Home » Eclipse Projects » Remote Application Platform (RAP) » Input Dialogs issue with escape key
Input Dialogs issue with escape key [message #1455679] Wed, 29 October 2014 12:38 Go to next message
We noticed something we suspect to be a RAP bug in our application.
If escape key is pressed fast enough with other keys in an input dialog we have some strange behavior and following stack trace displayed in our logs:
It is probably because is in batch of event to process there are some concerning the dialog closed by the escape key pressing.
I guess it is reproducible in demo, if you go there
http://rap.eclipsesource.com/demo/release/controls/#Dialogs
* open input dialog
* type something randomly in the input text and press escape as well (very fast or type something with one hand and press escape with the other to be sure to reproduce)
* the dialog is closed
* none of the buttons are working anymore unless the page is refreshed, so something is probably broken in the session and I think you should see similar logs on the server that I had in my application
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:3645)
at org.eclipse.swt.SWT.error(SWT.java:3568)
at org.eclipse.swt.SWT.error(SWT.java:3539)
at org.eclipse.swt.widgets.Widget.error(Widget.java:1031)
at org.eclipse.swt.widgets.Widget.getDisplay(Widget.java:408)
at org.eclipse.swt.widgets.Widget.isValidThread(Widget.java:986)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:969)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:594)
at org.eclipse.swt.widgets.Text.verifyText(Text.java:1072)
at org.eclipse.swt.widgets.Text.internalSetText(Text.java:1056)
at org.eclipse.swt.widgets.Text.access$0(Text.java:1055)
at org.eclipse.swt.widgets.Text$1.setText(Text.java:1036)
at org.eclipse.swt.internal.widgets.textkit.TextOperationHandler.setText(TextOperationHandler.java:147)
at org.eclipse.swt.internal.widgets.textkit.TextOperationHandler.access$2(TextOperationHandler.java:146)
at org.eclipse.swt.internal.widgets.textkit.TextOperationHandler$1.run(TextOperationHandler.java:75)
at org.eclipse.rap.rwt.internal.lifecycle.ProcessActionRunner.executeNext(ProcessActionRunner.java:51)
at org.eclipse.swt.widgets.Display.runPendingMessages(Display.java:1191)
at org.eclipse.swt.widgets.Display.safeReadAndDispatch(Display.java:1176)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:1168)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2733)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2694)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:2530)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:701)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:684)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:157)
[Updated on: Wed, 29 October 2014 12:40] by Moderator
Re: Input Dialogs issue with escape key [message #1456224 is a reply to message #1455679] Thu, 30 October 2014 02:12 Go to previous messageGo to next message
Hi Arnaud,
please open a bugzilla about it and I'll take a look immediately.
Best,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Input Dialogs issue with escape key [message #1456344 is a reply to message #1455679] Thu, 30 October 2014 05:02 Go to previous messageGo to next message
BTW... this happens only if Verify listener is attached to the Text
widget. Isn't it?
Ivan Furnadjiev
Re: Input Dialogs issue with escape key [message #1456466 is a reply to message #1456344] Thu, 30 October 2014 07:47 Go to previous messageGo to next message
In the dialog where I initially see the issue the text widget is using databinding
Then I reproduced it with standard Input Dialog (where I guess there are also some listeners attached to the Text)
I was about to fill the issue when I found this one https://bugs.eclipse.org/bugs/show_bug.cgi?id=328696 and I am wondering if they are not related
What do you think ? so you still want I fill a new issue or I comment this one with the way to reproduce it in Demo ?
[Updated on: Thu, 30 October 2014 07:48] by Moderator
Re: Input Dialogs issue with escape key [message #1456474 is a reply to message #1456466] Thu, 30 October 2014 07:57 Go to previous messageGo to next message
Hi Arnaud,
the mentioned bug is quite old (even the problem is still valid and
related to your issue). Please file a separate bugzilla. I have a patch
prepared to address your problem.
Best,
Ivan
Ivan Furnadjiev
Re: Input Dialogs issue with escape key [message #1456530 is a reply to message #1456474] Thu, 30 October 2014 09:02 Go to previous message
I have opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=449350
Previous Topic:Can we use the Dependency Injection feture of E4 in RAP
Next Topic:Swingwt on RAP
Current Time: Sun Jul 27 16:41:25 EDT 2025
Powered by FUDForum. Page generated in 0.03836 seconds
