Home » Eclipse Projects » Eclipse Platform » classloading error after defining package prefixes
classloading error after defining package prefixes [message #145790] Fri, 17 October 2003 10:24 Go to next message
I began adding
<packages prefixes="my.package.prefix"/>
elements to certain libraries in my plugin.xml. after doing this,
classes from those libraries that did *not* have these elememts declared
could not be loaded any longer.
is this a bug or a feature, or am I missing something?
thanks,
Christian
Re: classloading error after defining package prefixes [message #146210 is a reply to message #145790] Sat, 18 October 2003 10:20 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Christian Sell wrote:
> Hello,
> I began adding
> declared could not be loaded any longer.
A feature to improve class loading: you have to list all package
prefixes of the library. Those not being declared are not found.
Dani
> thanks,
> Christian
Re: classloading error after defining package prefixes [message #146364 is a reply to message #146210] Sun, 19 October 2003 14:35 Go to previous messageGo to next message
>> Hello,
>> I began adding
> Dani
did you get what I meant? Let me give an example
<library file="bla.jar"/>
<library file="another.jar">
<packages prefixes="com.mycomp.dada"/>
</library>
after declaring the prefixes for library "another.jar", the classes from
library "bla.jar" were no longer found. Feature?
thanks,
Christian
>> thanks,
>> Christian
Re: classloading error after defining package prefixes [message #146416 is a reply to message #146364] Mon, 20 October 2003 04:13 Go to previous messageGo to next message
>>> Hello,
>>> I began adding
>> Dani
From your original post it was not clear (at least to me) whether the
*not* belongs to the classes or library. It would have been clearer with
the example attached along with the first posting ;-).
> </library>
> from library "bla.jar" were no longer found. Feature?
No, this would clearly be a bug. Looks like the class loader uses
prefixes for all libs if prefixes are given for one lib. Please file a
bug report against Platform Core.
> thanks,
> Christian
>>> thanks,
>>> Christian
Re: classloading error after defining package prefixes [message #148692 is a reply to message #146364] Thu, 23 October 2003 14:24 Go to previous message
Originally posted by: John_Arthorne.oti.com_
It's a known problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=37480
Previous Topic:swt: how to add to a TableViewer
Next Topic:How to make IPath for file on other system
Current Time: Thu Nov 06 23:22:37 EST 2025
Powered by FUDForum. Page generated in 0.03051 seconds
