Home » Archived » Eclipse Communications Framework (ECF) » How to setup o.e.ecf.examples.raspberrypi.* on the pi
How to setup o.e.ecf.examples.raspberrypi.* on the pi [message #1472399] Thu, 13 November 2014 16:13 Go to next message
Hello
I am trying to run the example org.eclipse.ecf.examples.raspberrypi.management on a raspberry pi following this tutorial. After starting the programm the error: "Cannot assign requested address" is thrown repeatedly.
I'm using the ip address of my pi (192.168.1.121) as the host name and I have checked that the port 3288 is not used before. After the startup I can see the port 3288 listening, but I can't find the pi in the Service Discovery view.
In the OSGi log I can see ch.ethz.iks.slp trying to connect to 127.0.1.1. Any pointers on why this might fail and what I can do about it are greatly appriciated!
Versions:
- Equinox Target Components 3.10.0
- ECF OSGi Remote Services SDK 3.9.0
with dependencies
working in Luna RC1
pi@pi01 ~/ecf_raspi_sample $ sudo ./rpimgmthost.sh 192.168.1.121
Hostname: 192.168.1.121
Port: 3288
javaprops=-Decf.generic.server.hostname=192.168.1.121 -Decf.generic.server.port=3288 -Dch.ethz.iks.slp.debug=true -Declipse.ignoreApp=true -Dosgi.noShutdown=true
equinox=plugins/org.eclipse.osgi_3.10.1.v20140909-1633.jar
Debug options:
    file:/home/pi/ecf_raspi_sample/.options not found
Time to load bundles: 5643
20:45:46.796 DEBUG ch.ethz.iks.slp - jSLP OSGi started.
20:45:46.807 DEBUG ch.ethz.iks.slp - ServiceEvent REGISTERED [S:{ch.ethz.iks.slp.Advertiser}={service.id=68, service.bundleid=25, service.scope=bundle}]
20:45:46.831 DEBUG ch.ethz.iks.slp - ServiceEvent REGISTERED [S:{ch.ethz.iks.slp.Locator}={service.id=69, service.bundleid=25, service.scope=bundle}]
20:45:46.852 DEBUG ch.ethz.iks.slp - BundleEvent STARTED
20:45:48.505 DEBUG ch.ethz.iks.slp - jSLP is running on the following interfaces: [127.0.1.1]
20:45:48.519 DEBUG ch.ethz.iks.slp - jSLP is using port: 427
20:45:49.220 WARN  ch.ethz.iks.slp - Error connecting to: 127.0.1.1
java.net.BindException: Cannot assign requested address
        at java.net.PlainDatagramSocketImpl.bind0(Native Method) ~[na:1.8.0]
        at java.net.AbstractPlainDatagramSocketImpl.bind(AbstractPlainDatagramSocketImpl.java:93) ~[na:1.8.0]
        at java.net.DatagramSocket.bind(DatagramSocket.java:371) ~[na:1.8.0]
        at java.net.DatagramSocket.<init>(DatagramSocket.java:222) ~[na:1.8.0]
        at java.net.DatagramSocket.<init>(DatagramSocket.java:279) ~[na:1.8.0]
        at ch.ethz.iks.slp.impl.SLPCore.daLookup(SLPCore.java:611) ~[na:na]
        at ch.ethz.iks.slp.impl.SLPCore.init(SLPCore.java:321) ~[na:na]
        at ch.ethz.iks.slp.impl.Activator$2.getService(Activator.java:51) ~[na:na]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) ~[org.eclipse.osgi_3.10.1.v20140909-1633.jar:na]
        at java.security.AccessController.doPrivileged(Native Method) ~[na:1.8.0]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) ~[org.eclipse.osgi_3.10.1.v20140909-1633.jar:na]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[org.eclipse.osgi_3.10.1.v20140909-1633.jar:na]
        at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[org.eclipse.osgi_3.10.1.v20140909-1633.jar:na]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) ~[org.eclipse.osgi_3.10.1.v20140909-1633.jar:na]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[org.eclipse.osgi_3.10.1.v20140909-1633.jar:na]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) ~[org.eclipse.osgi_3.10.1.v20140909-1633.jar:na]
        at org.osgi.util.tracker.ServiceTracker.addingService(ServiceTracker.java:414) ~[org.eclipse.osgi_3.10.1.v20140909-1633.jar:na]
        at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[org.eclipse.osgi_3.10.1.v20140909-1633.jar:na]
        at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1) ~[org.eclipse.osgi_3.10.1.v20140909-1633.jar:na]
        at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[org.eclipse.osgi_3.10.1.v20140909-1633.jar:na]
        at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183) ~[org.eclipse.osgi_3.10.1.v20140909-1633.jar:na]
        at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:318) ~[org.eclipse.osgi_3.10.1.v20140909-1633.jar:na]
        at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261) ~[org.eclipse.osgi_3.10.1.v20140909-1633.jar:na]
        at org.eclipse.ecf.internal.provider.jslp.Activator.getLocator(Activator.java:64) ~[na:na]
        at org.eclipse.ecf.internal.provider.jslp.JSLPDiscoveryJob.run(JSLPDiscoveryJob.java:43) ~[na:na]
        at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) ~[na:na]
20:45:49.433 ERROR ch.ethz.iks.slp - Exception in initial DA lookup
ch.ethz.iks.slp.ServiceLocationException: Cannot assign requested address
        at ch.ethz.iks.slp.impl.SLPCore.daLookup(SLPCore.java:645) ~[na:na]
20:45:49.449 DEBUG ch.ethz.iks.slp - DAS FOR SCOPE default: null
Thanks!
