Home » Archived » Visual Editor (VE) » Eclipse 3.3, VE and gridbaglayout problem
Eclipse 3.3, VE and gridbaglayout problem [message #145020] Wed, 18 June 2008 08:29 Go to next message
Originally posted by: fbondioli.autentiweb.com
Hi all,
I need to use eclipse europa for a project based on both j2EE and swing.
I've installed VE following instruction on VE wiki but there seem to be a bug with GridBagLayout: adding an item to a panel produces this king of code:
GridBagConstraint gridBagConstraint32 = ;
instead of
GridBagConstraint gridBagConstraint32 = new GridBagConstraint();
If I manually insert the missing piece all works ok but actually I need to do it for every single swing object I put on my panels...
Is there a way to fix this? Will be VE integrated in the upcoming 3.4 release?
Best Regards
JB
Re: Eclipse 3.3, VE and gridbaglayout problem [message #145030 is a reply to message #145020] Wed, 18 June 2008 09:00 Go to previous messageGo to next message
Originally posted by: matthew.leah.pdgm.nospam.com
Hi Fabio,
This problem has been fixed in the recent VE release that Yves Yang
announced in this group (See post titled [ANN] Build for Eclipse 3.4
RC2). I am quite happily using this version with Eclipse 3.4 RC3.
I think the problem has also been fixed for 3.3.x eclipse builds,
however, there is no 'official' version available. The 3.3.x version
provided at http://www.ehecht.com/eclipse_ve/ve.html seems to work fine.
Hope that helps,
Matt.
Fabio B. wrote:
> Hi all,
> of code:
> instead of
> release?
> Best Regards
> JB
Re: Eclipse 3.3, VE and gridbaglayout problem [message #145038 is a reply to message #145030] Wed, 18 June 2008 09:52 Go to previous messageGo to next message
Matthew Leah ha scritto:
> Hi Fabio,
I'm just using that version that I found on www.ehecht.com and I'm having this problem
I've downloaded and installed this file under 3.3 (europa):
http://www.ehecht.com/eclipse_ve/ve_eclipse_34M7_win20080512 1900.zip
And with this file I'm having the GridBagLayout problem.
Does Yves Yang produced an unofficial build for 3.3 that has this problem fixed?
Best regards
FB
Re: Eclipse 3.3, VE and gridbaglayout problem [message #145047 is a reply to message #145038] Wed, 18 June 2008 10:18 Go to previous message
> problem fixed?
I've found it in an old post.
I've just installed it and seems to work great!
Many many thanks to Yves Yang!
Best regards
FB
Re: Eclipse 3.3, VE and gridbaglayout problem [message #617220 is a reply to message #145020] Wed, 18 June 2008 09:00 Go to previous message
Hi Fabio,
Hope that helps,
Matt.
Fabio B. wrote:
> Hi all,
> of code:
> instead of
> release?
> Best Regards
> JB
Re: Eclipse 3.3, VE and gridbaglayout problem [message #617221 is a reply to message #145030] Wed, 18 June 2008 09:52 Go to previous message
> Hi Fabio,
Best regards
FB
Re: Eclipse 3.3, VE and gridbaglayout problem [message #617222 is a reply to message #145038] Wed, 18 June 2008 10:18 Go to previous message
> problem fixed?
Best regards
FB
Previous Topic:Eclipse 3.3, VE and gridbaglayout problem
Next Topic:VE not invoking/appearing/working/loading
Current Time: Thu Jul 24 22:09:30 EDT 2025
Powered by FUDForum. Page generated in 0.07383 seconds
