Home » Modeling » EMF » [CDO] MemStore with file-based backend
[CDO] MemStore with file-based backend [message #1461193] Tue, 04 November 2014 04:51 Go to next message
I would like to know if CDO provides out-of-the-box an equivalent store to the MemStore with a file-based persistence as XML or binary ?
Stéphane.
Re: [CDO] MemStore with file-based backend [message #1461214 is a reply to message #1461193] Tue, 04 November 2014 05:24 Go to previous messageGo to next message
Am 04.11.2014 um 10:51 schrieb Stephane Fournier:
> as XML or binary ?
No, it doesn't. Several people (including myself) have tried this but in the end the different locking granularity of
files (i.e. different from single EObjects) makes it not so trivial as it might seem at a first glance.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] MemStore with file-based backend [message #1461254 is a reply to message #1461214] Tue, 04 November 2014 06:24 Go to previous messageGo to next message
Do you assume that Stephane wants each commit to be persisted to the file or does Stephane want to "dump" the contents (of the repository) of the MEMStore to a file and restore from it after a restart?
Eike Stepper wrote on Tue, 04 November 2014 11:24
> as XML or binary ?
Cheers
/Eike
Re: [CDO] MemStore with file-based backend [message #1461324 is a reply to message #1461254] Tue, 04 November 2014 07:49 Go to previous messageGo to next message
Am 04.11.2014 um 12:24 schrieb Erdal Karaca:
The former, but I may be wrong ;-)
Cheers
/Eike
>> > Hi,
>> persistence > as XML or binary ?
>> Cheers
>> /Eike
>> http://thegordian.blogspot.com
>> http://twitter.com/eikestepper
Re: [CDO] MemStore with file-based backend [message #1463475 is a reply to message #1461324] Thu, 06 November 2014 10:52 Go to previous messageGo to next message
Indeed, my need was not cristal clear Smile
Hence, my needs are both :
1) make a dump of a MemStore as files (XML content would be perfect as EMF serialisation does,) every XX minutes. I found out CDOCommandProvider that provides an ExportCommand, but I don't know how to call it from CDO views ? Is it possible ? Do you have an example how to use this command ?
2) on commits, dump only the modified resources. Indeed, my model is split in many CDOResources (according to initial XmlResources) to minimize the number of resources to serialize as XML files.
Re: [CDO] MemStore with file-based backend [message #1471429 is a reply to message #1463475] Wed, 12 November 2014 23:31 Go to previous message
Am 06.11.2014 um 16:52 schrieb Stephane Fournier:
> Indeed, my need was not cristal clear :)
> possible ?
The server-side entry point is org.eclipse.emf.cdo.server.CDOServerExporter.exportRepository(OutputStream). You can see
that it's only called by the CDOCommandProvider, but you could
1) Implement your own client/server protocol (e.g. with Net4j) to trigger a CDOServerExporter from a client.
2) Implement a CDORemoteSessionMessage-based protocol between a client and a server-embedded client to do the same.
3) Use telnet or something to gain access to the server console and use the shipped CDOCommandProvider.
No, but syntax help is displayed on the console.
This could be comparingly simple if you make use of the newer IRepository.Props.SERIALIZE_COMMITS option/feature. Could
be a nice contribution to CDO ;-)
Cheers
/Eike
Previous Topic:[CDO] MemStore always supports Audits ?
Next Topic:[CDO] Persistance Strategy for Java Objects
Current Time: Sat Jul 26 11:12:30 EDT 2025
Powered by FUDForum. Page generated in 0.25742 seconds