Christoph
Re: How to setup o.e.ecf.examples.raspberrypi.* on the pi [message #1473040 is a reply to message #1472399] Fri, 14 November 2014 04:36 Go to previous messageGo to next message
> at
> ~[na:1.8.0]
> ~[na:1.8.0]
> ~[na:1.8.0]
> ~[na:na]
> at
Hi Christoph,
try adding -net.slp.interfaces=192.168.1.121 to the list of java
properties to make jSLP bind to this (external) interface.
HTH
Markus
Re: How to setup o.e.ecf.examples.raspberrypi.* on the pi [message #1473626 is a reply to message #1473040] Fri, 14 November 2014 15:02 Go to previous messageGo to next message
Hi Markus
thanks for your input! That gets me one step further, but I still get an exception during start up and I still see 127.0.1.1 in the middle of it.
19:43:37.780 [de.kware.osgi.logging.OsgiLogListener@1577674] DEBUG ch.ethz.iks.slp - jSLP is running on the following interfaces: [192.168.1.121]
19:43:37.891 [de.kware.osgi.logging.OsgiLogListener@1577674] DEBUG ch.ethz.iks.slp - jSLP is using port: 427
19:43:38.023 [de.kware.osgi.logging.OsgiLogListener@1577674] DEBUG ch.ethz.iks.slp - DAS FOR SCOPE default: null
19:43:48.527 [de.kware.osgi.logging.OsgiLogListener@1577674] DEBUG ch.ethz.iks.slp - jSLP daemon starting ...
19:43:48.531 [de.kware.osgi.logging.OsgiLogListener@1577674] DEBUG ch.ethz.iks.slp - ServiceDisposalThread sleeping ...
19:43:53.671 [de.kware.osgi.logging.OsgiLogListener@1577674] ERROR ch.ethz.iks.slp - Exception during sending of SRVREG - xid=12298, locale=en_GB, url: service:ecfosgirsvc://ecfosgirsvc://127.0.1.1:32565/osgirsvc_pLfQg8JNIbH5hv4vnyLGnx3IWRA=, serviceType: service:ecfosgirsvc, scopeList: [default], attList: [(ecf.generic.server.hostname=192.168.1.121), (endpoint.service.id=83), (ecf.endpoint.ts=1415994219699), (endpoint.package.version.org.eclipse.ecf.examples.raspberrypi.management=1.0.0), (remote.intents.supported=passByValue exactlyOnce ordered), (ecf.exported.async.interfaces=*), (ecf.rsvc.id=1), (ecf.generic.server.port=3288), (x-28392-SERVICEIDNAME=\FF\62\33\4e\6e\61\58\4a\7a\64\6d\4e\66\63\45\78\6d\55\57\63\34\53\6b\35\4a\59\6b\67\31\61\48\59\30\64\6d\35\35\54\45\64\75\65\44\4e\4a\56\31\4a\42\50\51\3d\3d), (x-28392-PRIORITY=0), (objectClass=org.eclipse.ecf.examples.raspberrypi.management.IRaspberryPi), (remote.configs.supported=ecf.generic.server), (endpoint.framework.uuid=f0c0507f-366c-0014-1229-a389ab0dafb2), (service.imported.configs=ecf.generic.server), (x-28392-WEIGHT=0), (ecf.endpoint.id.ns=org.eclipse.ecf.core.identity.StringID), (ecf.endpoint.id=ecftcp://192.168.1.121:3288/server), (endpoint.id=e8e8a09d-03f4-45f5-8092-4a73d1f95ac0)]
19:43:53.698 [de.kware.osgi.logging.OsgiLogListener@1577674] ERROR ch.ethz.iks.slp - to pi01/127.0.1.1:427
19:43:54.190 [de.kware.osgi.logging.OsgiLogListener@1577674] ERROR ch.ethz.iks.slp - Exception:
java.net.SocketTimeoutException: Receive timed out
	at java.net.PlainDatagramSocketImpl.receive0(Native Method) ~[na:1.8.0]
	at java.net.AbstractPlainDatagramSocketImpl.receive(AbstractPlainDatagramSocketImpl.java:143) ~[na:1.8.0]
