Home » Eclipse Projects » Eclipse Scout » Tree Field in Scout Kepler(class TestTreeField extends AbstractTreeField)
Tree Field in Scout Kepler [message #1449380] Tue, 21 October 2014 05:07 Go to next message
Hi all,
I define a TreeField in my form and I load it dinamically when my application start, but I have a couple of questions regarding the operation of this field:
- first: after initial load on the inizialization of the field, the user can set different filter and reload the information in the Tree Field. This operation doesn't produce visible results but in the debug mode I see that the tree is filled correctly.
- Second: when I expand the node I set on the node a different icon but the layout the control isn't updated.
I think that the problem is the same in this two points but at the moment I don't understand where is my mistake.
Here the code to inizialize the Tree Field and to load the data:
        protected void execInitField() throws ProcessingException {
          this.getTree().setCheckable(true);
          this.getTree().setMultiSelect(false);
          this.getTree().setEnabled(true);
          this.getTree().setMultiCheck(true);
          if (getGroupOrderForOrderFileField().isChecked()) {
            this.setLabel(TEXTS.get("FileOrderList"));
          else {
            this.setLabel(TEXTS.get("OrderList"));
          //Load Tree Node
          loadTreeNodes();
          //Listener on tree changed
          this.getTree().addTreeListener(new TreeAdapter() {
            public void treeChanged(TreeEvent e) {
              System.out.println("TestTree : " + e.getType());
              //Check event
              if (e.getType() == TreeEvent.TYPE_NODE_EXPANDED) {
                //Check if the node is locked or not
                if (e.getNode().isChecked()) {
                  //Node locked
                  e.getNode().setExpanded(false);
                  MessageBox.showOkMessage("Node Locked", "Node", e.getNode().getCell().getText());
                else {
                  //Node not locked
                  MessageBox.showOkMessage("Node Expanded", "Node", e.getNode().getCell().getText());
                  e.getNode().getCellForUpdate().setIconId(Icons.Padlock16);
                  e.getNode().setChecked(true);
              else if (e.getType() == TreeEvent.TYPE_NODE_COLLAPSED) {
                MessageBox.showOkMessage("Node Collapsed", "Node", e.getNode().getCell().getText());
                e.getNode().getCellForUpdate().setIconId("");
                e.getNode().setChecked(false);
        public void loadTreeNodes() {
          Tree tree = new Tree();
          AbstractTreeNode node;
          AbstractTreeNode parent = null;
          AbstractTreeNode node1 = null;
          boolean loadTree = false;
          //Prepare search criteria
          List<String> listCountryId = new ArrayList<String>();
          String interfaceID = "";
          //Country ID
          if (getCountryIDField() != null) {
            if (getCountryIDField().getTable().getSelectedRowCount() > 0) {
              //Create a list of country for the filter
              for (ITableRow row : getCountryIDField().getTable().getSelectedRows()) {
                listCountryId.add(row.getCell(0).toString());
            else {
              listCountryId = Arrays.asList("");
          else {
          //Interface
          if (getInterfaceField() != null) {
            if (getInterfaceField().getTable().getSelectedRowCount() > 0) {
              interfaceID = getInterfaceField().getTable().getSelectedRow().getCell(0).toString();
            else {
              interfaceID = "";
          else {
            interfaceID = "";
          IDesktopService service = SERVICES.getService(IDesktopService.class);
          Object[][] result = service.loadNode(getRefNr(), getCustomerId(), isFielmannFilter(), isFeedbackFilter(), getLowerLimit(),
              getUpperLimit(), getUsesTimeIntervalField().isChecked(), getDoubleFileField().isChecked(),
              listCountryId, interfaceID);
          if (result != null) {
            if (result.length > 0) {
              String lastFile = "";
              //Fill the tree
              for (int index = 0; index < result.length; index++) {
                if (!lastFile.toLowerCase().equals(result[index][2].toString().toLowerCase())) {
                  //Parent + leaf
                  lastFile = result[index][2].toString();
                  //Definition of node
                  node = getAbstractTree(result[index][2].toString(), Integer.parseInt(result[index][0].toString()));
                  node.setEnabled(true);
                  //Check reorder
                  if (Integer.parseInt(result[index][6].toString()) > 0) {
                    node.getCellForUpdate().setForegroundColor("FF0000");
                  //Check if locked
                  if (Integer.parseInt(result[index][3].toString()) > 0) {
                    node.setChecked(true);
                    node.getCellForUpdate().setIconId(Icons.Padlock16);
                  else {
                    node.setChecked(false);
                    node.getCellForUpdate().setIconId("");
                  parent = node;
                  //Definition of leaf
                  node1 = getAbstractTree(result[index][4].toString(), Integer.parseInt(result[index][1].toString()));
                  node1.setEnabled(true);
                  node1.setLeaf(true);
                    node1.getCellForUpdate().setForegroundColor("FF0000");
                  if (Integer.parseInt(result[index][5].toString()) > 0) {
                    node1.setChecked(true);
                  if (index == 0) {
                    node.setLeaf(false);
                    tree.addChildNode(tree.getRootNode(), node);
                  else {
                  //Connect leaf with his parent
                  tree.addChildNode(parent, node1);
                else {
                  //Only leaf
                    tree.findNode(parent.getPrimaryKey()).getCellForUpdate().setForegroundColor("FF0000");
              loadTree = true;
          if (!loadTree) {
            MessageBox.showOkMessage("No Value", "Tree Load Operation", "No data");
          setTree(tree, false);
Can someone help me understand this issue?
