Home » Modeling » Papyrus » OCL Association Constraint(Validation throws error on association constraints)
OCL Association Constraint [message #1455768] Wed, 29 October 2014 14:43 Go to next message
I am relatively new to OCL and its application to UML Profiles. I have created a simpled profile with two stereotypes ST1 and ST2 that extend metaclass UML Class and one stereotypes testLink that extends metaclass Association. In this profile, I have created the following constraint
self.base_Association.memberEnd->at(1).oclIsTypeOf(profile::Test1::ST1)
and
self.base_Association.memberEnd->at(2).oclIsTypeOf(profile::Test1::ST2)
When I save the profile, I also check the options to save the OCL constraints with the profile. I am using Kepler and Papyrus (0.10.2). In the windows Preferences->OCL, I have selected /ECore/OCL/Pivot.
When I apply the profile to an UML Class diagram (two classes and one association, applied with stereotypes) and validate the application, I have the following error
Severity	Description	Element	Parent	Type
Error	An exception occurred while delegating evaluation of the 'Constraint1' invariant on 'Test Link -> <<testLink>> <Association> myassocication': Errors in '
and
self.base_Association.memberEnd->at(2).oclIsTypeOf(profile::Test1::ST2)'
2: Unresolved Property 'profile::Test2::http://www.eclipse.org/uml2/2.0.0/UML::Test2::testLink::base_Association'
2: Ambiguous resolution:
	Property : uml::Association.memberEnd
	Property : UML::Association.memberEnd
2: Unresolved Operation 'Set(OclInvalid)::at(UnlimitedNatural)'
4: Unresolved Property 'profile::Test2::http://www.eclipse.org/uml2/2.0.0/UML::Test2::testLink::base_Association'
4: Ambiguous resolution:
4: Unresolved Operation 'Set(OclInvalid)::at(UnlimitedNatural)'	<<testLink>> <Association> class1_class2_1	model	EMF Problem
Re: OCL Association Constraint [message #1456143 is a reply to message #1455768] Thu, 30 October 2014 00:07 Go to previous messageGo to next message
I don't know what is wrong with "Test1::ST1". Others may help you with that. But If you want to specify the end members of an association meta class, you can write this:
self.base_Association->collect(e|e.endType().getAppliedStereotypes()->asSequence()->at(1).name)->includes('ST1')
and
self.base_Association->collect(e|e.endType().getAppliedStereotypes()->asSequence()->at(1).name)->includes('ST2')
Also, you made an assumption that the member ends first and last (i.e. at(1), at(2)) are in order which is not usually the case.
Instead of using "includes" twice, I tried the constraint below, but didn't work for me, which again I don't know the reason:
self.base_Association->collect(e|e.endType().getAppliedStereotypes()->asSequence()->at(1).name)->includesAll(Set{'ST1','ST2'})
A question that I have, Is how you will navigate with association metaclass (i.e. testLink) to write other OCLs? for example, ST1 has Attribute1 and ST2 has Attribute2 both from type of Real. You want to be sure that the value of Attribute1 is less than Attribute2. Can we do that really with meta class Associations? How about the time we need to navigate from multiple associations? This seems complicated to me.
Re: OCL Association Constraint [message #1456865 is a reply to message #1456143] Thu, 30 October 2014 16:19 Go to previous messageGo to next message
Thanks. You example, helped me to figure out the right way. Furthermore, the new LUNA with OCL Console is very useful. I have used the following constraint for my purpose:
 self.base_Association.endType.getAppliedStereotypes()->asSequence().name->includesAll(Set{'ST1','ST2'})
But here is the interesting thing I have found. There were two ways, I have defined the OCL constrains.
1. I have used "Constraint" node from the designed Palette in Papyrus and associated "Contextual Link" to the respective stereotype. I defined the OCL constraint in the "Constraint" box and saved the profile.
2. I have defined a .ocl file using "OCL->Complete OCL File" (OCL 5.0.2) and placed it in the profile along with (.di, .notation and .uml). I have moved the OCL constraints into the .ocl file.
When I validate the model, option 1 works fine, but option 2 does'not.
Do I have to do anything specific when dealing with .ocl and papyrus (profile and class diagram).
Re: OCL Association Constraint [message #1456873 is a reply to message #1455768] Thu, 30 October 2014 16:25 Go to previous messageGo to next message
The oclIsTypeOf operation tests that a model element's metaclass is
exactly the argument. Stereotypes are not metaclasses, so your
expressions don't make sense.
You navigated the context stereotype's metaclass extension to access
the association; you need to do similarly for the member-end
properties. Something like this (not tested by me) may work:
self.base_Association.memberEnd->at(1).extension_ST1->notEmpty()
and
self.base_Association.memberEnd->at(2).extension_ST2->notEmpty()
HTH,
Christian
On 2014-10-29 18:43:01 +0000, Rishi Kanth said:
> and
> and
> Thanks
Re: OCL Association Constraint [message #1456893 is a reply to message #1456873] Thu, 30 October 2014 16:48 Go to previous messageGo to next message
HI,
Thanks. I wil try, but do you know anything about the other problem I am currently facing (constraints within the profile and constraints in .ocl file)
Re: OCL Association Constraint [message #1456916 is a reply to message #1456893] Thu, 30 October 2014 17:22 Go to previous messageGo to next message
Hi ,
About your second problem ( validating the completeOCL file on the models) I should say I had the same problem and after asking it in the OCL forum they told me to fill a bug report for that. Still no response.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=446007
Azadeh
Re: OCL Association Constraint [message #1457613 is a reply to message #1456916] Fri, 31 October 2014 10:10 Go to previous message
Thanks for reply. I will follow the bug progress.
Previous Topic:Re: How to apply a profile to an Activity Diagram
Next Topic:Working with Papyrus Search
Current Time: Sun Jul 27 02:14:19 EDT 2025
Powered by FUDForum. Page generated in 0.04478 seconds
