials on the wiki.
Laurent Goubet
Obeo
Previous Topic:Compare Result of compare editor without the UI
Next Topic:ProximityEObject matcher - tell the matcher that the objects are NOT equal
Current Time: Fri Jul 25 00:49:20 EDT 2025
Powered by FUDForum. Page generated in 0.04139 seconds
