Home » Archived » BIRT » Can Chart Engine use XML chart definitions
Can Chart Engine use XML chart definitions [message #146709] Wed, 22 March 2006 01:45 Go to next message
Originally posted by: diptendu.vsnl.com
The Report Engine can use XML files (.rptdesigns).
Can Chart Engine use something similar?
If yes, is there a GUI tool to generate such chart
definitions in XML format?
I found this on Actuate site
( http://www.actuate.com/products/techzone/birtreporting/birt_ overview/charting.asp)
The BIRT Chart Engine allows Java application developers to provide data
to the engine in a pre-defined format and to provide an XML file that
specifies the characteristics of the chart that will be generated. It also
includes a tightly integrated Eclipse-based design component to facilitate
visual design of the chart
Re: Can Chart Engine use XML chart definitions [message #146717 is a reply to message #146709] Wed, 22 March 2006 02:10 Go to previous message
Yes, you can serialize/deserialize the chart model to an xml file. The chart
is using an EMF model, so you simply use the EMF mechanism to do that. You
can take a look at the ChartWizardLauncher.main example in
org.eclipse.birt.chart.examples for sample code to load/save a chart from
disk.
David
"Diptendu Dutta" <diptendu@vsnl.com> wrote in message
news:3c9325a5177f6b2a83f87aec9ae12c27$1@www.eclipse.org...
> Hello,
Previous Topic:Images appearing in preview, but not report
Next Topic:spring and birt
Current Time: Fri Oct 31 16:41:26 EDT 2025
Powered by FUDForum. Page generated in 0.03526 seconds
