Home » Archived » BIRT » _format=pdf
_format=pdf [message #146965] Wed, 22 March 2006 08:02 Go to next message
Originally posted by: almasalki.hotmail.com
hi for all
when i use the following url
( http://192.168.1.83:1500/Reports/preview?__report=HotelRepor ts/new_report.rptdesign&__format=pdf)
or
( http://192.168.1.83:1500/Reports/frameset?__report=HotelRepo rts/new_report.rptdesign&__format=pdf)
to generate the report as pdf ,the servlet viewer display the report as
html in the first case and ignore the _format=pdf.
also the servlet viewer display the report as html in the second case and
ignore the _format=pdf,consider that I put the iText.jar in its place.
please can you help me
thanks in advance
Re: _format=pdf [message #147023 is a reply to message #146965] Wed, 22 March 2006 09:33 Go to previous messageGo to next message
Try the run viewer.
http://192.168.1.83:1500/Reports/run?__report=HotelReports/n ew_report.rptdesign&__format=pdf
CDias
Abo Alnnor wrote:
> hi for all
> or
> and ignore the _format=pdf,consider that I put the iText.jar in its place.
> thanks in advance
Re: _format=pdf [message #147318 is a reply to message #147023] Thu, 23 March 2006 04:07 Go to previous messageGo to next message
sorry nothing changed
I try run and frameset and preview,I guess the problem in the iText
version(1.3 or 1.4)or may be in the JDK version(1.4,1.5)
other thing to help me
Re: _format=pdf [message #147332 is a reply to message #147318] Thu, 23 March 2006 04:58 Go to previous messageGo to next message
Originally posted by: sp_res.rediffmail.com
Check the itext.jar size ~ 1 Mb or not. If not download latest.
Also check whether ur URL using __format=pdf(Double underscore before
format) or not.
regards,
SP
Re: _format=pdf [message #147425 is a reply to message #147332] Thu, 23 March 2006 08:39 Go to previous messageGo to next message
The size of iText=1.23 MB
and I put (__)before format term in the url, but there is nothing changed
and the report still display as html
please more help
thanks in advance
Re: _format=pdf [message #147702 is a reply to message #147425] Thu, 23 March 2006 23:19 Go to previous messageGo to next message
Originally posted by: marshal_liu.yahoo.com.cn
I've met the same problem as u got. This is c'z u use the 1.4 version of
itext.jar. Just download one 1.3 version of the file and replace it in the
deployment environment. It should works:-)
Re: _format=pdf [message #148019 is a reply to message #147702] Sat, 25 March 2006 03:09 Go to previous message
I still use itest1.4 and all thing work good when i call the default
example such as test.rptdesign and i can see it as pdf.
but when i build my private report by connection to database,and deploy
this report on tomcat,and call it by using preview? or frameset? it is
work as usually,but when I use run? to see it as pdf,I can see part of
report as pdf example(I see the columns name of report without data or
chart).
can you help me thanks
Previous Topic:Can someone of BIRT team take care plaes?
Next Topic:Import problem in Birt Chart engine
Current Time: Wed Jul 23 06:07:15 EDT 2025
Powered by FUDForum. Page generated in 0.28952 seconds
