Home » Modeling » M2T (model-to-text transformation) » XSD as XML representation for JET
XSD as XML representation for JET [message #14609] Wed, 02 May 2007 05:57 Go to next message
I have an XSD schema and try to use it as input for JET2 transformation.
But this schema either loaded as Ecore XSD model or not loaded at all.
Even if I try to rename it to *.xml it can't be loaded by
org.eclipse.jet.emfxml model loader.
How can I load schema document as a simple XML file?
P.S Debug log of org.eclipse.jet.emfxml on loading XSD:
templates/dump.jet(3,1): <c:load var="simpleSchema"
loader="org.eclipse.jet.emfxml" url="simpleSchemas/xsd_complexType.xsd">
Error: Unable to load: simpleSchemas/xsd_complexType.xsd
Vladimir
Re: XSD as XML representation for JET [message #14640 is a reply to message #14609] Wed, 02 May 2007 11:19 Go to previous messageGo to next message
Vladimir:
This is a limitation of the EMF-based XML loader JET am using. When the XML
loader sees a XML namespace definition, it attempts to find the
corresponding XSD. If it cannot, then it refuses to load the document.
The good news is, I have figured out how to overcome it. Bug 185143
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=185143) tracks this. It
should be committed this week.
Once this is in, you will need to do the following on you c:load:
<c:load var="simpleSchema" loader="org.eclipse.jet.emf.xml" type="xml"
url="simpleSchemas/xsd_complexType.xsd"/>
The 'type' attribute tells the loader to pretend that the file has an XML
extension for the purposes of selecting the EMF loader.
Paul
"Vladimir Sosnin" <antiso@gmail.com> wrote in message
news:f19nb0$6i2$3@build.eclipse.org...
> Hello,
> Regards,
> Vladimir
Re: XSD as XML representation for JET [message #14699 is a reply to message #14640] Wed, 02 May 2007 11:48 Go to previous messageGo to next message
Paul,
I've found solution. It can be done by following code in template body:
try {
String filePath=
" /export/work/workspace/myproject/simpleSchemas/xsd_complexTy pe.xsd ";
File file = new File(filePath);
context.logInfo("Loading file: " + file.getAbsolutePath());
DocumentBuilder builder =
DocumentBuilderFactory.newInstance().newDocumentBuilder();
Document doc = builder.parse(file);
context.setVariable("simpleSchema", doc);
} catch (Exception e) {
e.printStackTrace();
<c:log>
<c:addElement
select="$simpleSchema/descendant-or-self::*[name()='appinfo'] "
name="foo" var="new"/>
<c:dump select="$simpleSchema/descendant-or-self::*" format="true"
entities="true" />
<c:dump select="$new" format="true" entities="true" />
</c:log>
Moreover, tag "c:addElement" works with this model! It's exactly what I
was looking for.
Vladimir
Paul Elder wrote:
> Vladimir:
> Paul
>> Hello,
>> Regards,
>> Vladimir
Re: XSD as XML representation for JET [message #14729 is a reply to message #14699] Wed, 02 May 2007 13:28 Go to previous message
Vladimir:
Glad you're making some progress. I'll consider adding a model loader that
uses XML DOM, too.
Paul
news:f1abt9$12i$1@build.eclipse.org...
> Paul,
> try {
> String filePath=
> <c:log>
> <c:addElement
> entities="true" />
> </c:log>
> was looking for.
> Regards,
> Vladimir
> Paul Elder wrote:
>> Vladimir:
>> XML
>> Paul
>>> Hello,
>>> Regards,
>>> Vladimir
Previous Topic:Jet modules
Next Topic:[JET2] Starnge behavior with xmi:type tags
Current Time: Fri Jul 18 18:34:56 EDT 2025
Powered by FUDForum. Page generated in 0.06753 seconds
