Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMFStore] unable to retrieve history
[EMFStore] unable to retrieve history [message #1454068] Mon, 27 October 2014 19:10 Go to next message
I have a model stored in EMFStore that has gone through 269 revisions
and is about 10MB in size on the server. I'm able to checkout revisions
through the History Browser after a certain version, but attempting to
checkout any revision before that version fails with the following
exception.
Have you seen this kind of problem before. What could cause this and is
that a way I can fix it so that previous versions are accessible?
!ENTRY org.eclipse.emf.emfstore.client 4 4 2014-10-27 18:58:24.579
!MESSAGE
org.eclipse.emf.emfstore.internal.server.exceptions.ConnectionException:
Server could not be reached.
Failed to parse server's response: Couldn't parse EObject: Failed to
retrieve ID for EObject contained in project:
com.humanfactor.rw.model.regatta.impl.ResultsImpl@7d382ac6
(officialFinishTime: null, rawFinishTime: null, officialOrderOfFinish:
0, adjustedOrderOfFinish: 0)
!STACK 0
java.util.concurrent.ExecutionException:
at java.util.concurrent.FutureTask.report(FutureTask.java:122)
at java.util.concurrent.FutureTask.get(FutureTask.java:202)
at
org.eclipse.emf.emfstore.internal.client.common.UnknownEMFStoreWorkloadCommand.execute(UnknownEMFStoreWorkloadCommand.java:83)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$13.call(ESRemoteProjectImpl.java:415)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$13.call(ESRemoteProjectImpl.java:1)
at
org.eclipse.emf.emfstore.client.util.RunESCommand$WithException$1.doRun(RunESCommand.java:61)
at
org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommandWithResult.commandBody(EMFStoreCommandWithResult.java:31)
at
org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.execute(AbstractEMFStoreCommand.java:64)
at
com.humanfactor.emf.edocument.editingdomain.EMFStoreTransactionalCommandStack$1.doExecute(EMFStoreTransactionalCommandStack.java:61)
at
org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
at
org.eclipse.emf.common.command.BasicCommandStack.execute(BasicCommandStack.java:78)
at
org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.basicExecute(AbstractTransactionalCommandStack.java:241)
at
com.humanfactor.emf.edocument.editingdomain.EMFStoreTransactionalCommandStack.basicExecute(EMFStoreTransactionalCommandStack.java:163)
at
org.eclipse.emf.transaction.impl.TransactionalCommandStackImpl.doExecute(TransactionalCommandStackImpl.java:63)
at
org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at
org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at
com.humanfactor.emf.edocument.editingdomain.EMFStoreTransactionalCommandStack.runEMFStoreCommand(EMFStoreTransactionalCommandStack.java:64)
at
com.humanfactor.emf.edocument.editingdomain.EMFStoreTransactionalCommandStack.execute(EMFStoreTransactionalCommandStack.java:49)
at
org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.aRun(AbstractEMFStoreCommand.java:108)
at
org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommandWithResult.run(EMFStoreCommandWithResult.java:59)
at
org.eclipse.emf.emfstore.client.util.RunESCommand$WithException.runWithResult(RunESCommand.java:78)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl.fetch(ESRemoteProjectImpl.java:395)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl.checkout(ESRemoteProjectImpl.java:438)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl.checkout(ESRemoteProjectImpl.java:1)
at
org.eclipse.emf.emfstore.internal.client.ui.controller.UICheckoutController.doRun(UICheckoutController.java:245)
at
org.eclipse.emf.emfstore.internal.client.ui.controller.UICheckoutController.doRun(UICheckoutController.java:1)
at
org.eclipse.emf.emfstore.internal.client.ui.common.MonitoredEMFStoreAction$1.run(MonitoredEMFStoreAction.java:70)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at
org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
at
org.eclipse.ui.internal.progress.ProgressManager.run(ProgressManager.java:1162)
at
org.eclipse.emf.emfstore.internal.client.ui.common.MonitoredEMFStoreAction.execute(MonitoredEMFStoreAction.java:67)
at
org.eclipse.emf.emfstore.internal.client.ui.handlers.CheckoutRevisionHandler.handle(CheckoutRevisionHandler.java:60)
at
org.eclipse.emf.emfstore.internal.client.ui.handlers.AbstractEMFStoreHandler.handleWithResult(AbstractEMFStoreHandler.java:29)
at
org.eclipse.emf.emfstore.internal.client.ui.handlers.AbstractEMFStoreHandlerWithResult$1.doRun(AbstractEMFStoreHandlerWithResult.java:52)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.emf.emfstore.internal.client.ui.handlers.AbstractEMFStoreHandlerWithResult.execute(AbstractEMFStoreHandlerWithResult.java:54)
at
org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
at
org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at
org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at
org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:243)
at
org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:224)
at
org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at
org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:167)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
at
org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at
org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at
org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:850)
at
org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:743)
at
org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:727)
at
org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:662)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at
org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
at
