Home » Modeling » GMF (Graphical Modeling Framework) » Change the relation source & target point
Change the relation source & target point [message #146453] Tue, 14 August 2007 03:52 Go to next message
I have implemented an layout algorithm to reorganize the nodes into a
diagram, but now I want to change the source and target point of the
relations between 2 nodes. Somebody knows how to do this?
I try to access to the Bendpoints of the relation, but I think it's not
what I want...
Thanks. Marc.
Re: Change the relation source & target point [message #146510 is a reply to message #146453] Tue, 14 August 2007 05:34 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
They are calculated by connection anchors. Nodes return them for
incoming and outgoing connections.
@see org.eclipse.draw2d.ConnectionAnchor, org.eclipse.gef.NodeEditPart
> what I want...
> Thanks. Marc.
Re: Change the relation source & target point [message #146601 is a reply to message #146510] Wed, 15 August 2007 06:12 Go to previous message
I try to modify the ID of the Anchor (the class that implements Anchor is
called IdentityAnchorImpl, so the class is IdentityAnchor). So I try to
modify this ID, and I put for example "0.5, 0.99" in the source of the
relation, but the change doesn't reflect in the diagram. I want the
relation starts in the down-center of the source, and finishes in the
top-center of the target ("0.5, 0.01", for example).
Previous Topic:Replacing GEF model with EMF; go GMF? Or just EMF+GEF?
Next Topic:Migrating to GMF 2.0 and code generation problem
Current Time: Sat Nov 08 23:24:29 EST 2025
Powered by FUDForum. Page generated in 0.03546 seconds
