Home » Eclipse Projects » JFace » TextCellEditor does not show edited content
TextCellEditor does not show edited content [message #1467760] Mon, 10 November 2014 04:35 Go to next message
My implementation of a TextCellEditor is the following, also adding a KeyListener:
fHoverTableViewerTextCellEditor = new TextCellEditor(fHoverTableViewer.getTable());
		fHoverTableViewerTextCellEditor.getControl().addKeyListener(new KeyListener() {
			private boolean isPressedKeyModifier = false;
			private boolean isStateKeyModifier = false;
			public void keyPressed(KeyEvent e) {
				isPressedKeyModifier = e.keyCode > 0 && e.character == 0 && (e.keyCode & SWT.MODIFIER_MASK) != 0;
				isStateKeyModifier = e.stateMask > 0 && (e.stateMask & SWT.MODIFIER_MASK) != 0;
				String insertString = null;
				String modifierString = Action.findModifierString(e.keyCode);
				String modifierMask = Action.findModifierString(e.stateMask);
				if (isPressedKeyModifier) {
					insertString = Action.findModifierString(e.keyCode);
					if (isStateKeyModifier) {
						insertString= java.text.MessageFormat.format(Messages.HoverPreferencePage_insertModifierAndDelimiterAndModifier,
								new Object[] { Action.findModifierString(e.keyCode), Action.findModifierString(e.stateMask) });
					fHoverTableViewerTextCellEditor.setValue(insertString);
And then I bind:
fModifierTableViewerColumn.setEditingSupport(ObservableValueEditingSupport.create(fHoverTableViewer, context,
				fHoverTableViewerTextCellEditor,
				CellEditorProperties.control().value(WidgetProperties.text(SWT.Modify)),
				HoverViewModel.getEditingDomain()));
But when I press enter I cannot see my content, or better, if I click again on the Cell, it shows my content, but it dies not show it after the "Editing" context is over.
What am I missing?
Re: TextCellEditor does not show edited content [message #1467783 is a reply to message #1467760] Mon, 10 November 2014 04:56 Go to previous messageGo to next message
You need to call viewer.update(Object,null) after you modified the value.
> KeyListener:
> KeyListener() {
> insertString=
> new Object[] {
> And then I bind:
> context,
> What am I missing?
Re: TextCellEditor does not show edited content [message #1467842 is a reply to message #1467783] Mon, 10 November 2014 05:56 Go to previous messageGo to next message
Yes but I don't have the visibility of the row that was modified/my model Object (I guess, I am still a JFace rookie), don't I?
Re: TextCellEditor does not show edited content [message #1467852 is a reply to message #1467842] Mon, 10 November 2014 06:09 Go to previous messageGo to next message
Well it looks like use use JFace-Databinding for editing but not the
LabelProviders.
Tom
Re: TextCellEditor does not show edited content [message #1467910 is a reply to message #1467852] Mon, 10 November 2014 07:05 Go to previous messageGo to next message
Yes it is a little mixed because I don't know how to intercept the KeyPressed/KeyReleased method in another way. Probably I should just forse a notify from my:
ViewerSupport.bind(fHoverTableViewer, fViewModel.observableList, HoverViewModel.getDisplayDomain());
Re: TextCellEditor does not show edited content [message #1468102 is a reply to message #1467910] Mon, 10 November 2014 10:21 Go to previous message
Ok, using
ObservableMapLabelProvider
solved the problem.
Previous Topic:How to make shell display when it is hidden
Next Topic:How to add readonly textbox in table Viewer.
Current Time: Sun Jul 27 11:48:52 EDT 2025
Powered by FUDForum. Page generated in 0.05647 seconds