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at com.humanfactor.rw.rcp.RWApplication.start(RWApplication.java:136)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by:
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcClientManager.executeCall(XmlRpcClientManager.java:174)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcClientManager.callWithResult(XmlRpcClientManager.java:120)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcConnectionManager.getProject(XmlRpcConnectionManager.java:172)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$13$1$1.run(ESRemoteProjectImpl.java:409)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$13$1$1.run(ESRemoteProjectImpl.java:1)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.ServerCall.run(ServerCall.java:249)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.SessionManager.executeCall(SessionManager.java:126)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.SessionManager.execute(SessionManager.java:65)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.ServerCall.execute(ServerCall.java:269)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$13$1.run(ESRemoteProjectImpl.java:413)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$13$1.run(ESRemoteProjectImpl.java:1)
at
org.eclipse.emf.emfstore.internal.client.common.UnknownEMFStoreWorkloadCommand$1.call(UnknownEMFStoreWorkloadCommand.java:73)
at java.util.concurrent.FutureTask.run(FutureTask.java:262)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:744)
Caused by: org.apache.xmlrpc.client.XmlRpcClientException: Failed to
parse server's response: Couldn't parse EObject: Failed to retrieve ID
at
org.apache.xmlrpc.client.XmlRpcStreamTransport.readResponse(XmlRpcStreamTransport.java:188)
at
org.apache.xmlrpc.client.XmlRpcStreamTransport.sendRequest(XmlRpcStreamTransport.java:156)
at
org.apache.xmlrpc.client.XmlRpcHttpTransport.sendRequest(XmlRpcHttpTransport.java:143)
at
org.apache.xmlrpc.client.XmlRpcSunHttpTransport.sendRequest(XmlRpcSunHttpTransport.java:69)
at
org.apache.xmlrpc.client.XmlRpcClientWorker.execute(XmlRpcClientWorker.java:56)
at org.apache.xmlrpc.client.XmlRpcClient.execute(XmlRpcClient.java:167)
at org.apache.xmlrpc.client.XmlRpcClient.execute(XmlRpcClient.java:137)
at org.apache.xmlrpc.client.XmlRpcClient.execute(XmlRpcClient.java:126)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcClientManager.executeCall(XmlRpcClientManager.java:164)
... 15 more
Caused by: org.xml.sax.SAXException: Couldn't parse EObject: Failed to
org.apache.xmlrpc.XmlRpcException: Couldn't parse EObject: Failed to
at
org.apache.xmlrpc.parser.RecursiveTypeParserImpl.endValueTag(RecursiveTypeParserImpl.java:80)
at
org.apache.xmlrpc.parser.XmlRpcResponseParser.endElement(XmlRpcResponseParser.java:197)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(AbstractSAXParser.java:609)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(XMLDocumentFragmentScannerImpl.java:1789)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2965)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:606)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:117)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:510)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:848)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:777)
at
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
at
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:649)
at
org.apache.xmlrpc.client.XmlRpcStreamTransport.readResponse(XmlRpcStreamTransport.java:186)
... 23 more
Caused by: org.apache.xmlrpc.XmlRpcException: Couldn't parse EObject:
Failed to retrieve ID for EObject contained in project:
at
org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.util.EObjectTypeParser.getResult(EObjectTypeParser.java:80)
at
org.apache.xmlrpc.parser.RecursiveTypeParserImpl.endValueTag(RecursiveTypeParserImpl.java:78)
... 36 more
Caused by:
org.eclipse.emf.emfstore.internal.server.exceptions.SerializationException:
at
org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.util.EObjectTypeParser.getResultfromResource(EObjectTypeParser.java:147)
at
org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.util.EObjectTypeParser.getResult(EObjectTypeParser.java:74)
... 37 more
!ENTRY org.eclipse.emf.emfstore.client 4 4 2014-10-27 18:58:24.591
!MESSAGE Server could not be reached.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 15 more
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 23 more
at
at
... 36 more
Caused by:
at
at
... 37 more
Re: [EMFStore] unable to retrieve history [message #1456726 is a reply to message #1454068] Thu, 30 October 2014 13:02 Go to previous messageGo to next message
Hi Scott,
thanks for the report! Would you mind opening a Bug Report for this
issue (https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EMFStore)?
I will try to have a look at it next month.
Thanks!
Edgar
Edgar Mueller
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: [EMFStore] unable to retrieve history [message #1485448 is a reply to message #1456726] Mon, 24 November 2014 03:45 Go to previous message
Hi Scott,
I've started looking into this issue, but had no luck so far in
reproducing this.
This issue might be related to bugs 450069
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=450069) and 450557
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=450557) which have been
fixed meanwhile.
If you are willing to provide us with your meta model as well as your
data causing the error, we might be able to debug this further.
Edgar
Edgar Mueller
Previous Topic:[EMFStore] ldap group access control
Next Topic:EMFCompareMap not found
Current Time: Thu Jul 31 17:21:41 EDT 2025
Powered by FUDForum. Page generated in 0.05157 seconds
