Error while generating Diagram Editor Gen Model [message #1458064] |
Fri, 31 October 2014 21:12  |
Hi I was following the mindmap GMF example, but when I try to create Diagram Editor GMF Gen Model using the GMF Dashboard. I get the following error:
Unhandled event loop exception
java.lang.NoSuchMethodError: org.eclipse.m2m.internal.qvt.oml.compiler.QVTOCompiler.createCompilerWithHistory(Lorg/eclipse/m2m/internal/qvt/oml/compiler/UnitResolver;Lorg/eclipse/emf/ecore/resource/ResourceSet;)Lorg/eclipse/m2m/internal/qvt/oml/compiler/QVTOCompiler;
at org.eclipse.gmf.internal.xpand.util.ResourceManagerImpl.getQvtCompiler(ResourceManagerImpl.java:97)
at org.eclipse.gmf.internal.xpand.util.ResourceManagerImpl.doLoadQvtResource(ResourceManagerImpl.java:75)
at org.eclipse.gmf.internal.xpand.util.ResourceManagerImpl.loadQvtResourceThroughCache(ResourceManagerImpl.java:63)
at org.eclipse.gmf.internal.xpand.util.ResourceManagerImpl.loadQvtResource(ResourceManagerImpl.java:46)
at org.eclipse.gmf.internal.xpand.model.Scope.findExtension(Scope.java:148)
at org.eclipse.gmf.internal.xpand.model.ExecutionContextImpl.getImportedModules(ExecutionContextImpl.java:293)
at org.eclipse.gmf.internal.xpand.model.ExecutionContextImpl.getOCLEnvironment(ExecutionContextImpl.java:254)
at org.eclipse.gmf.internal.xpand.ocl.TypeHelper.getTypeForName(TypeHelper.java:35)
at org.eclipse.gmf.internal.xpand.model.ExecutionContextImpl.findDefinition(ExecutionContextImpl.java:231)
at org.eclipse.gmf.internal.xpand.model.ExecutionContextImpl.findDefinition(ExecutionContextImpl.java:167)
at org.eclipse.gmf.internal.xpand.XpandFacade.evaluate(XpandFacade.java:54)
at org.eclipse.gmf.graphdef.codegen.FigureGenerator.go(FigureGenerator.java:99)
at org.eclipse.gmf.internal.bridge.genmodel.InnerClassViewmapProducer.createViewmap(InnerClassViewmapProducer.java:128)
at org.eclipse.gmf.internal.bridge.genmodel.InnerClassViewmapProducer.create(InnerClassViewmapProducer.java:76)
at org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTransformer.process(DiagramGenModelTransformer.java:413)
at org.eclipse.gmf.internal.bridge.genmodel.MappingTransformer.transform(MappingTransformer.java:31)
at org.eclipse.gmf.internal.bridge.transform.TransformToGenModelOperation$2.process(TransformToGenModelOperation.java:435)
at org.eclipse.gmf.internal.bridge.transform.TransformToGenModelOperation.executeTransformation(TransformToGenModelOperation.java:265)
at org.eclipse.gmf.internal.bridge.ui.dashboard.actions.TransformMap2GenModelAction.run(TransformMap2GenModelAction.java:65)
at org.eclipse.gmf.internal.bridge.ui.dashboard.HyperlinkFigure$1.mousePressed(HyperlinkFigure.java:63)
at org.eclipse.draw2d.Figure.handleMousePressed(Figure.java:935)
at org.eclipse.draw2d.SWTEventDispatcher.dispatchMousePressed(SWTEventDispatcher.java:242)
at org.eclipse.draw2d.LightweightSystem$EventHandler.mouseDown(LightweightSystem.java:523)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:192)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4188)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1467)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1490)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1475)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1279)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4031)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3658)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
Session Data:
eclipse.buildId=4.4.1.M20140925-0400
java.version=1.7.0_67
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -product org.eclipse.epp.package.modeling.product -keyring /Users/er/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.modeling.product -keyring /Users/er/.eclipse_keyring -showlocation
can anyone help me resolve this issue, I am using Eclipse Luna with Modeling Tools.
Re: Error while generating Diagram Editor Gen Model [message #1463324 is a reply to message #1463204] |
Thu, 06 November 2014 07:52  |
Ed Willink wrote on Thu, 06 November 2014 05:09Are you suggesting that the Additional Modeling Packages is offering Kepler? That seems much more likley it's happened more than once before
and just requires a poke to Amalgam?
Yes, the Eclipse Modeling Components Discovery dialog did so. Can't reproduce today, so must have been fixed.
FUDForum. Page generated in 0.04921 seconds
