Home » Modeling » EMF » [CDO] references between different packages / DanglingReferenceException
[CDO] references between different packages / DanglingReferenceException [message #1451758] Fri, 24 October 2014 04:48 Go to next message
I'm currently working on a implementation to write our models into a CDO storage. The models are generated out of a database which contains our current meta model (no emf).
The current code generates different packages and between classes of this packages are references.
E.g.
    <eStructuralFeatures xsi:type="ecore:EReference" name="SELECTED" lowerBound="1" upperBound="-1">
      <eAnnotations source="Configurations">
        <contents xsi:type="common:CompositeConfiguration">
          <children xsi:type="common:PdoPropertyConfiguration"/>
          <children xsi:type="configurations_1:DataAccessPropertyConfiguration" ColumnName="Selected Materials">
            <ColumnNames>Selected Materials</ColumnNames>
          </children>
          <children xsi:type="common:MeasureConfiguration" visible="true"/>
        </contents>
      </eAnnotations>
      <eType xsi:type="ecore:EClass" href="mda:www.xxx.de#[ecore::EClass]metalsgui_sample_matmanagement::MAT_VD"/>
    </eStructuralFeatures>
metalsgui_sample_matmanagement is a different package than the current.
Now I have problems to write it to a CDO storage. I always get an DanglingReferenceException (The object "org.eclipse.emf.ecore.impl.EClassImpl@618ea67a (eProxyURI: mda:www.xxx.de#[ecore::EClass]metalsgui_sample_matmanagement::MAT_VD)(org.eclipse.emf.ecore.impl.EClassImpl)" is not contained in a resource).
Here is my test code (getContents() returns the current model):
    private void loadToCdo2()
        CDOModelStorage cdo = new CDOModelStorage( "CDO", "localhost", 2036, false, 1000, "" );
        try
            CDOTransaction tx = cdo.getSession().openTransaction();
            CDOResource res = tx.getResource( "abc3" );
            while( getContents().size() > 0 )
                EObject obj = getContents().get( 0 );
                // EcoreUtil.resolveAll( obj );
                log.info( "copy: " + obj + " class: " + obj.getClass() );
                res.getContents().add( obj );
            tx.commit();
        catch( Exception e )
            log.warn( "Can't copy (" + e.getMessage() + ")\n", e );
        log.info( "finish" );
Even when I try to resolve (EcoreUtil.resolveAll( obj )) the model I get an exception.
I also tried to write back my models to xmi files (this works) and load it into the cdo via the CDO Explorer in Eclipse. There I get the same DanglingReferenceException.
Now, I don't know how to handle such references between the models. Any suggestion?
Johannes.
Re: [CDO] references between different packages / DanglingReferenceException [message #1471466 is a reply to message #1451758] Thu, 13 November 2014 00:13 Go to previous message
Hi Johannes,
A DanglingReferenceException means that you try to commit an object A that has a cross-reference to an object B and that
B is not contained in any resource. If that's the case it doesn't matter what client parts of CDO you use, you must find
and fix that problem in your model/application. Even in a pure EMF application (without any CDO) you would get the same
or a similöar exception when you attempt to save it to XML.
Cheers
/Eike
http://www.esc-net.de
Am 24.10.2014 um 14:54 schrieb Johannes Schaefer:
> Hello,
> E.g.
> </children>
> </contents>
> </eAnnotations>
> "mailto:org.eclipse.emf.ecore.impl.EClassImpl@618ea67a (eProxyURI:
> try
> tx.commit();
> Regards,
> Johannes.
Previous Topic:[CDO] Security Manager and Package Filter
Next Topic:[EMF] MinimalEStoreEObjectImpl
Current Time: Sat Oct 25 21:07:34 EDT 2025
Powered by FUDForum. Page generated in 0.04992 seconds
