Home » Eclipse Projects » Nebula » Radio Group / Listener(add Listener to radio group to change color in another field)
Radio Group / Listener [message #1471734] Thu, 13 November 2014 04:48 Go to next message
I created a radio group with 2 buttons (Yes/No)
Now depending which button is selected a field needs to change color.
I tried the following Listener (full code attached):
      tropicamideGroup.addListener(SWT.Selection, new Listener()
         public void handleEvent(Event event)
            switch (tropicamideGroup.getSelectionIndex())
               case 0:
                  txtAuthorized.setBackground(SWTResourceManager.getColor(60, 179, 113));
                  txtAuthorized.setText("\r\nAuthorized");
                  break;
               case 1:
                  txtAuthorized.setBackground(SWTResourceManager.getColor(SWT.COLOR_DARK_RED));
                  txtAuthorized.setText("\r\nNot Authorized");
                  break;
            // recreateAndLayout();
I tried also this version:
      tropicamideGroup.addSelectionListener(new SelectionAdapter()
         public void widgetSelected(SelectionEvent e)
            RadioItem[] radioItems = tropicamideGroup.getItems();
            if (radioItems[0].equals(e.item))
            if (radioItems[1].equals(e.item))
none of them changes the color
what do i do wrong?
  • Attachment: PpmsForm.java
    (Size: 64.96KB, Downloaded 397 times)
Re: Radio Group / Listener [message #1471888 is a reply to message #1471734] Thu, 13 November 2014 07:23 Go to previous messageGo to next message
Hi Charlie,
Please provide a running snippet with only the minimum code that exposes your problem and I will take a look. I have to do too much work to make your sample code work.
For examples on snippets see http://www.eclipse.org/nebula/snippets.php
Wim
Re: Radio Group / Listener [message #1472558 is a reply to message #1471888] Thu, 13 November 2014 19:16 Go to previous messageGo to next message
Hi Wim
Thx for the reply. I actually took the listener from the radio example code.
I am currently not at the development machine, but on monday i will put a small dialog with a main() and only the radio group and the text up here for you to have a look at it.
Re: Radio Group / Listener [message #1473124 is a reply to message #1472558] Fri, 14 November 2014 05:59 Go to previous messageGo to next message
Great Thanks!
Re: Radio Group / Listener [message #1476402 is a reply to message #1473124] Sun, 16 November 2014 22:33 Go to previous messageGo to next message
Morning Wim
Looks like it works in this demo.
It seems that when using the quick test, the does not use the listener
I add the short test also for others who might be interested in the solution.
Sort of a snippet..
Re: Radio Group / Listener [message #1482120 is a reply to message #1476402] Fri, 21 November 2014 09:02 Go to previous message
Cool. Well done.
Previous Topic:TableCombo with autocomplete
Next Topic:Trace Type SOLID_LANE join all points
Current Time: Sat Nov 22 22:29:57 EST 2025
Powered by FUDForum. Page generated in 0.04150 seconds