Thanks in advance for any help
Re: Tree Field in Scout Kepler [message #1449385 is a reply to message #1449380] Tue, 21 October 2014 05:20 Go to previous messageGo to next message
Hi all,
I partially solved the first question or better I find the right way to solve it.
The problem about this point is linked on the source-code of button that exec the load of data in base at the filter set by user.
Wrongly, I used to call the method "loadRootNode()" instead my method to load the tree:
//Destroy and recreate Tree
          getTestTreeField().getTree().disposeTree();
          getTestTreeField().getTree().initTree();
//Load data in to tree
          getTestTreeField().loadTreeNodes();
Instead the second point remains opened. I accept any help and suggestion.
Thanks in advance at all
Re: Tree Field in Scout Kepler [message #1450482 is a reply to message #1449385] Wed, 22 October 2014 09:47 Go to previous messageGo to next message
Hi all,
I find my mistake also for the second point.
The error is: after reinitialized the tree I don't associated the handler to manage the various event and for this reason I don't see the expected modify on the layout of the node.
I hope that helps other persons that have a similar error Smile
Re: Tree Field in Scout Kepler [message #1450527 is a reply to message #1450482] Wed, 22 October 2014 10:33 Go to previous messageGo to next message
marco giudici wrote on Wed, 22 October 2014 15:47
It will help other scout developers. Thanks for sharing!
Re: Tree Field in Scout Kepler [message #1454570 is a reply to message #1450482] Tue, 28 October 2014 10:39 Go to previous messageGo to next message
Hi all,
I have noticed a difference in the operation of the Tree Field between SWT and RAP interface.
When I load a new set of data and use the istruction:
In SWT interface appears correctly the new tree and it works fine. Instead in RAP interface nothing appears and the Tree field remains empty.
In the first time, I think a problem linked to the istructions:
and for this reason, I comment these two rows but nothing has changed in the behavior.
Re: Tree Field in Scout Kepler [message #1454595 is a reply to message #1450527] Tue, 28 October 2014 11:09 Go to previous messageGo to next message
Hi all,
I have another problem with this type of field, I have found two different behaviors between SWT and RAP interface:
  • In SWT when I load a new set of information, the tree field is correctly populated and works fine
  • In RAP, when I do the same operation to obtain the same result, the tree field remains empty
In the first time, I thinked that the problem is linked with these two istructions:
and for this reason I commented these two rows, but nothing has changed in the behavior. The code is in the first message of this topic.
This is the result in these two interfaces:
index.php/fa/19702/0/
  • Attachment: Cattura.PNG
    (Size: 19.33KB, Downloaded 307 times)
[Updated on: Wed, 29 October 2014 04:39] by Moderator
Re: Tree Field in Scout Kepler [message #1455359 is a reply to message #1454595] Wed, 29 October 2014 05:33 Go to previous message
Hi all,
is it possible that one reason of this problem is linked to this error message
!ENTRY org.eclipse.scout.rt.ui.rap 4 0 2014-10-29 10:27:14.936
!MESSAGE org.eclipse.scout.rt.ui.rap.internal.servletfilter.DelegateFilter$1.service(DelegateFilter.java:66) IOException
 UserAgent: Mozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.1; Win64; x64; Trident/5.0)
RemoteIP: 127.0.0.1
What exactly does this error message?
Previous Topic:Multi-module app and dev workflow
Next Topic:How to fix broken Service Registration
Current Time: Sat Jul 26 02:45:42 EDT 2025
Powered by FUDForum. Page generated in 1.05695 seconds
