Home » Language IDEs » ServerTools (WTP) » org.eclipse.wst.wsdl.Definition serialization namespace
org.eclipse.wst.wsdl.Definition serialization namespace [message #145995] Wed, 02 November 2005 15:35 Go to next message
Originally posted by: esnible.acm.org
I create a <definition> using
org.eclipse.wst.wsdl.WSDLFactory.eINSTANCE.createDefinition( ), add the
definition to a Resource, and save it. The generated .wsdl file looks
like this:
<definitions/>
This was unexpected; I had hoped to see a namespace:
<definitions xmlns="http://schemas.xmlsoap.org/wsdl/"/>
This seems to be my fault. I have told the ResourceSet to use
org.eclipse.wst.wsdl.internal.util.WSDLResourceFactoryImpl (by putting
that in the extension-to-factory map.) When I put XMIResourceFactoryImpl
into the extension-to-factory map alone I get proper namespaces:
<?xml version="1.0" encoding="ASCII"?>
<wsdl:Definition xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:wsdl="http://www.ibm.com/wsdl/2003/WSDL"/>
... but that factory impl can't serialize the full WSDL I want to generate
(EMF complains the embedded schemas aren't contained in a file when
serializing using XMIResourceFactoryImpl).
Any advice?
Re: org.eclipse.wst.wsdl.Definition serialization namespace [message #146132 is a reply to message #145995] Thu, 03 November 2005 10:49 Go to previous messageGo to next message
It sounds to be a bug in the WSDL model.
Try to associate it with a namespace prefix like the following as a
workaround, and open a defect.
Definition definition = WSDLFactory.eINSTANCE.createDefinition();
resource.getContents().add(definition);
definition.addNamespace("wsdl", "http://schemas.xmlsoap.org/wsdl/");
- Kihup
Re: org.eclipse.wst.wsdl.Definition serialization namespace [message #146178 is a reply to message #145995] Thu, 03 November 2005 11:36 Go to previous message
With some help from an IBM colleage I discovered a fix.
Adding
d.addNamespace("wsdl", "http://schemas.xmlsoap.org/wsdl/");
to the EMF instance fixed the serialization problems. I post here in case
others encounter the same problem.
Previous Topic:WTP XDoclet EJB spec version
Next Topic:Help with Eclipse - BIRT
Current Time: Sat Jul 19 04:10:50 EDT 2025
Powered by FUDForum. Page generated in 0.02918 seconds
