Home » Modeling » GMF (Graphical Modeling Framework) » How to programmatically set an EditPart to be selected
How to programmatically set an EditPart to be selected [message #145612] Tue, 07 August 2007 10:25 Go to next message
Originally posted by: tyhoho.gmail.com
Hi there,
How to programmatically set an EditPart to be selected?
Thanks in advance!
Re: How to programmatically set an EditPart to be selected [message #145628 is a reply to message #145612] Tue, 07 August 2007 10:36 Go to previous messageGo to next message
Hi Tina,
Use EditPartViewer#select(EditPart),
EditPartViewer#appendSelection(EditPart),
EditPartViewer#deselect(EditPart) or EditPartViewer#deselectAll().
Boris
Tina Chen wrote:
> Hi there,
> Thanks in advance!
Re: How to programmatically set an EditPart to be selected [message #145637 is a reply to message #145628] Tue, 07 August 2007 10:46 Go to previous messageGo to next message
Thanks for you reply,but how to get an instanceof EditPartViewer ?
Boris Blajer wrote:
> Hi Tina,
> Best regards,
> Boris
> Tina Chen wrote:
>> Hi there,
>> Thanks in advance!
Re: How to programmatically set an EditPart to be selected [message #145644 is a reply to message #145637] Tue, 07 August 2007 10:49 Go to previous messageGo to next message
Hi Tina,
If you have an edit part (well, I believe you have it, otherwise you
cannot select it), use EditPart#getViewer() to navigate to the edit part
viewer.
Boris
> Boris Blajer wrote:
>> Hi Tina,
>> Best regards,
>> Boris
>> Tina Chen wrote:
>>> Hi there,
>>> Thanks in advance!
Re: How to programmatically set an EditPart to be selected [message #145653 is a reply to message #145628] Tue, 07 August 2007 10:53 Go to previous message
Hi,Boris
Thank you very much! Problem solved.
I get the EditPart instance named editP,
then use editP.getViewer().select(editP).
It works!
Boris Blajer wrote:
> Hi Tina,
> Best regards,
> Boris
> Tina Chen wrote:
>> Hi there,
>> Thanks in advance!
Previous Topic:In-Code documentation xpt
Next Topic:Online Doc linked to Eclipse 3.1 help
Current Time: Fri Jul 18 17:43:45 EDT 2025
Powered by FUDForum. Page generated in 0.08365 seconds