	at java.net.DatagramSocket.receive(DatagramSocket.java:781) ~[na:1.8.0]
	at ch.ethz.iks.slp.impl.SLPCore.sendMessage(SLPCore.java:725) ~[na:na]
19:43:54.543 [de.kware.osgi.logging.OsgiLogListener@1577674] ERROR org.eclipse.ecf.discovery - FrameworkEvent ERROR
org.eclipse.ecf.core.util.ECFRuntimeException: Receive timed out
	at org.eclipse.ecf.provider.jslp.container.JSLPDiscoveryContainer.registerService(JSLPDiscoveryContainer.java:190) ~[na:na]
	at org.eclipse.ecf.internal.discovery.IServiceInfoServiceListener$1.addingService(IServiceInfoServiceListener.java:39) ~[na:na]
Caused by: ch.ethz.iks.slp.ServiceLocationException: Receive timed out
	at ch.ethz.iks.slp.impl.SLPCore.sendMessage(SLPCore.java:743) ~[na:na]
	at ch.ethz.iks.slp.impl.AdvertiserImpl.register(AdvertiserImpl.java:121) ~[na:na]
	at org.eclipse.ecf.provider.jslp.container.JSLPDiscoveryContainer.registerService(JSLPDiscoveryContainer.java:187) ~[na:na]
And I still don't see the pi in the Service Discovery view.
Any ideas what else I could try?
Smile
Christoph
Re: How to setup o.e.ecf.examples.raspberrypi.* on the pi [message #1474388 is a reply to message #1473626] Sat, 15 November 2014 06:10 Go to previous messageGo to next message
Hi Christoph,
what is the content of /etc/hosts and the output of ifconfig on the Pi?
M.
Re: How to setup o.e.ecf.examples.raspberrypi.* on the pi [message #1474534 is a reply to message #1474388] Sat, 15 November 2014 08:58 Go to previous messageGo to next message
Te pi01 says that it is on interface 127... You also have to add the property on the remote end.
Wim
Re: How to setup o.e.ecf.examples.raspberrypi.* on the pi [message #1477106 is a reply to message #1474534] Mon, 17 November 2014 11:24 Go to previous messageGo to next message
Hi Markus, hi Wim,
thanks for your replies! The weekend has been busy, but now I'm eager to get this working.
@Wim: Thanks for your inspirational talk at ECE in Ludwigsburg! Your presentation was the reason I wanted to try this stuff myself Smile
I don't know what you mean with "add the property on the remote end". I compared my script to the start script of your pipolos and it looks like you're basically doing the same thing, in the sense that i'm also setting net.slp.interfaces and ecf.generic.server.hostname when I start the server on the pi.
I get the feeling that my issue is probably not connected to ECF but has more to do with the setup of the pi itself. I admit that I am not very komfortable with linux yet.
ifconfig
eth0      Link encap:Ethernet  HWaddr b8:27:eb:ab:28:b9
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
wlan0     Link encap:Ethernet  HWaddr 00:0d:81:ae:df:05
          inet addr:192.168.1.121  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:1317 errors:0 dropped:607 overruns:0 frame:0
          TX packets:220 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:391016 (381.8 KiB)  TX bytes:28622 (27.9 KiB)
I've also tried this with lan (eth0) which uses the ip 192.168.1.120 with the same result. The ip is provided by a dhcp server which reserves 192.168.1.121 for pi01 over wlan0.
