Home » Language IDEs » Java Development Tools (JDT) » External Tool/Ant Builders
External Tool/Ant Builders [message #141540] Thu, 12 February 2004 15:51 Go to next message
Originally posted by: mbrozowski.nc.rr.com
I was wondering if there is a good reason why the 'wizard' for the Ant
Builder in a Java Project is not the same as the Ant/Runtime
preferences page which in turn is not the same as the External
Tools.. ->Ant Builder..
An example is why can't I set the Classpath in the Ant Builder for my
Java Project
Also the External Program Builders are also different...
Why can't I set environment variables for the Java Project builder
when I can other places
Is there a reason for the additional limitations on the builders?
Do you need someone to help make it more consistent?
Matt Brozowski
Re: External Tool/Ant Builders [message #141552 is a reply to message #141540] Thu, 12 February 2004 16:18 Go to previous messageGo to next message
> Java Project
Possible for 3.0
https://bugs.eclipse.org/bugs/show_bug.cgi?id=50986
Fixed in M7
https://bugs.eclipse.org/bugs/show_bug.cgi?id=51298
Time :-)
We are trying but help is always appreciated.
Thanks for the feedback
Darins
Re: External Tool/Ant Builders [message #141595 is a reply to message #141552] Thu, 12 February 2004 17:17 Go to previous messageGo to next message
Thank you so much for the info... I'm really looking forward to M7 (I
guess I've gotten used to the once per month milestones... )
Are the behaviors for these different Tabbed collection all
different... It seems like it would be a lot easier for all of you.. I
this code was all common (with only a few special case tabs such as
'common' and 'build options') Is it necessary to maintain two or
three completely different sets?
Also a related question... Does the environment tab support eclipse
variables like ${workspace:/project} as a value and are there variable
for thinks like JAVA_HOME?
Thanks for the great help. I'll start learning that code and see if
there is any way I can help in this area.
Matt Brozowski
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:c0gq54$lda$1@eclipse.org...
my
> > Java Project
> Possible for 3.0
> Fixed in M7
> Time :-)
> Darins
Re: External Tool/Ant Builders [message #141675 is a reply to message #141595] Fri, 13 February 2004 00:31 Go to previous messageGo to next message
"Mathew Brozowski" <mbrozowski@nc.rr.com> wrote in message
news:c0gtt7$q7n$1@eclipse.org...
I wish I could get used to them :-)
The code is really common among the different groups it is just the time to
do the "wiring" behind the UI...minimal but it still takes time
Yes you can use variables that get expanded.
For your case you would use ${workspace_loc:/project}
For example, if you set to append to the native environment, you can set
PATH to be ${workspace_loc:/project} and this will be appended to the value
of the PATH variable.
We should make this easier and more appearant to the user that you can use
variables.
I logged:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=51935
For a listing of possible variables check out the selection available by
hitting the Variables button on the Main tab of a builder.
To use JAVA_HOME, you would make use of the env_var variable with the name
JAVA_HOME:
${env_var:JAVA_HOME}
Let me know if there is any way I can help. Don't hesitate to ask
development questions on the platform-ant-dev mailing list.
Darins
Re: External Tool/Ant Builders [message #145209 is a reply to message #141675] Wed, 25 February 2004 10:01 Go to previous messageGo to next message
I'm using M7 now and don't see an Environment tab in the dialog that
appears when I select Run/External Tools/External Tools.../Ant Build/{my
ant config}. I could really use such a thing, but just don't know how to
access it. Did this feature really make M7 in the end?
Chris DiGiano
> variables.
> I logged:
> JAVA_HOME:
> Darins
Re: External Tool/Ant Builders [message #145391 is a reply to message #145209] Wed, 25 February 2004 12:08 Go to previous messageGo to next message
Chris there is no Environment Tab for the Ant builds...only the Program
external tools.
We are working out what it means to have the environment tab for the Ant
builds.
