Load EMF model instance from XMI file [message #1474463] |
Sat, 15 November 2014 07:43  |
I know there are several QnA about this subject. I have tried lots of solution, I am always getting same error. What I want to do is in my project to read elements and try to find EAttributes and their values, which EClass they belong. EReferences also.
Can you plesea show me a way and a method to traverse xmi file ?
My code structure is like:
Resource.Factory.Registry reg = Resource.Factory.Registry.INSTANCE;
Map<String, Object> m = reg.getExtensionToFactoryMap();
m.put("xmi", new XMIResourceFactoryImpl());
ResourceSet resSet = new ResourceSetImpl();
Resource resource = resSet.getResource(URI.createURI("model/List.xmi"), true);
resource.load(Collections.EMPTY_MAP);
EObject root = resource.getContents().get(0);
Error:
Quote:Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'List' not found. (file:///C:/Users/2/My%20Repository/UNIT%20Research%20and%20Development/com.unitbilisim.research.transformation/model/List.xmi, 6, 40) at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319) at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278) at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406) at com.unitbilisim.research.transformation.ConvertEcore2Graph.main(ConvertEcore2Graph.java:61) Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'List' not found. (file:///C:/Users/2/My%20Repository/UNIT%20Research%20and%20Development/com.unitbilisim.research.transformation/model/List.xmi, 6, 40) at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(XMLHandler.java:2625) at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefix(XMLHandler.java:2458) at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1335) at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1504) at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1026) at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:77) at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1008) at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:719) at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:163) at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source) at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.startElement(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$ContentDriver.scanRootElementHook(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source) at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source) at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source) at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175) at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261) at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518) at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297) at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259) at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274) ... 2 more
What does 'package with uri "" not found' mean ? Can I read xmi file directly or do I need to parse it as xml file ?
I have also tried this:
XMIResource resource = new XMIResourceImpl(URI.createURI("model/List.xmi"));
resource.load(null);
System.out.println( resource.getContents().get(0) );
PackageNotFoundEx. and Reource$IOWrappedEx. again :(
Please help
kind regards
Re: Load EMF model instance from XMI file [message #1474570 is a reply to message #1474463] |
Sat, 15 November 2014 09:35   |
Furkan,
Comments below.
> Resource resource =
You're trying to do this stand alone? Invoke the Generate Test Code and
look for XyzExample.java in the *.tests project.
> Error:
> Quote:
>> 'List' not found.
>> 6, 40) at
>> at
>> at
>> at
>> 6, 40) at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> at
>> at
>> at
>> at
>> at
>> ... 2 more
That means your xmi file is expecting there to be a registered model,
i.e., an EPackage with that value as the nsURI.
XMI is XML. To make any sense of it, you'd need the registered model as
you parse it.
Where did this XMI come from? Note that I've always telling people not
to use a relative URI to load a resource.
> Please help
> kind regards
Re: Load EMF model instance from XMI file [message #1474710 is a reply to message #1474696] |
Sat, 15 November 2014 12:20  |
What kind of environment are you wanting to run in? Just stand alone,
or are you building an Eclipse application? What's you goal? In any
case, try generating a model and looking at the example. That will
answer many of your questions...
On 15/11/2014 6:06 PM, furkan tanrıverdi wrote:
> I generated it as dynamic instance from ecore model. It's in my model
> folder with *.ecore file.
> So, what do you suggest load ?
> Sorry for my lack of knowledge but I have been working with EMF just
> for 2 or 3 weeks :(
FUDForum. Page generated in 0.05377 seconds
