Home » Modeling » GMF (Graphical Modeling Framework) » Create Connection in a command
Create Connection in a command [message #146259] Fri, 10 August 2007 19:14 Go to next message
Originally posted by: mom.mom.gmx.net
I have the situation, that when I create a Node, I automatically want to
create a second one which is connected to the first one. This is allready
working, I just overwrote the xxxCreateElementCommand where I create the new
Model and add it to it's container. So both models were created and
correctly added ans setup. So this is fine.
But the 'missing' piece is the connection between this two nodes, it is not
visible/created. Some times ago I used GEF, back then I had to create the
connetion manually in the Command. Do I need to do this here too? And if so
how?
Actuall I personally guess this is just a refresh problem, beause when I
save the diagram and reopen it the connection is drawn.
regards Rainer
Re: Create Connection in a command [message #146268 is a reply to message #146259] Fri, 10 August 2007 21:56 Go to previous messageGo to next message
Perhaps this part of the tutorial will help:
http://wiki.eclipse.org/GMF_Tutorial_Part_3#Custom_Actions
Best,
Rich
On 8/10/07 7:14 PM, in article f9irhv$58m$1@build.eclipse.org, "Rainer
> how?
> regards Rainer
Re: Create Connection in a command [message #146278 is a reply to message #146268] Sat, 11 August 2007 08:13 Go to previous messageGo to next message
I'm not sure if this is the right solution in my case, cause I'm allready in
a command. I actually searching for one line of code just creating the
Connection.
cause I done stuff with GEF, I think in the similar way. So at the moment i
have changed the Command :
private void execute() {
// create the Port Object we need
AnonymousClassInterface classInterface =
CjdFactory.eINSTANCE.createAnonymousClassInterface();
Component comp=(Component) getCreateRequest().getContainer();
AnonymousClass anonClass = ((AnonymousClass)getNewElement());
classInterface.setAnonymousClass(anonClass);
anonClass.setAnonymousClassInterface(classInterface);
// Add the code object to the model --> is also correctly show
comp.getCodeUnits().add(classInterface);
AnonymousClass anClass = ...; // Get the class (I know how.)
// Now we need a connection. GEF code: (Portline is the Figure from
..gmfgraph)
new Portline( anClass , classInterface );
The last line with the new Portline , is somthing I would have done with
GEF, but I don't know how to do it with GMF. Or, because the link mapping is
correct am GMF is allready creating the connection when I save and reopen
the diagram, I probably just have to call a refreshConnection() type of
command.
"Richard Gronback" <richard.gronback@borland.com> schrieb im Newsbeitrag
news:C2E28FA6.19B1B%richard.gronback@borland.com...
Re: Create Connection in a command [message #146530 is a reply to message #146278] Tue, 14 August 2007 09:38 Go to previous messageGo to next message
For a newbie (me) it sounds like that you've created the connection just
in the semantic model not in the notation model.
-stefan
> Connection.
> .gmfgraph)
> command.
Re: Create Connection in a command [message #147045 is a reply to message #146530] Sun, 19 August 2007 08:48 Go to previous message
I'm pretty sure you're right. The Problem is, how to tell the notation model
that it should now 'resync' oder whatever is needed to display the
Connection.
"SKuhn" <kuhn@oio.de> schrieb im Newsbeitrag
news:f9sb9d$okr$1@build.eclipse.org...
> -stefan
>> in a command. I actually searching for one line of code just creating the
>> Connection.
>> i have changed the Command :
>> .gmfgraph)
>> with GEF, but I don't know how to do it with GMF. Or, because the link
>> mapping is correct am GMF is allready creating the connection when I save
>> and reopen the diagram, I probably just have to call a
>> refreshConnection() type of command.
Previous Topic:How to deal with org.eclipse.emf.common.command.Command ?
Next Topic:Re: Combining Ecore Models
Current Time: Fri Nov 07 23:38:48 EST 2025
Powered by FUDForum. Page generated in 0.08496 seconds