/etc/hosts
127.0.0.1       localhost
::1             localhost ip6-localhost ip6-loopback
fe00::0         ip6-localnet
ff00::0         ip6-mcastprefix
ff02::1         ip6-allnodes
ff02::2         ip6-allrouters
127.0.1.1       pi01
I tried to change the last line to "192.168.1.121 pi01" which leads to
16:15:43.322 ERROR ch.ethz.iks.slp - Exception during sending of SRVREG - xid=23438, locale=en_GB, url: service:ecfosgirsvc://ecfosgirsvc://192.168.1.121:32565/osgirsvc_MF/pJaj+VOw71ZqWCthAHXHogLw=, serviceType: service:ecfosgirsvc, scopeList: [default], attList: [(ecf.generic.server.hostname=192.168.1.121), (endpoint.service.id=83), (ecf.endpoint.ts=1416240935602), (endpoint.package.version.org.eclipse.ecf.examples.raspberrypi.management=1.0.0), (remote.intents.supported=passByValue exactlyOnce ordered), (ecf.exported.async.interfaces=*), (ecf.rsvc.id=1), (ecf.generic.server.port=3288), (x-28392-SERVICEIDNAME=\FF\62\33\4e\6e\61\58\4a\7a\64\6d\4e\66\54\55\59\76\63\45\70\68\61\69\74\57\54\33\63\33\4d\56\70\78\56\30\4e\30\61\45\46\49\57\45\68\76\5a\30\78\33\50\51\3d\3d), (x-28392-PRIORITY=0), (objectClass=org.eclipse.ecf.examples.raspberrypi.management.IRaspberryPi), (remote.configs.supported=ecf.generic.server), (endpoint.framework.uuid=404bd8eb-746e-0014-185e-e526cf180d47), (service.imported.configs=ecf.generic.server), (x-28392-WEIGHT=0), (ecf.endpoint.id.ns=org.eclipse.ecf.core.identity.StringID), (ecf.endpoint.id=ecftcp://192.168.1.121:3288/server), (endpoint.id=03f6ccef-743e-4417-98dc-63acb17f8896)]
16:15:43.326 ERROR ch.ethz.iks.slp - to pi01/192.168.1.121:427
16:15:43.825 ERROR ch.ethz.iks.slp - Exception:
Christoph
Re: How to setup o.e.ecf.examples.raspberrypi.* on the pi [message #1478726 is a reply to message #1477106] Tue, 18 November 2014 18:09 Go to previous messageGo to next message
Ok. I've finally got it working! The problem was the missing loopback network interface lo which needed to be configured.
As a reference to others: The output of ifconfig should also include someting like this:
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:4089 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4089 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:210891 (205.9 KiB)  TX bytes:210891 (205.9 KiB)
Re: How to setup o.e.ecf.examples.raspberrypi.* on the pi [message #1479334 is a reply to message #1478726] Wed, 19 November 2014 05:51 Go to previous messageGo to next message
> someting like this:
Hi Christoph,
thanks for the follow up. Without a loopback interface, SLP cannot
detect a locally running Directory Agent [1].
What Raspberry Pi image are you running? It would be good to know if it
has no loopback interface by default.
M.
[1] http://en.wikipedia.org/wiki/Service_Location_Protocol#SLP_roles
Re: How to setup o.e.ecf.examples.raspberrypi.* on the pi [message #1479362 is a reply to message #1479334] Wed, 19 November 2014 06:18 Go to previous messageGo to next message
Eclipse User wrote on Wed, 19 November 2014 11:51
I messed this up myself when I configured the wlan connection Embarrassed . The default is fine.
Re: How to setup o.e.ecf.examples.raspberrypi.* on the pi [message #1481283 is a reply to message #1479362] Thu, 20 November 2014 17:46 Go to previous messageGo to next message
Cool! and thank you for your compliments.
Are you also running the egg interface? Please note that out of the box pipolos uses a slightly newer version of the raspberry pi examples. In addition, pipolos uses JmDNS and not slp for discovery.
The egg interface can be found here: https://github.com/wimjongman/eggclient
Please note that you also need to supply the java properties:
-Decf.generic.server.hostname=192.168.1.33
-Dnet.mdns.interface=192.168.1.33 // (without the "j") to tell jmdns which network to use
-Dadmin=true // activates the cooking pin
See egg.ini for details.
Re: How to setup o.e.ecf.examples.raspberrypi.* on the pi [message #1483613 is a reply to message #1481283] Sat, 22 November 2014 14:46 Go to previous message
Wim Jongman wrote on Thu, 20 November 2014 23:46
I'll get around to the client after I've played with the basics for a while. I managed to run Scotts original GPIO example today. The next thing I will do is try your enhancements.
Out of curiosity: Why did you choose JmDNS over SLP for pipolos? They seem rather similar and both target LANs?
Previous Topic:ECF 3.9.1 Released
Next Topic:Which bundles need to be started to enable remote service discovery?
Current Time: Wed Oct 29 18:02:22 EDT 2025
Powered by FUDForum. Page generated in 0.04522 seconds
