Home » Eclipse Projects » Virgo » Update Virgo with org.eclipse.osgi_3.9.1
Update Virgo with org.eclipse.osgi_3.9.1 [message #1472720] Thu, 13 November 2014 22:37 Go to next message
I noticed that Virgo 3.6.3 is still using the old org.eclipse.osgi_3.8.2.v20130124-134944.jar.
Is it possible to use org.eclipse.osgi_3.9.1.v20130814-1242.jar instead?
The reason is that 3.9.1 fixes an Equinox bug that affect bundle deployment and that I filed last year (ConcurrentModificationException in org.eclipse.osgi.internal.resolver.StateWriter.writeList, see https://bugs.eclipse.org/bugs/show_bug.cgi?id=411718)
What is the process for updating the org.eclipse.osgi component in Virgo?
Thanks.
Re: Update Virgo with org.eclipse.osgi_3.9.1 [message #1473050 is a reply to message #1472720] Fri, 14 November 2014 04:48 Go to previous messageGo to next message
In the long run we want to Support generic container based Equinox implementation (Bug 404390).
Tom Watson from the Equinox team offered a possible short term alternative which might have less impact than updating to 3.9.1 or newer:
[quote]
Also having Virgo updated to use one of the other non-deprecated writeState methods would fix the issue. [1]
[\quote]
If you solely care about the Bug you mentioned I suggest you open a bug to replace the deprecated method call(s) in Virgo to work around the
Equinox bug.
[1] http://dev.eclipse.org/mhonarc/lists/equinox-dev/msg07575.html
[Updated on: Fri, 14 November 2014 04:49] by Moderator
Re: Update Virgo with org.eclipse.osgi_3.9.1 [message #1473455 is a reply to message #1473050] Fri, 14 November 2014 11:48 Go to previous message
OK, thanks for the quick reply. I will file a bug.
Previous Topic:Virgo, Java 8, Blueprint/Spring 4.x, Tooling
Next Topic:how to update logback version in virgo?
Current Time: Mon Jul 21 03:48:52 EDT 2025
Powered by FUDForum. Page generated in 1.57951 seconds
