Home » Language IDEs » Java Development Tools (JDT) » Global or project specific VM arguments?
Global or project specific VM arguments? [message #145951] Fri, 27 February 2004 03:24 Go to next message
Originally posted by: markku.saarela.entra.fi
Is it possible to set Global or project specific VM arguments for running
or debugging program. I like for ex. use same log4j property file for
programs in same project. How to set -Dlog4j.configuration=... property so
that all programs at least in same project find's it.
thanks, Markku
Re: Global or project specific VM arguments? [message #145960 is a reply to message #145951] Fri, 27 February 2004 05:15 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
You can use the following work-arounds for such this problem:
1. (in Eclipse 3.0M7) You can define variables in
Window->Preferences->Run/Debug->String Substitution. For example you can
define a projectName_log4j variable with the
correct -Dlog4j.configuration=... value. In a run configuration you can use
${projectName_log4j} and you don't have to remember the real value.
2. You can define a project-specific "empty" run configuration. Set the
project and the arguments fields in this configuration but not the main
class. If you have to create a new run configuration for this project select
this one and use 'Duplicate' from its popup-menu to copy this configuration.
You have to simply set the main class and the program arguments.
Also you can combine both solutions: use a variable and define an "empty"
run configuration which use this variable. The great advantage in this case
is when you begin to use a different log4j config file you have to change
only the variable declaration.
HTH,
Csaba
"Markku Saarela" <markku.saarela@entra.fi> wrote in message
news:c1muso$ev1$1@eclipse.org...
> thanks, Markku
Re: Global or project specific VM arguments? [message #145970 is a reply to message #145960] Fri, 27 February 2004 05:42 Go to previous messageGo to next message
Thanks, this work-around works.
But still i must define all the common
systemproperties substitutions for all run confics. Do you know if there
are any plans to implement real project configuration management for these
sysprops?
Rgds, Markku
Horváth, Csaba wrote:
> HTH,
> Regards,
> Csaba
> > Hi,
> > thanks, Markku
Re: Global or project specific VM arguments? [message #145997 is a reply to message #145970] Fri, 27 February 2004 09:19 Go to previous messageGo to next message
For the 3.0 release, this is unlikely to happen - due to time/resource
contraints.
Darin
news:c1n6vi$ph1$1@eclipse.org...
> sysprops?
> Rgds, Markku
> Horv
Re: Global or project specific VM arguments? [message #146328 is a reply to message #145997] Sat, 28 February 2004 02:36 Go to previous message
It's good to hear that item is planned to do!
Markku
> contraints.
> Darin
> > Hi,
> > sysprops?
> > Rgds, Markku
> > > Hi,
> use
> select
> configuration.
> "empty"
> case
> change
> > > HTH,
> > > Regards,
> > > Csaba
> > > > Hi,
> running
> property so
> > > > thanks, Markku
Previous Topic:What is "Launch in Background"?
Next Topic:Update of the classes on the bin folder
Current Time: Thu Oct 30 04:49:34 EDT 2025
Powered by FUDForum. Page generated in 0.07256 seconds
