Home » Language IDEs » Java Development Tools (JDT) » Uncomment command
Uncomment command [message #147163] Wed, 03 March 2004 09:25 Go to next message
I recently switched to M7 and was disappointed to see that comment/uncomment
had been removed from the default keymap and replaced with toggle comment.
So I tried to map comment to ctrl+/ and uncomment to ctrl+shift+/. The
comment works fine. I cannot get uncomment to work. When I add the mapping
for ctrl+shift+/ for uncomment in the "general" context, I remove the
default mapping for "Add block comment" in the "editing java" context.
Any ideas?
Re: Uncomment command [message #147217 is a reply to message #147163] Wed, 03 March 2004 21:40 Go to previous messageGo to next message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
Hi Ernest. I'm not sure why that didn't work but try defining Ctrl-/ and
Ctrl-\. . I did that for the Java editing context and it works fine. If
there's not a bugzilla request to bring back these original keydefs you
might want to enter one.
Ed Burnette
"Ernest Pasour" <Ernest.Pasour@sas.com> wrote in message
news:c24pm4$d51$1@eclipse.org...
comment/uncomment
mapping
> Any ideas?
Re: Uncomment command [message #147266 is a reply to message #147217] Thu, 04 March 2004 09:03 Go to previous messageGo to next message
I filed a defect for the keymapping problem.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=53735
"Ed Burnette" <ed.burnette@REMOVE.THIS.sas.com> wrote in message
news:c264oi$4km$1@eclipse.org...
> Ed Burnette
> comment/uncomment
comment.
> mapping
> > Any ideas?
Re: Uncomment command [message #147365 is a reply to message #147163] Thu, 04 March 2004 18:08 Go to previous messageGo to next message
I'm not sure whether I should post it here or open a bug report, but I
really don't like the new comment
method. Usually I select a block of code and want to comment it out.
Placing */ on the *next* line makes the code to look ugly.
Can anybody comment on why the old method was abandoned?
Genady
>Any ideas?
Genady Beryozkin
http://www.genady.net/
Re: Uncomment command [message #147429 is a reply to message #147365] Fri, 05 March 2004 04:56 Go to previous message
What old method? I don't really see what you mean, can you post an example?
You can still use "Toggle Comment" to toggle line comments ("//"). The
"comment" and "uncomment" commands are still available, but not bound in
the default config. And there is "add block comment" which will add "/*"
and "*/" around your selection. Nothing changed there.
-tom
(PS. I guess some keybindings were switched on GTK)
Previous Topic:How do I add an already checked out CVS repository to my project?
Next Topic:Import question
Current Time: Sun Jun 08 10:53:31 EDT 2025
Powered by FUDForum. Page generated in 0.07290 seconds
