Home » Modeling » GMF (Graphical Modeling Framework) » Re: Combining Ecore Models
Re: Combining Ecore Models [message #147016] Fri, 17 August 2007 08:52 Go to next message
Gary,
You're question seems to be purely a GMF one so I've added the GMF
newgroup to the "to" list of the reply since it's best to ask GMF
question on that specific newsgroup.
Gary Leask wrote:
> I have 2 ecore models that I need to combine dynamically in a
> graphical editor produced by EMF-GMF-GEF
> The first ecore model is used to build the graphic element for the
> diagram.
> It provides the palette item and the visual icon on the canvas. I
> don't want ot use the compartments and have to drag all the interior
> elements on to the canvas. Below is a simple example, the real
> implementation can add multiple interior elements.
> The first ecore model for this consists of a
> <stateElement> -- ecore Eclass
> <processElement> - an EReference to and ecore Eclass
> <xsdAny> -- an EFeatureMapEntry
> The second Ecore Model is used to popualte the xsdAny Element. It is
> not known what type of element this will be until it is added to the
> canvas. The element may be from different namespaces <stateElement>
> -- ecore Eclass
> <ns1:collect> -- an EClass
> <ns2:process> -- an EClass
> I have tried to add the second ecore model to the .gmpmap as a child
> reference but The containment feature is not owned by the Domain Meta
> Model.
> If I ignore the error the Diagram Updater is not generated correctly.
> I have tried to add the second ecore model element at the part
> creation time however the transaction is rolled back if I use the
> XXXImpl class when it is created.
> If I tried to add it when it is dropped on the canvas using the
> XXXEditPart. I get a java.lang.IllegalStateException "Cannot modify
> resource set without a write transaction". At this point The
> diagramEditingDomain for the EditPart is null so I can't create a
> SetCommand.
> Where is the best place in the life cycle of the editor or the GMF
> generation to create or define the content of my processElement.
> I can send you code samples if this will help.
Re: Combining Ecore Models [message #147052 is a reply to message #147016] Mon, 20 August 2007 04:20 Go to previous message
Hello Gary,
If you can enumerate all the possible "xsdAny" elements on model definition
time then I suggest you to modify your model and introduce abstract super-class
for such elements - "AbstractXsdAny" + containment link from diagram element
to this abstract class. All the elements of the second model will be inherited
from this one. As a result valid containment reference will be represented
in the model for each child element.
Another option is ignoring validation errors, generating the code and then
modifying it.
Alex Shatalin
Previous Topic:Create Connection in a command
Next Topic:Popup Model Assistant
Current Time: Sun Jul 27 00:36:21 EDT 2025
Powered by FUDForum. Page generated in 0.02185 seconds
