Home » Modeling » EMF » [CDO] ClassCastException in CDODeltaNotification for Enum-based attribute
[CDO] ClassCastException in CDODeltaNotification for Enum-based attribute [message #1464447] Fri, 07 November 2014 10:13 Go to next message
Assume I have 2 clients (A and B) connected to a repository (MemStore).
A commits a change on attribute named "state" that is an Enum.
B receives a CDODeltaNotificationImpl with the change made on the attribute named "state". But there is a bug here, indeed both calling getOldObject / getNewObject returns an Integer instead of the Enum, I suppose it is due to the fact the Enum is transported over the networlk as integer.
Thus if I cast the result of getOldObject or getNewObject in the expected Enum, I get a ClassCastException.
I'm using CDO 4.3 release with Luna (Shipped in last June).
Should I file a bugzilla ?
Stéphane.
Re: [CDO] ClassCastException in CDODeltaNotification for Enum-based attribute [message #1471415 is a reply to message #1464447] Wed, 12 November 2014 23:17 Go to previous messageGo to next message
Am 07.11.2014 um 16:13 schrieb Stephane Fournier:
Sure. If you know how to fix it you ideally submit a review to Gerrit ;-)
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] ClassCastException in CDODeltaNotification for Enum-based attribute [message #1472448 is a reply to message #1471415] Thu, 13 November 2014 17:07 Go to previous message
Unfortunately, I'm not aware of Gerrit.
I reproduced the bug with CD0 4.3 from Luna shipped in June.
I have open a bugzilla https://bugs.eclipse.org/bugs/show_bug.cgi?id=450880 and I will give you the fix tomorrow in the bugzilla.
The fix is based on EMF Reflective API to retrieve: from the EStructuralFeature that points to an EEnum, the EEnumLiteral matching the Integer value and from that the related Java Enum literal.
Stéphane.
Previous Topic:Sharing a resource between transactional editing domains
Next Topic:[CDO] eIsSet is ko for eOpposite structural feature ?
Current Time: Sun Aug 31 03:42:42 EDT 2025
Powered by FUDForum. Page generated in 0.04214 seconds
