Home » Modeling » GMF (Graphical Modeling Framework) » GMF & extension point: org.eclipse.emf.ecore.extension_parser
GMF & extension point: org.eclipse.emf.ecore.extension_parser [message #146018] Thu, 09 August 2007 12:40 Go to next message
I want to make use of my own persister for the sematic model domain of
my GMF Editor. Everything worked great with my EMF generated tree editor
but in GMF there are some problems. Is there generally speaking
something more to adjust in GMF than just using the extension point
org.eclipse.emf.ecore.extension_parser ?
thanks in advance,
dawid
Re: GMF & extension point: org.eclipse.emf.ecore.extension_parser [message #146089 is a reply to message #146018] Fri, 10 August 2007 05:18 Go to previous message
Hello Dawid,
No. Even more, it should be enough, so if you face any problems try to report
it here.
I've recently plugged in custom parser for semantic model into org.eclipse.emf.ecore.extension_parser
and modify exisitng diagram to work upon this resource - looks like diagram
is working (with some minor problems like synchronize with external changes).
Nevertheless I did not try to create new diagram using custom resource factory
step by step, so there could be some problems.
Alex Shatalin
Previous Topic:Extension Point Issue
Next Topic:Editor still "dirty" after a full undo
Current Time: Sun Nov 09 04:24:54 EST 2025
Powered by FUDForum. Page generated in 0.45328 seconds
