Home » Language IDEs » ServerTools (WTP) » The WTP 3.6.1 map file
The WTP 3.6.1 map file [message #1464174] Fri, 07 November 2014 04:04 Go to next message
For work reason , I will build WTP3.6.1 with git source.
However there aren't any map file(directory.txt) informations in WTP3.6.1 download page.
http://download.eclipse.org/webtools/downloads/drops/R3.6.1/R-3.6.1-20140912000031/
While the 3.6.0 has one.
The question is, how can I get the source version without 3.6.1's map.
What's the difference beteen 3.6.0 and 3.6.1?
Re: The WTP 3.6.1 map file [message #1464599 is a reply to message #1464174] Fri, 07 November 2014 13:30 Go to previous messageGo to next message
WTP 3.6.1 is built using CBI (git+Maven+other stuff), and I guess that is why the map files are no longer used.
Each WTP repository should have a git tag like R3_6_1 which you could use to get the source
If you find a wtp repository without a tag, could you post it here? Maybe the project lead can tell which tag should be used instead.
[Updated on: Fri, 07 November 2014 13:30] by Moderator
Re: The WTP 3.6.1 map file [message #1467381 is a reply to message #1464599] Sun, 09 November 2014 21:07 Go to previous messageGo to next message
Roberto Sanchez Herrera wrote on Fri, 07 November 2014 13:30
Hi Roberto
It seems WTP is not quite like the other Porjects. In map file, Sources are listed in plugin/feature, but not repository. Part of 3.6.0RC4's map below:
plugin@org.eclipse.wst.common.infopop=GIT,tag=v201004280700,repo=git://git.eclipse.org/gitroot/webtools-common/webtools.common.git,path=plugins/org.eclipse.wst.common.infopop
plugin@org.eclipse.wst.validation.infopop=GIT,tag=v200806041506,repo=git://git.eclipse.org/gitroot/webtools-common/webtools.common.git,path=docs/org.eclipse.wst.validation.infopop
plugin@org.eclipse.wst.common.api.doc=GIT,tag=v200807181737,repo=git://git.eclipse.org/gitroot/webtools-common/webtools.common.git,path=docs/org.eclipse.wst.common.api.doc
plugin@org.eclipse.wst.validation.doc.isv=GIT,tag=v201209262100,repo=git://git.eclipse.org/gitroot/webtools-common/webtools.common.git,path=docs/org.eclipse.wst.validation.doc.isv
For 3.6.0RC4, I have to clone [webtools.common.git] and checkout to many tags to get different plugins/features.
Do you mean that ,from 3.6.1, all the plugins/features are in the same tag/branch so we only have to clone [webtools.common.git] and checkout to a tag like R3_6_1?
[Updated on: Sun, 09 November 2014 21:10] by Moderator
Re: The WTP 3.6.1 map file [message #1468081 is a reply to message #1467381] Mon, 10 November 2014 10:02 Go to previous messageGo to next message
Yes, try using the tag R3_6_1 on the repository.
Re: The WTP 3.6.1 map file [message #1468909 is a reply to message #1468081] Tue, 11 November 2014 01:29 Go to previous message
Thanks Roberto
I checkouted src to the below tags/branchs. Four of them are not in tag R3_6_1.
Anybody tell me are these right? If not please tell me the right ones.
webtools.releng.aggregator          R3_6_1_patches (branch)
 webtools.common                    R3_6_1
 webtools.common.fproj              R3_6_1
 webtools.common.snippets           R3_6_1
 webtools.common.tests              R3_6_1
 webtools.dali                      R3_4_1a (R3_4_1 or R3_4_1a?)
 webtools.ejb                       R3_6_1
 webtools.javaee                    R3_6_1
 webtools.javaee.tests              R3_6_1
 webtools.jsdt                      R3_6_1
 webtools.jsf                       R3_6_1
 webtools.jsf.docs                  R3_6_1
 webtools.jsf.tests                 R3_6_1
 webtools.releng                    R3_6_1
 webtools.servertools               R3_6_1
 webtools.servertools.docs          master  (R3_6_1 doesn't exist)
 webtools.servertools.tests         master  (R3_6_1 doesn't exist)
 webtools.sourceediting             R3_6_1
 webtools.sourceediting.tests       R3_6_1
 webtools.sourceediting.xpath       R3_6_1
 webtools.sourceediting.xpath.tests R3_6_1
 webtools.sourceediting.xsl         R3_6_1
 webtools.sourceediting.xsl.tests   R3_6_1
 webtools.webservices               R3_6_1
 webtools.webservices.axis2         R3_6_1
 webtools.webservices.jaxws         R3_6_1
[Updated on: Tue, 11 November 2014 05:07] by Moderator
Previous Topic:DOM object
Next Topic:Suffix 'Service'
Current Time: Thu Jul 24 21:32:26 EDT 2025
Powered by FUDForum. Page generated in 0.27932 seconds
