Home » Newcomers » Newcomers » How to enable local Java API docs for context-sensitive API help
How to enable local Java API docs for context-sensitive API help [message #144894] Fri, 24 March 2006 16:37 Go to next message
Originally posted by: Bernd.Giesen.gmx.net
when I attempt to get context-sensitive help for a Java class (e.g. the
JDialog class from the Swing toolkit), my Eclipse 3.1.2 application always
opens an Internet connection to java.sun.com to display the appropriate
Java 2 SDK docs from there.
How/Where can I configure Eclipse (3.1.2) to use my existing local
installation of the Java 2 SDK docs instead?
kind regards,
Bernd
Re: How to enable local Java API docs for context-sensitive API help [message #144913 is a reply to message #144894] Fri, 24 March 2006 19:26 Go to previous messageGo to next message
Open your Package Explorer, right click on the .jar library
you want to modify (something like foo\jre\lib\rt.jar),
select Properties from the menu. You should now see a dialog
asking for the Javadoc location that has a default value of
http://sun.com. Click the Browse button to point to your
local drive paying mind to the note about "package-list".
-paul
Re: How to enable local Java API docs for context-sensitive API help [message #144983 is a reply to message #144913] Sat, 25 March 2006 10:53 Go to previous message
> -paul
THX!
kind regards,
Bernd
Previous Topic:How can I get eclipse's junit plugin to run with java apps ?
Next Topic:Problem with dataprovider
Current Time: Wed Nov 05 04:07:01 EST 2025
Powered by FUDForum. Page generated in 0.26668 seconds