If the build is launched in the same VM as Eclipse it has no meaning.
I would be interested in your use case as we currently do not intend to add
the environment tab for the Ant builds...but we can change :-)
Darins
"Chris DiGiano" <chris.digiano@sri.com> wrote in message
news:c1id6o$nho$1@eclipse.org...
> Chris DiGiano
to
set
value
use
> > variables.
> > I logged:
name
> > JAVA_HOME:
> > Darins
Re: External Tool/Ant Builders [message #145400 is a reply to message #145391] Wed, 25 February 2004 12:23 Go to previous messageGo to next message
Here's my case: I have an ant target that needs
${env.JAVA_HOME}/tools.jar in the classpath. I would like my environment
variable JAVA_HOME to be available when I run this ant target from
within Eclipse.
Chris
> external tools.
> builds.
> Thanks
> Darins
>>Chris DiGiano
> to
> set
> value
> use
>>>variables.
>>>I logged:
> name
>>>JAVA_HOME:
>>>Darins
Re: External Tool/Ant Builders [message #145428 is a reply to message #145400] Wed, 25 February 2004 12:53 Go to previous messageGo to next message
By default (with no environment tab) you will inherit the environment
variables.
My quick test
<project default="environ">
<target name="environ">
<property environment="env"></property>
<echo>${env.JAVA_HOME}</echo>
</target>
</project>
Produces the expected effect for both same and separate VM.
So with no additional support it would seem you can do what you need?
Darins
news:c1ilfr$4p5$1@eclipse.org...
> within Eclipse.
> Chris
> > external tools.
> > builds.
add
> > Thanks
> > Darins
> >>Chris DiGiano
time
> > to
> > set
> > value
> > use
> >>>variables.
> >>>I logged:
by
> > name
> >>>JAVA_HOME:
> >>>Darins
Re: External Tool/Ant Builders [message #145437 is a reply to message #145428] Wed, 25 February 2004 13:14 Go to previous messageGo to next message
That does not work for me under M7. Here's the output--
environ:
[echo] ${env.JAVA_HOME}
BUILD SUCCESSFUL
....and yes, I checked that JAVA_HOME is defined by using printenv on the
command line.
Chris
> variables.
> My quick test
> </target>
> </project>
> Thanks
> Darins
>>within Eclipse.
>>Chris
>>>external tools.
>>>builds.
> add
>>>Thanks
>>>Darins
>>>>Chris DiGiano
> time
>>>to
>>>set
>>>value
>>>use
>>>>>variables.
>>>>>I logged:
> by
>>>name
>>>>>JAVA_HOME:
>>>>>Darins
Re: External Tool/Ant Builders [message #145463 is a reply to message #145437] Wed, 25 February 2004 13:54 Go to previous message
So it would appear that we have a bug on our *nix support as this works fine
on Windows.
I have logged
https://bugs.eclipse.org/bugs/show_bug.cgi?id=53097
to investigate as I only have Windows at my current location.
Darins
news:c1iog2$9dp$1@eclipse.org...
> environ:
> BUILD SUCCESSFUL
> command line.
> Chris
> > variables.
> > My quick test
> > </target>
> > </project>
> > Thanks
> > Darins
> >>within Eclipse.
> >>Chris
> >>>external tools.
Ant
> >>>builds.
> > add
> >>>Thanks
> >>>Darins
Build/{my
to
> >>>>Chris DiGiano
(I
I
> > time
> >>>to
variable
> >>>set
> >>>value
can
> >>>use
> >>>>>variables.
> >>>>>I logged:
> > by
> >>>name
> >>>>>JAVA_HOME:
> >>>>>Darins
Previous Topic:Announce: new plug-in for continuous testing
Next Topic:AdapterFactory IAdaptable without changing model objects
Current Time: Sun May 11 04:51:33 EDT 2025
Powered by FUDForum. Page generated in 0.03725 seconds
