Home » Newcomers » Newcomers » Locking is not possible in the directory(Problem with locking on startup)
Locking is not possible in the directory [message #1029520] Fri, 29 March 2013 16:27 Go to next message
I downloaded and installed
http://www.eclipse.org/downloads/packages/eclipse-ide-cc-developers/junosr2
in /usr/local/ as root.
root can run the program, but other users cannot. They get
Locking is not possible in the directory "/usr/local/eclipse/configuration/org.eclipse.osgi". A common reason is that the file system or Runtime Environment does not support file locking for that location. Please choose a different location, or disable file locking passing "-Dosgi.locking=none" as a VM argument.
/usr/local/eclipse/configuration/org.eclipse.osgi/.manager/.fileTableLock (Permission denied
even if they use
eclipse -vmargs -Dosgi.locking=none
How do I get this program working for ordinary users?
Also I see that logs are created in ../eclipse/configuration. It is inconvenient to clear out these files. Can the logs be sent to the user's home directory or to /var/log/eclipse instead?
Re: Locking is not possible in the directory [message #1053320 is a reply to message #1029520] Fri, 03 May 2013 16:59 Go to previous messageGo to next message
I ran into this problem trying to connect with a network drive. I have succesfully solved this on this environment by adding a line at the end of the config.ini file.
osgi.locking=none
After that I was able to set up a workspace on the network drive. Hope that helps.
Daniel
icon14.gif  Re: Locking is not possible in the directory [message #1451379 is a reply to message #1053320] Thu, 23 October 2014 14:58 Go to previous message
Thank you so much. I was having the same problem and this fixed my problem with eclipse-jee-indigo-win32.
Previous Topic:Eclipse not starting on Mepis Linux
Next Topic:No Design view tab
Current Time: Sun Jul 20 22:10:22 EDT 2025
Powered by FUDForum. Page generated in 0.09033 seconds
