Home » Modeling » EMF » [CDO] Security Manager and Package Filter
[CDO] Security Manager and Package Filter [message #1454368] Tue, 28 October 2014 05:49 Go to next message
I created simple as I thought security policy for my models in CDO but I ended up with not working PackageFilter used as a permission in a role.
Let me describe the situation in detail.
In CDO Server I have a "limited" folder with model resources inside.
I turned on Security Manager by simply adding
<securityManager type="default" description="/security:annotation:home(/home)"/>
Then, all users have read only access to all resources inside the "limited" folder expressed by the fololwing two Resource Filters:
  • READ resource >= /limited
    - folders = true
    - text resources = true
    - binary resources = true
    - model resources = true
    - model objects = true
    - include parents = true
    - include root = true
  • WRITE resource >= /limited
    - folders = false
    - text resources = false
    - binary resources = false
    - model resources = false
    - model objects = false
    - include parents = false
    - include root = false
In the "limited" folder I created a new model resource with several EPackage objects as roots.
Now I'd like to give a write access for users only to one of EPackage object.
So I made a new rule with Package Filter:
  • WRITE package == MyPackage
    - applicable Package = MyPackage
All roles are assigned to the proper users.
A conclusion is that Package Filter does not work, all EPackage objects got read only access anyway.
Any ideas? What am I doing wrong?
Paweł
Re: [CDO] Security Manager and Package Filter [message #1471461 is a reply to message #1454368] Thu, 13 November 2014 00:07 Go to previous message
Am 28.10.2014 um 10:49 schrieb Paweł Doleciński:
> I turned on Security Manager by simply adding <securityManager type="default"
> Resource Filters:
> - folders = true
> - folders = false
I fear without a minimal test case that reproduces the problem it's not possible for me to tell what's going wrong. The
following CDO test cases may serve you as examples:
Bugzilla_399487_Test
Bugzilla_417483_Test
Bugzilla_418267_Test
Bugzilla_422170_Test
Cheers
/Eike
http://www.esc-net.de
Previous Topic:[CDO] Persistance Strategy for Java Objects
Next Topic:[CDO] references between different packages / DanglingReferenceException
Current Time: Sun Jul 27 03:49:40 EDT 2025
Powered by FUDForum. Page generated in 0.12398 seconds
