Home » Modeling » Graphiti » Multiple PictogramElements for single BusinessElement(.. and Pictogramelements without linked business element)
Multiple PictogramElements for single BusinessElement [message #726022] Fri, 16 September 2011 08:39 Go to next message
I want to create a flow Editor. At the beginning I create one Flow-BusinessObject and then the following three Pictogramelements should be created (StartNode, Endnode and Connection):
http://image-upload.de/image/q82Lsb/cc51646ce1.png
How do create more then one Pictogramelement for one businessobject? Is the only way to have a containershape and then three shapes in it?
And is it possible to add a Pictogrammelement without having a Business Object?
Re: Multiple PictogramElements for single BusinessElement [message #726032 is a reply to message #726022] Fri, 16 September 2011 08:49 Go to previous messageGo to next message
In your add feature you can create so many PictogramElements as you want.
Or is the question about linking business objects with pictogram elements? You can link the same business object to more then one pictogram element. This is also no problem.
Re: Multiple PictogramElements for single BusinessElement [message #726035 is a reply to message #726032] Fri, 16 September 2011 08:57 Go to previous messageGo to next message
Matthias Gorning wrote on Fri, 16 September 2011 08:49
yeah, but i can only return exactly one Pictogramelement in the add feature. So if i create the three PE's for StartNode, Connection and EndNode, i have to put them in a Container PE and return that Container PE. Am I right?
If I do so, is it possible for the user to select each of the three PE's distinctly or can he only select the container PE? And does the container PE need a graphic algorithm?
Re: Multiple PictogramElements for single BusinessElement [message #726041 is a reply to message #726035] Fri, 16 September 2011 09:11 Go to previous messageGo to next message
In my opinion a container shape doesn't make sense. It is OK if you return only one PictogramElement. That means only this one will be selected after the creation. Is that behaviour OK for you?
Re: Multiple PictogramElements for single BusinessElement [message #726050 is a reply to message #726041] Fri, 16 September 2011 09:23 Go to previous messageGo to next message
Yeah that's okay, if the other two PE's are selectable as well. thx!
Any input for the other question: Wink
Is it possible to add a Pictogrammelement without having a Business Object?
Re: Multiple PictogramElements for single BusinessElement [message #726066 is a reply to message #726050] Fri, 16 September 2011 09:49 Go to previous messageGo to next message
They will be selectable if your main PE's for StartNode, Connection and EndNode are all set to active.
Yes, it is possible to add a PE without having a BO.
If you have PE's linked with the same BO, or PE's without a BO you must be able to differentiate your PE's in your feature provider. You can simply do this, by adding properties to such kind of PE's.
Re: Multiple PictogramElements for single BusinessElement [message #1454510 is a reply to message #726066] Tue, 28 October 2014 09:27 Go to previous messageGo to next message
Hi all,
How do I link a pictogram element added to a diagram with a bo of another diagram?
Moreover, how can I update the diagram automatically when the underlying BO changes?
Simone
Re: Multiple PictogramElements for single BusinessElement [message #1455696 is a reply to message #1454510] Wed, 29 October 2014 13:04 Go to previous message
Simone Di Cola wrote on Tue, 28 October 2014 09:27
Hi all,
Simone
You can use Update Feature provided by Graphiti
[Updated on: Wed, 29 October 2014 13:05] by Moderator
Previous Topic:Distinguishing between ContainerShapes
Next Topic:Switch programmatically to move mode
Current Time: Sun Jul 27 04:02:05 EDT 2025
Powered by FUDForum. Page generated in 0.04909 seconds
