Home » Modeling » GMF (Graphical Modeling Framework) » Problem with Tool Galerie
Problem with Tool Galerie [message #145800] Wed, 08 August 2007 08:26 Go to next message
After using the new Version of GMF 2.0, I encounter some strange behavior
at the tool group palette. The palette contains 4 different objects and I
can use it to make new objects, but the description seems to be wrong, if
I would like to make an object of kind A, the editor makes a new object of
kind B. I checked my mapping file and it seems to be ok. Where can I make
sure which symbol in the palette makes the specified type of objects? I
did not have this problem with GMF 1.
Thank you for reading this post.
Malte
Re: Problem with Tool Galerie [message #145811 is a reply to message #145800] Wed, 08 August 2007 08:39 Go to previous messageGo to next message
Originally posted by: trac.phandinh.hotmail.fr
Hi Malte, when you say that you checked your mapping file, are you sure
that the different creation tool correspond to the nodes you want to
display? For that look at all top node reference and check the node mapping
Re: Problem with Tool Galerie [message #145820 is a reply to message #145800] Wed, 08 August 2007 08:43 Go to previous messageGo to next message
Originally posted by: orlando.opencanarias.com
Hi Malte,
Are you sure the property Tool of all Node Mappings within the
..gmfmap are pointing towards the right element in .gmftool?
It seems to me that, occasionally, the wizard that generates
the .gmfmap file fails to fill in that property right. When
that happened to me, some Node Mappings where not pointing
to the right Creation Tool element from the .gmftool file.
Orlando
> Malte
Re: Problem with Tool Galerie [message #145836 is a reply to message #145820] Wed, 08 August 2007 09:00 Go to previous message
Thank you very much guys, for your fast and competent help. The problem is
solved.
Previous Topic:How create custom figures with .gif
Next Topic:Compartment - Connection - Layout
Current Time: Wed Nov 05 12:59:17 EST 2025
Powered by FUDForum. Page generated in 0.04273 seconds
