Java Code Generation Plug-in [message #1453637] |
Mon, 27 October 2014 04:38  |
I want to extend the Java Code Generation Plugin, I've already managed to get it to work, installed QVT Operational and successfully generated some class diagram code. Unfortunately, when I checkout the Papyrus repository with OOMPH, there are several errors and when I compile whole Eclipse, Java Generation Code plugin doesn't work, it pops up the error related to missing QVT library, the same is with Obeo UML to Java Generator, it doesn't even show in Run Configurations in compiled Eclipse. How can I get these plugins to work in compiled Eclipse to be able to make some changes in code and test? I've already tried to copy plugins into features/plugins folders, none of them worked. Thank you for your answer.
Re: Java Code Generation Plug-in [message #1489489 is a reply to message #1453637] |
Thu, 27 November 2014 07:10  |
Marek Lences a écrit :
> Hello,
> for your answer.
Hi Marek,
Do you still have this problem ?
Cedric
FUDForum. Page generated in 0.20859 seconds
